logan2z Posted March 10, 2023 Share #1  Posted March 10, 2023 Advertisement (gone after registration) I just received a Zeiss Biogon 35mm/2.8 that I rented and have been having a minor issue mounting it to my M2. The lens fits into the mount fine, but won't turn unless I lightly depress the lens release button. Once I do, it turns and locks as expected. The problem seems intermittent as sometimes it does turn without the release button being depressed, but most times it will not. I tried the lens on my M4 and it worked a bit better there, but still felt pretty tight when it turned - tighter than the Leica lenses I own. I don't know if this is an issue with the Biogon or just a matter of tolerances between the lens and the mount. FWIW, I tried my 50mm Summicron on my M2 and it went on just fine. Anyone else ever experience this with the Biogon, or any other lenses? Link to post Share on other sites More sharing options...
Advertisement Posted March 10, 2023 Posted March 10, 2023 Hi logan2z, Take a look here Minor problem mounting Zeiss Biogon 35mm/2.8. I'm sure you'll find what you were looking for!
madNbad Posted March 10, 2023 Share #2  Posted March 10, 2023 It’s the lens. I never had a problem mounting my Biogon on either my M2 or Millennium. The mount on the lens must be slightly off. See if if you can get a different lens. Link to post Share on other sites More sharing options...
lct Posted March 10, 2023 Share #3 Â Posted March 10, 2023 My Biogon 35/2.8 fits perfectly my M3, M4-2, M6J, M8.2, M240 and M11 cameras. I would return this faulty copy to prevent damages to the lens mount of your M2. Link to post Share on other sites More sharing options...
logan2z Posted March 10, 2023 Author Share #4  Posted March 10, 2023 @madNbad @lct Thanks for the responses. I'll return the lens and see if I can get another copy.  Link to post Share on other sites More sharing options...
CPA Posted March 10, 2023 Share #5  Posted March 10, 2023 It’s definitely the lens. My C Biogon mounted perfectly on both my M6 and M-A.  Great lens. Link to post Share on other sites More sharing options...
logan2z Posted March 10, 2023 Author Share #6  Posted March 10, 2023 14 minutes ago, CPA said: It’s definitely the lens. My C Biogon mounted perfectly on both my M6 and M-A.  Great lens. Thanks, it's on its way back. Link to post Share on other sites More sharing options...
