Sharphoto Posted September 1, 2022 Share #1 Posted September 1, 2022 Advertisement (gone after registration) Thambar has a spot filter.. has anybody found a way to use a Summicron lens with a spot filter ? Or is softening the image done during post ? Quote Link to post Share on other sites More sharing options...
Advertisement Posted September 1, 2022 Posted September 1, 2022 Hi Sharphoto, Take a look here Spot filter for Summicron lenses. I'm sure you'll find what you were looking for!
a.noctilux Posted September 1, 2022 Share #2 Posted September 1, 2022 I don't have any experience with spot filter. However for "softening" effect you can try one of these Hoya Diffusion Filters or Duto or simply make filters by yourself your imagination is the limit, hairspray, breath, nylon fabric, etc. Quote Link to post Share on other sites More sharing options...
Sharphoto Posted September 1, 2022 Author Share #3 Posted September 1, 2022 (edited) Ok thank you , will use when needed on the 75mm Summicron ..cheaper than buying a 75mm Summilux........Duto Thumbs up Edited September 1, 2022 by Sharphoto Quote Link to post Share on other sites More sharing options...
graphlex Posted September 1, 2022 Share #4 Posted September 1, 2022 13 minutes ago, a.noctilux said: I don't have any experience with spot filter. However for "softening" effect you can try one of these Hoya Diffusion Filters or Duto or simply make filters by yourself your imagination is the limit, hairspray, breath, nylon fabric, etc. Probably just as good as the Softar I once tried. Quote Link to post Share on other sites More sharing options...
a.noctilux Posted September 1, 2022 Share #5 Posted September 1, 2022 I do use some diffution devices (DIY only) on my Noctilux, sometimes. I can not share results, but I can say very "pleasing". Quote Link to post Share on other sites More sharing options...
earleygallery Posted September 1, 2022 Share #6 Posted September 1, 2022 Other soft focus effects can be had using a clear filter and some vaseline - good for getting different effects e.g. just around the edges or centre. Of course there is also the option to add softening in digital PP. Quote Link to post Share on other sites More sharing options...
Ecar Posted September 2, 2022 Share #7 Posted September 2, 2022 Advertisement (gone after registration) https://tiffen.com/products/black-pro-mist-filter Expensive though. Quote Link to post Share on other sites More sharing options...
Pyrogallol Posted September 2, 2022 Share #8 Posted September 2, 2022 UV filter with Vaseline round the edge is what I used in the 70’s. Quote Link to post Share on other sites More sharing options...
spydrxx Posted September 2, 2022 Share #9 Posted September 2, 2022 In the 70s I used a patch of womens' hosiery with a central hole burned in with a cigarette. Quote Link to post Share on other sites More sharing options...
