budjames Posted December 4, 2022 Share #1 Posted December 4, 2022 Advertisement (gone after registration) I started getting random out of focus shots using my SL 16-35mm zoom on my SL2. The focus peaking shows in focus, but the images are blurry. I noticed this on images were the subject is a couple of hundred feet away. I was shooting outdoors in sun with the shutter speeds greater than 1/500s with image stabilization ON. Has anyone else experienced auto focusing issues with this lens? Thanks, in advance, your any comments. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography. Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 4, 2022 Posted December 4, 2022 Hi budjames, Take a look here Leica Vario Super Elmar SL 16-35mm on SL2 out of focus shots on longer distances. I'm sure you'll find what you were looking for!
ImmerDraussen Posted December 4, 2022 Share #2 Posted December 4, 2022 Hi Bud, I‘ve had some issues in the past, but it was my mistake. The autofocus spot had moved into the corner when I put the camera into the bag. If the horizon function is switched on, this is hardly noticable. With wide angle lenses the wrong focus is not very obvious in the EVF. Since I force myself to center the autofocus after switching on the camera, the problem is gone. I would prefer a setting that would do this automatically when the camera is started. Andreas 1 Quote Link to post Share on other sites More sharing options...
jplomley Posted December 4, 2022 Share #3 Posted December 4, 2022 4 hours ago, budjames said: I started getting random out of focus shots using my SL 16-35mm zoom on my SL2. The focus peaking shows in focus, but the images are blurry. I noticed this on images were the subject is a couple of hundred feet away. I was shooting outdoors in sun with the shutter speeds greater than 1/500s with image stabilization ON. Has anyone else experienced auto focusing issues with this lens? Thanks, in advance, your any comments. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography. I have this exact same problem. No idea what the issue is since does not happen on my 35/75 APO SC-L lenses. Need to do some more rigorous testing. How are the corners on your copy? Resolution across the entire frame? Quote Link to post Share on other sites More sharing options...
MediaFotografie Posted December 4, 2022 Share #4 Posted December 4, 2022 vor 4 Stunden schrieb budjames: I started getting random out of focus shots using my SL 16-35mm zoom on my SL2. The focus peaking shows in focus, but the images are blurry. I noticed this on images were the subject is a couple of hundred feet away. I was shooting outdoors in sun with the shutter speeds greater than 1/500s with image stabilization ON. Has anyone else experienced auto focusing issues with this lens? I have (fortunately) not noticed anything like that so far. I often use the lens on the SL 601 and the SL2. Quote Link to post Share on other sites More sharing options...
trickness Posted December 4, 2022 Share #5 Posted December 4, 2022 Happens occasionally for me even with the 35 and 75 SL APOs, usually when I’m using back button focus, but occasionally even with autofocus. It’s only maybe one out of 20 shots but it is definitely puzzling. Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted December 4, 2022 Share #6 Posted December 4, 2022 1 hour ago, trickness said: Happens occasionally for me even with the 35 and 75 SL APOs, usually when I’m using back button focus, but occasionally even with autofocus. It’s only maybe one out of 20 shots but it is definitely puzzling. I'm a long time back button focus photographer. When I first got my SL2 I set it up just like my Nikons. Shutter does not activate autofocus, autofocus set to AF-C, joystick initiates autofocus. Press and release joystick for stationary subjects; press and hold for moving ones. Found that my SL2 does not work the same as my Nikons. Press and release on a stationary subject results in OOF shots about 10% of the time. I have to be in AF-S for that to work consistently. Interestingly, if I press and hold in AF-C I consistently get in focus shots even on a stationary subject. 1 Quote Link to post Share on other sites More sharing options...
budjames Posted December 5, 2022 Author Share #7 Posted December 5, 2022 Advertisement (gone after registration) Thanks everyone for your comments. Today, I'm shipping my lens to the Leica service center to get it checked out. Regards, Bud James Please check out my fine art and travel photography at www.budjames.photography. Quote Link to post Share on other sites More sharing options...
insomnia Posted December 5, 2022 Share #8 Posted December 5, 2022 (edited) Hmm, do you have the issue on single shot or on continuous shot? I've noticed that for the slower continuous drives, the camera will try to focus new after the first shot (and also take a new exposure). It will take the following shot even if it didn't lock focus (it's great!). So it's basically impossible to lock & reframe unless you assign exposure and AF lock on the joystick (it does work if you're in single shot mode or one of the faster options, where the camera has no time to re-lock focus and exposure). Exposure lock doesn't even work with manual lenses, here the joystick will always trigger the magnification. It's a mess, but they don't seem to have the motivation to change it. Leica representative says, his friend's Nikon behaves similar, that was pretty much the only answer, no drive to improve the product. Edited December 5, 2022 by insomnia Quote Link to post Share on other sites More sharing options...
