MaticB Posted June 1, 2023 Share #1 Â Posted June 1, 2023 Advertisement (gone after registration) I need your advice! Whenever I connect the camera through USB cable to the computer (iMac 27' 2019), camera on OFF, it doesn't charging at all. All the settings are as suggested by instruction manual. Camera otherwise work perfectly. Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted June 1, 2023 Posted June 1, 2023 Hi MaticB, Take a look here M11Monochrom USB charging. I'm sure you'll find what you were looking for!
alksv Posted June 1, 2023 Share #2 Â Posted June 1, 2023 That's a known "feature". You can somewhat circumvent that by turning it on, waiting for the LED on the bottom to indicate it's charging and then turning it off. It will keep charging. Hopefully they can fix that behaviour in the future updates. 2 Link to post Share on other sites More sharing options...
MaticB Posted June 1, 2023 Author Share #3 Â Posted June 1, 2023 9 hours ago, alksv said: That's a known "feature". You can somewhat circumvent that by turning it on, waiting for the LED on the bottom to indicate it's charging and then turning it off. It will keep charging. Hopefully they can fix that behaviour in the future updates. Thanks! I will certainly try! Link to post Share on other sites More sharing options...
