sunung1188 Posted August 7, 2022 Share #1 Posted August 7, 2022 (edited) Advertisement (gone after registration) Dropped my M10 with my 50 Cron attached from chest height and it luckily landed right on the Leica Uva II filter. The optics of the lens seem unscathed but I could not remove the filter and the focus ring becomes slightly stiff half way turning. I’m amazed the glass on the Leica Uva II did not shatter and finally I know the importance of why a good filter is crucial for protection. Just sent it in for CLA - here’s a vote: Do you think CLA by Leica can save the cron? it’s my first ever CLA! Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited August 7, 2022 by sunung1188 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/335301-will-cla-be-able-to-save-this-vote/?do=findComment&comment=4484594'>More sharing options...
Advertisement Posted August 7, 2022 Posted August 7, 2022 Hi sunung1188, Take a look here Will CLA be able to save this? (Vote). I'm sure you'll find what you were looking for!
pedaes Posted August 7, 2022 Share #2 Posted August 7, 2022 (edited) Definitely yes. The only consideration would be cost, but should be fine. Are you insured? Edited August 7, 2022 by pedaes Quote Link to post Share on other sites More sharing options...
lct Posted August 7, 2022 Share #3 Posted August 7, 2022 Of course yes. Quote Link to post Share on other sites More sharing options...
insomnia Posted August 7, 2022 Share #4 Posted August 7, 2022 "Clean, Lubricate, Adjust" - hmmm. If your question is, if the service is gonna be able to fix it: of course. If "CLA" is enough, I doubt it 😉 Quote Link to post Share on other sites More sharing options...
pippy Posted August 7, 2022 Share #5 Posted August 7, 2022 I suspect they will be able to return your lens as if nothing had ever happened to it. As mentioned by Pedaes in post #2, however, cost might be a bit of an issue depending on what the engineers find on strip-down of the lens. Best of good fortune! Philip. Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 7, 2022 Share #6 Posted August 7, 2022 (edited) A CLA by anyone would not fix this. But as a repair job? No problem. I threw my Apo-Summicron-M 90 Asph onto the cobbles outside Parma cathedral some years ago. The glass appeared intact, but the focus had locked. Leica repaired it (a few hundred pounds IIRC) and it literally was like new. Edited August 7, 2022 by LocalHero1953 Quote Link to post Share on other sites More sharing options...
spydrxx Posted August 7, 2022 Share #7 Posted August 7, 2022 Advertisement (gone after registration) I had my M4 with a new 50 Summicron IV crash down onto the pavement a few years ago in the winter...lens ok but focus was jammed. Sent it to DAG and it came back a smooth as new. Quote Link to post Share on other sites More sharing options...
Jeff S Posted August 7, 2022 Share #8 Posted August 7, 2022 (edited) It needs an FCLA…. fix, clean, lubricate and adjust. Jeff Edited August 7, 2022 by Jeff S Quote Link to post Share on other sites More sharing options...
frame-it Posted August 7, 2022 Share #9 Posted August 7, 2022 19 minutes ago, LocalHero1953 said: I threw my Apo-Summicron-M 90 Asph onto the cobbles outside Parma cathedral some years ago. outside a Cathedral? this story sounds interesting Quote Link to post Share on other sites More sharing options...
RexGig0 Posted August 7, 2022 Share #10 Posted August 7, 2022 (edited) The filter threads, on the lens, may well be damaged, but a successful REPAIR is probable. Some parts replacement may be necessary. A mere “CLA” would be insufficient. I do not see how my “vote” can be helpful, as it would be based upon a mere guess. The chief lesson that I can see, in these images, is that a hood can act to protect both the filter and the lens. True, a hood is not always feasible, but I like to use a hood, unless something about the shoot dictates its removal. A Heliopan Adapterring/Step-Up Ring can, in some cases, act as an inexpensive, more-compact substitute for a hood. Edited August 7, 2022 by RexGig0 1 Quote Link to post Share on other sites More sharing options...
jaeger Posted August 7, 2022 Share #11 Posted August 7, 2022 seems like filter + maybe first element Quote Link to post Share on other sites More sharing options...
TomB_tx Posted August 7, 2022 Share #12 Posted August 7, 2022 I've dropped a lens once in my 50+ years using Leicas, a 35 Summicron v2, just a few feet to a hardwood floor. No visible damage, but some binding on the focus. DAG repaired it, but noticed some edge separation starting between 2 glued elements. Separation often starts with a shock like that, so be aware there could be more to fix than just the mechanical parts. However, my v2 Summicron used Canadian Balsam as the element glue, so more modern lenses may be stronger. Quote Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 7, 2022 Share #13 Posted August 7, 2022 (edited) 4 hours ago, frame-it said: outside a Cathedral? this story sounds interesting Not particularly interesting! I was with choir on tour to Bologna and Parma; we were hanging around outside before the recital, so of course I was taking photos. When we were summoned, I grabbed my bag from the ground in a hurry, and the strap caught underneath, turning it upside down. My lens, sitting inside, took a looping path to the cobbles. I should have (a) been more careful picking up the bag and (b) kept the bag fastened closed when not in immediate use. Edited August 7, 2022 by LocalHero1953 Quote Link to post Share on other sites More sharing options...
