A. Cahan Posted November 8, 2022 Share #1 Posted November 8, 2022 Advertisement (gone after registration) I have a 40mm 1.4 Nokton Classic and the Voigtlander LH-6 Lens hood. The tolerance of the lens hood is so close that most UV filters will not allow the lens hood to be used. I have an old Vivitar K2 that will fit the lens and allow the hood to be used. Could someone suggest a new UV that will fit? Andrew Cahan Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 8, 2022 Posted November 8, 2022 Hi A. Cahan, Take a look here VOIGTLANDER 40MM 1.4 NOKTON CLASSIC. I'm sure you'll find what you were looking for!
Fred Miranda Posted November 9, 2022 Share #2 Posted November 9, 2022 Hi Andrew, I use a B+W 007 Clear filter (slim) with it and the hood attaches just fine. (LH-6) 1 Quote Link to post Share on other sites More sharing options...
pippy Posted November 10, 2022 Share #3 Posted November 10, 2022 I've found that Hoya filters allow the hood to slip over the ring. Previously - when I used a generic screw-in hood - I used VHBW filters but the rings of these, like your Vivitar, are too thick for the LH-6 to fit so should be avoided. Philip. Quote Link to post Share on other sites More sharing options...
