Me Leica! Posted September 27, 2022 Share #1 Posted September 27, 2022 Advertisement (gone after registration) After my last camera gave up on me (after a lot of good service, mind you), I started pondering what to get to replace it. After a process of elimination I had it down to a couple of options, neither of which happened to be Leica, but then I saw an X Vario in a local shop. I'd never considered this camera before, but I did some googling on it and it seemed like a nice compromise of IQ, usability, weight, etc. So I picked it up yesterday. I've only just started playing around with it, so this may well be an "RTFM" question (although it didn't come with a "FM", and it's a Leica, so it's not like you have to master a Sony-style maze of menus). I found the way to move the AF point is by pressing the "Delete/Focus" button for a second or two, which then makes the AF point movable. That's fine, but a little slow, so I wanted to know if there's a faster way. I'm not going to be using this camera in situations where I need blazing AF; in many cases I'll probably use MF. But for those times where AF is useful, is there a faster way to move the AF point? Thanks in advance! Quote Link to post Share on other sites More sharing options...
Advertisement Posted September 27, 2022 Posted September 27, 2022 Hi Me Leica!, Take a look here X Vario and moving the AF point. I'm sure you'll find what you were looking for!
wda Posted September 27, 2022 Share #2 Posted September 27, 2022 If you are used to touch screen adjustments, remember that technology was not available when the XV was designed. It is is slower to operate, but not critically. Quote Link to post Share on other sites More sharing options...
mija1789 Posted September 27, 2022 Share #3 Posted September 27, 2022 There is also the well-known trick: - move the camera so that the AF point is on the target point you want in focus - depress halfway the trigger (this will lock AF) and keep it so - reframe the camera so as to capture the scene you want - fully depress the trigger The exposure might change when reframing depending on the mode selected but it can be corrected in post-processing or if you can juggle with your fingers, depress the AE lock before reframing whilst keeping the trigger halfway depressed 1 Quote Link to post Share on other sites More sharing options...
