Weird Bokeh for 35mm summilux pre-a
yiccciy
I just had a Leica 35mm summilux pre-a lens and notice a weird thing in the bokeh. As you can see, the bokeh circled are not smooth, instead there are nets connected by light spot inside. Is this supposed to be a lens issue?
I shot on M6 with Fuji xtra400, F1.4 and scanned with epson V750
Any help is greatly appreciated. Thanks!!
(Also I don’t know what’s that yellowish thing behind the green plant..)
Edited by yiccciy
shooting through a window?
check the negative with a magnified loupe, & check the scanner settings
Especially one with a window screen (an evenly-spaced grid of wires)?
All kinds of things can be "imaged" in bokeh/blurs, especially if they are a repeating pattern that can moiré with itself in constructive interference patterns.
Or if the lens has overcorrected spherical aberration to make the sharp areas sharper/clearer (which the all double-gauss pre-ASPH 35s have to one extent or another.) That produces "bright-ring bokeh," and the bright rings can overlap like the Olympic logo and produce artificial patterns.
Monochromatic light like LED traffic lights (all the red is virtually the same wavelength, like a laser) can emphasize the interference patterns.
Consider the "floaters" that our eyes themselves image from time to time (body detritus floating around in the jelly (vitreous humor) between the eye's lens and the retina).
Consider "onion-ring" bokeh from some ASPH lenses - which are simply imaging microscopic "stair-steps" molded into the ASPH surface by the carved-metal mold. An image literally produced at the place where the light rays are "least focused" - in the middle of the lens itself somewhere.
https://www.imaging-resource.com/news/2014/05/02/the-end-of-onion-ring-bokeh-panasonic-beats-the-curse-of-aspheric-lenses
Here's a wide-open shot with the seven-element "King of bokeh" 35 Summicron v.4 - very similar in construction to the 35 Summilux pre-ASPH. See all the bright-ring-bokeh "doughnuts" and how they can overlap to produce doubled images (pith helmet brim, some of the background twigs and branches) and other patterns?
Now imagine a screen or wire fence between the foreground and the background, and therefore also blurred. And how those blurs would interact with the other blurs to produce even more artifact patterns.
It all just boils down to the physics of bending light rays/waves/photons through and around things.
Edited by adan
There is to much to go at here. Generally speaking your lens is the least likely cause of any problems with that highlight 'problem'. And beyond that it is equipment or user error. For example if in the background there was a street sign that gave off a digital light display you may see bright spot in the highlights because of the LED light source. On the other hand if it has been very poorly scanned you may also see individual LED's showing up in highlights because of the scanner, but not something I've ever seen with an Epson V750. Generally from a photo where everything is out of focus it is impossible to say if any other faults are chromatic aberration or something else in the background. Maybe try the lens where it is best, f/4 or f5.6 and not at the 'emergency' end of the scale at f/1.4 because the pre-asp Summilux wide open has many optical problems.
Edited by 250swb
