MRJohn Posted November 23, 2022 Share #1 Posted November 23, 2022 Advertisement (gone after registration) I want to copy slides and I was trying to use the combination but the extender does not fit over the ROM contact (the Apo Extender 2x does fit and is a workaround but the aperture prolongation makes for longer exposure). Does anyone know of a simple extender which does the same, but allows me to use it on a ROM-modified lens? Thanks in advance for any suggestions. Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 23, 2022 Posted November 23, 2022 Hi MRJohn, Take a look here Macro Elmarit R 2.8/60 ROM and Extender 14198 issue - any alternatives?. I'm sure you'll find what you were looking for!
MattiasAndersson Posted November 23, 2022 Share #2 Posted November 23, 2022 34 minutes ago, MRJohn said: I want to copy slides and I was trying to use the combination but the extender does not fit over the ROM contact (the Apo Extender 2x does fit and is a workaround but the aperture prolongation makes for longer exposure). Does anyone know of a simple extender which does the same, but allows me to use it on a ROM-modified lens? Thanks in advance for any suggestions. The Macro-Adapter-R can be found with ROM contacts, as you probably know. I started with a TL2 but has now a SL, this is my set up for 1:1 full frame. Positive results so far, the Macro-Adapter-R + Macro-Elmarit-R with SL give me some Cromatic Aberration that need to be corrected. Have only done slides so far. Tried color negatives, not so easy to get colors right. B&W is easy. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/349578-macro-elmarit-r-2860-rom-and-extender-14198-issue-any-alternatives/?do=findComment&comment=4575279'>More sharing options...
MRJohn Posted November 23, 2022 Author Share #3 Posted November 23, 2022 Nice setup. - I ran my slides through a Nikon Coolscan 5000 before (still have to sell it), just want to see if for select "good ones" perhaps there is a benefit with this method. I did try negatives and find it difficult too. 1 Quote Link to post Share on other sites More sharing options...
frame-it Posted November 23, 2022 Share #4 Posted November 23, 2022 1 hour ago, MattiasAndersson said: Tried color negatives, not so easy to get colors right. B&W is easy. might help>> 2 Quote Link to post Share on other sites More sharing options...
davidmknoble Posted December 3, 2022 Share #5 Posted December 3, 2022 @frame-it, really great article! Thanks for posting that. I’ve been working on best ways to scan 120mm negatives with a Leica S3 and 120 macro lens and found some similar setups, but the software he uses (NLP) looks really interesting to help finish the job! 1 Quote Link to post Share on other sites More sharing options...
davidmknoble Posted December 3, 2022 Share #6 Posted December 3, 2022 This is the setup I have and will try out with 35mm and 120mm. https://www.camerawest.com/new/miw-x-negative-supply-35mm-pro-kit Quote Link to post Share on other sites More sharing options...
frame-it Posted December 3, 2022 Share #7 Posted December 3, 2022 (edited) Advertisement (gone after registration) 27 minutes ago, davidmknoble said: @frame-it, really great article! Thanks for posting that. I’ve been working on best ways to scan 120mm negatives with a Leica S3 and 120 macro lens and found some similar setups, but the software he uses (NLP) looks really interesting to help finish the job! i use this process for 6x6 negatives[scanned with fuji GFX] and also for exotic films that have no profile in most scanning software, and also for black and white i scan DNG in sillverfast/plustek, its very very fast, then follow this process for black and white https://www.alexburkephoto.com/blog/2019/10/16/manual-inversion-of-color-negative-film Edited December 3, 2022 by frame-it 1 Quote Link to post Share on other sites More sharing options...
