sinjun Posted August 27, 2022 Share #1 Posted August 27, 2022 Advertisement (gone after registration) The anti-reflection paint is wearning off my titanium-coated 35mm summilux to the extent that it is likely to contribute to flare. Are there any suggestions for what paint I could use to touch it up? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/336014-suggestions-for-anti-reflection-paint/?do=findComment&comment=4497893'>More sharing options...
Advertisement Posted August 27, 2022 Posted August 27, 2022 Hi sinjun, Take a look here Suggestions for anti-reflection paint. I'm sure you'll find what you were looking for!
spydrxx Posted August 27, 2022 Share #2 Posted August 27, 2022 I'd use a flat black enamel paint lightly applied with a brush and thoroughly hardened before subsequent use. 1 1 Quote Link to post Share on other sites More sharing options...
Pyrogallol Posted August 27, 2022 Share #3 Posted August 27, 2022 This is what I use for any camera blackout needs, but you may find painting the filter threads will stop you screwing in a filter or it will rub off when you do. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 1 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/336014-suggestions-for-anti-reflection-paint/?do=findComment&comment=4498028'>More sharing options...
250swb Posted August 27, 2022 Share #4 Posted August 27, 2022 Paint will rub right off again if you put a filter on and I don't think it will make any difference to the image even if it all flakes off. Quote Link to post Share on other sites More sharing options...
chasdfg Posted August 27, 2022 Share #5 Posted August 27, 2022 I think he can't put a filter on those threads anyway since it's the 35lux pre-asph. Quote Link to post Share on other sites More sharing options...
sinjun Posted August 27, 2022 Author Share #6 Posted August 27, 2022 3 hours ago, Pyrogallol said: This is what I use for any camera blackout needs, but you may find painting the filter threads will stop you screwing in a filter or it will rub off when you do. Thanks, that's interesting - it even says 'photographic work' on the tin, though I'm not sure what it means by that. As Chasdfg says I can't put a filter on anyway - in fact they are not even threads, just circular rather than spiral indents. 3 hours ago, 250swb said: Paint will rub right off again if you put a filter on and I don't think it will make any difference to the image even if it all flakes off. I think it does make a difference in the right (wrong) circumstances since the titanium finish is pretty shiny. You may be right about rubbing off though. Although a filter won't fit there, the titanium finish seems to make a poor substrate for paint and the lens cap pushes agains this part. Quote Link to post Share on other sites More sharing options...
Pyrogallol Posted August 27, 2022 Share #7 Posted August 27, 2022 Advertisement (gone after registration) I use the blackboard paint for the inside of homemade wooden large format cameras and anything else that needs matt black, like the inside of lenshoods. 1 Quote Link to post Share on other sites More sharing options...
adan Posted August 27, 2022 Share #8 Posted August 27, 2022 Why mess around with the also-rans? https://www.amazon.com/BLACK-2-0-Flattest-pigmented-waterbased/dp/B0758GKKGZ 1 Quote Link to post Share on other sites More sharing options...
sinjun Posted August 27, 2022 Author Share #9 Posted August 27, 2022 25 minutes ago, adan said: Why mess around with the also-rans? https://www.amazon.com/BLACK-2-0-Flattest-pigmented-waterbased/dp/B0758GKKGZ Looks ideal - assuming it will stick. I found a reseller on Ebay who repackages in 10 ml bottles for £3.40 so will give it a go. Quote Link to post Share on other sites More sharing options...
Kl@usW. Posted August 28, 2022 Share #10 Posted August 28, 2022 vor 20 Stunden schrieb sinjun: The anti-reflection paint is wearning off my titanium-coated 35mm summilux to the extent that it is likely to contribute to flare. Are there any suggestions for what paint I could use to touch it up? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! https://tetenal.com/media/60/bd/3a/1605714511/351686_00_Produkt Information_Kameralack Spray_105202_DE_08-05-2017.pdf If you spray a small amount of the paint onto a cotton swab you can then apply the matte black paint. Or else you take a small container and spray the required amount into that container before applying it with a small brush. You should clean the surface with benzine or alcohol before applying the paint. 1 Quote Link to post Share on other sites More sharing options...
Anbaric Posted August 28, 2022 Share #11 Posted August 28, 2022 14 hours ago, adan said: Why mess around with the also-rans? https://www.amazon.com/BLACK-2-0-Flattest-pigmented-waterbased/dp/B0758GKKGZ Apparently there's now a Black 3.0, and Musou Black claims to be even blacker: https://culturehustle.com/products/black-3-0-the-worlds-blackest-black-acrylic-paint-150ml https://www.ko-pro.black/2020/05/14/black-3-0-vs-musou-black/ 1 Quote Link to post Share on other sites More sharing options...
sinjun Posted August 28, 2022 Author Share #12 Posted August 28, 2022 38 minutes ago, Anbaric said: Apparently there's now a Black 3.0, and Musou Black claims to be even blacker: It seems not to have such good adhesion qualities though, which is an important consideration in my case. Quote Link to post Share on other sites More sharing options...
rramesh Posted August 28, 2022 Share #13 Posted August 28, 2022 (edited) Why don’t you just hide this area by screwing in a filter? Or maybe just the black filter ring without the glass? Edited August 28, 2022 by rramesh Quote Link to post Share on other sites More sharing options...
rramesh Posted August 28, 2022 Share #14 Posted August 28, 2022 My mistake. Maybe those are not filter threads I thought I saw. Quote Link to post Share on other sites More sharing options...
hdmesa Posted August 28, 2022 Share #15 Posted August 28, 2022 Repainting it yourself will devalue it more than leaving it alone. It's character. Slap the 12504 lens hood on it and never think about it again. . . . If you can't let it go, use a professional repaint/repair service like Kanto to repaint just the inside of the rim. I doubt they would charge much for that. 1 Quote Link to post Share on other sites More sharing options...
sinjun Posted August 28, 2022 Author Share #16 Posted August 28, 2022 5 hours ago, hdmesa said: Repainting it yourself will devalue it more than leaving it alone. It's character. That's something that had crossed my mind - but I can't see it doing irreparable damage and in this instance I'm more interested in utility than character. Quote Link to post Share on other sites More sharing options...
Ernstk Posted August 29, 2022 Share #17 Posted August 29, 2022 Use matt black model paint from Humbrol, Revell or Tamiya. Ernst Quote Link to post Share on other sites More sharing options...
