BjarniM Posted April 17, 2023 Share #1 Posted April 17, 2023 Advertisement (gone after registration) I have just been commissioned for an assignment, and I do not want to buy a Leica flash since I don’t really have a need for it on a daily basis, and I ‘only’ might need it for fill in-light outside in broad daylight. I have a Nikon SB-24-flash (390 grams plus four AA-batteries) in my drawer for my Nikon equipment, but I am wondering if it’s too heavy for my M10’s hot-shoe. Does anyone have a qualified answer, how much a flash for the M10 may weigh? Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 17, 2023 Posted April 17, 2023 Hi BjarniM, Take a look here M10: How heavy a flash can it handle?. I'm sure you'll find what you were looking for!
Lelmer Posted April 17, 2023 Share #2 Posted April 17, 2023 44 minutes ago, BjarniM said: I have just been commissioned for an assignment, and I do not want to buy a Leica flash since I don’t really have a need for it on a daily basis, and I ‘only’ might need it for fill in-light outside in broad daylight. I have a Nikon SB-24-flash (390 grams plus four AA-batteries) in my drawer for my Nikon equipment, but I am wondering if it’s too heavy for my M10’s hot-shoe. Does anyone have a qualified answer, how much a flash for the M10 may weigh? SF-60, 300g Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted April 17, 2023 Share #3 Posted April 17, 2023 (edited) I have used the SB-28 on the M9 and M240 and they are well balanced. I would expect the SB-24 and M10/11 to be the same. Edited April 17, 2023 by LocalHero1953 Quote Link to post Share on other sites More sharing options...
Siriusone59 Posted April 17, 2023 Share #4 Posted April 17, 2023 SF-40, 203g, 301g with batteries installed. Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted April 17, 2023 Share #5 Posted April 17, 2023 Leica SF-58 (which I use) 355 grams less batteries. I also have the SB-24 and have used it on my M bodies without issue. I doubt the Nikon flash shoes are stronger than the Leica ones. 1 Quote Link to post Share on other sites More sharing options...
dugby Posted April 17, 2023 Share #6 Posted April 17, 2023 For many years on both a M240 and M10-R, I regularly use a Mecablitz Metz 40MZ-3i ( with SCA3502M5 and 4 alkaline AA batteries ) which weighs 530g. The design is comfortable balanced. Quote Link to post Share on other sites More sharing options...
PhotogLeica Posted May 8, 2023 Share #7 Posted May 8, 2023 Advertisement (gone after registration) I use a Minolta 132X, if you can find a good one that works. Its voltage output is less than 3 volts. Problem with third party old flashes is they might be over 6 volts, I think that is a danger to the camera. If you want something new I've read about Godex flashes, the Nikon versions, are suppose to work, but not positive if it is manual mode only or not. The old Minolta 132x flashes are auto with an electronic "eye", but they cannot work well in backlight or bright sunlight settings. You would need to practice and test. I use mine for fill flash indoors and set the camera per. the back dial's recommendation for f/stop, then test it and adjust. Usually bounce off the roof. Its fun to use, cheap...20 bucks or less. Works great for occasional use. Quote Link to post Share on other sites More sharing options...
dugby Posted May 8, 2023 Share #8 Posted May 8, 2023 Whilst my heavy Metz 40MZ-3i is a superb dual reflector speedlight, I’ve recently purchased the Leica SF26 (GN26) which weighs only 124g I am absolutely surprised and pleased how well the TTL-only SF26 operates on the M10-R. The preflash is so fast , one can hardly observe it. There is a well hidden instruction in the SF26 user guide to get the flash to work reliably: “a half press of shutter to enable metering” before the shooting period. I think this is my new favorite M speedlight for occasional use (slow charge build up after 2-4 consecutive flashes) 1 Quote Link to post Share on other sites More sharing options...
