TigrisJK Posted December 24, 2022 Share #1 Â Posted December 24, 2022 Advertisement (gone after registration) Anyone got a fix for a loose front element for the Summilux FLE or do I need to send it back to Leica? It's not as simple as cranking it tight, that's for sure, it (a) doesn't stay tight and (b) needs to be in a certain orientation for the hood to fit and lock properly in place, or else it won't do it. Video demonstrating the issue:https://photos.app.goo.gl/QuRS6aAKau14tSFu7 Link to post Share on other sites More sharing options...
Advertisement Posted December 24, 2022 Posted December 24, 2022 Hi TigrisJK, Take a look here 35mm Summilux FLE - loose front element. I'm sure you'll find what you were looking for!
wda Posted December 24, 2022 Share #2 Â Posted December 24, 2022 A job for Leica, I think. Link to post Share on other sites More sharing options...
jaeger Posted December 25, 2022 Share #3 Â Posted December 25, 2022 welcome to the club Link to post Share on other sites More sharing options...
Jeff S Posted December 25, 2022 Share #4 Â Posted December 25, 2022 Or call/send to reliable third party repairer, e.g., DAG. Jeff Link to post Share on other sites More sharing options...
28framelines Posted December 26, 2022 Share #5  Posted December 26, 2022 On 12/24/2022 at 11:58 AM, TigrisJK said: Anyone got a fix for a loose front element for the Summilux FLE or do I need to send it back to Leica? It's not as simple as cranking it tight, that's for sure, it (a) doesn't stay tight and (b) needs to be in a certain orientation for the hood to fit and lock properly in place, or else it won't do it. Video demonstrating the issue:https://photos.app.goo.gl/QuRS6aAKau14tSFu7 That is painful to watch. I wonder if this is part of the reason they are switching these lenses to have a lens hood built in. Link to post Share on other sites More sharing options...
TigrisJK Posted December 28, 2022 Author Share #6 Â Posted December 28, 2022 (edited) Thanks all. I'll contact support. And I wonder, that seems possible. I certainly prefer the look of this hood to the new pull out, honestly. Plus it's so sturdy the hood itself is a protective measure in the front of my lens. I've had it a decade as my primary lens and I really wouldn't want to live without it, so it's definitely going back to Leica. Edited December 28, 2022 by TigrisJK Link to post Share on other sites More sharing options...
labyrinth Posted December 31, 2022 Share #7  Posted December 31, 2022 Advertisement (gone after registration) The fix is easy. There are three screws under the name plate, they are now loose, you need to tighten them. Take the name plate off first by using the rubber ring (widely available on ebay of different sizes).  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 2 4 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/357192-35mm-summilux-fle-loose-front-element/?do=findComment&comment=4622305'>More sharing options...
CLTRYD Posted May 18, 2023 Share #8  Posted May 18, 2023 Hello everyone, I have the very same issue with my elmarit 28mm asph v2, and I tried Labyrinth ‘s fix, but the name ring just seems to unscrew undefinitely and I can’t take it out. did anyone had a similar experience and found a workaround? thanks! Link to post Share on other sites More sharing options...
labyrinth Posted June 2, 2023 Share #9  Posted June 2, 2023 On 5/18/2023 at 5:57 PM, CLTRYD said: Hello everyone, I have the very same issue with my elmarit 28mm asph v2, and I tried Labyrinth ‘s fix, but the name ring just seems to unscrew undefinitely and I can’t take it out. did anyone had a similar experience and found a workaround? thanks! please check this link for picures elmarit v2 disassembly Link to post Share on other sites More sharing options...
CLTRYD Posted June 8, 2023 Share #10 Â Posted June 8, 2023 On 6/2/2023 at 12:00 PM, labyrinth said: please check this link for picures elmarit v2 disassembly Thanks! however, I believe the v2 is built quite differently than the last asph version, but cool ressource anyway! Link to post Share on other sites More sharing options...
