Pelu2010 Posted May 6, 2022 Share #61 Posted May 6, 2022 Advertisement (gone after registration) Hey , if you like to watch the update. kind regards peter 4 1 Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 6, 2022 Posted May 6, 2022 Hi Pelu2010, Take a look here Big Firmware Update for Leica SL2 (v.4.0) and SL2-S (v.3.0). I'm sure you'll find what you were looking for!
HME Posted May 6, 2022 Share #62 Posted May 6, 2022 vor 9 Stunden schrieb michali: It's not a MAC issue, I use a MAC. You may have downloaded the file twice onto the card. I've inadvertently done this before & the camera doesn't recognise the file. Reformat the card, download FW again & drag the FW File from the MAC to the SD card...... The thing that drives me nuts after a FW update is having to redo all of my camera settings again, even when I've copied settings onto the card, it makes no difference 😤 Do you reload the Profiles? 1 Quote Link to post Share on other sites More sharing options...
Jeff S Posted May 6, 2022 Share #63 Posted May 6, 2022 Red Dot Forum Camera Talk (David Farkas/Leica Miami) is devoting an episode tomorrow night to these FW updates. Jeff 3 Quote Link to post Share on other sites More sharing options...
Doug Trabaris Posted May 6, 2022 Share #64 Posted May 6, 2022 11 hours ago, erudolph said: Doug, the FW update file is definitely on root level of your SD card? Thanks! It worked. Much appreciated your expertise and that of the others on this excellent forum. 2 Quote Link to post Share on other sites More sharing options...
digitalfx Posted May 6, 2022 Share #65 Posted May 6, 2022 11 hours ago, michali said: I The thing that drives me nuts after a FW update is having to redo all of my camera settings again, even when I've copied settings onto the card, it makes no difference 😤 Back up settings first, than after update restore profiles...no need to rebuild them 1 Quote Link to post Share on other sites More sharing options...
digitalfx Posted May 6, 2022 Share #66 Posted May 6, 2022 15 hours ago, Doug Trabaris said: I download the file on my MAC to an SD card. When I insert the SD card into the camera says no file exists. Are you going to the following in the SL2 menu: -Camera Information/ -Camera Firmware version/ -Start update EDIT: oops, I see you already resolved the issue. 1 Quote Link to post Share on other sites More sharing options...
jaapv Posted May 6, 2022 Share #67 Posted May 6, 2022 Advertisement (gone after registration) On 5/5/2022 at 9:56 AM, Leon_B. said: Today Leica has released firmware update v.4.0 for the Leica SL2. Here is the link to the firmware download and an overview of all improvements. Downloads » Leica SL2 v.4.0 Download » Leica SL2-S v.3.0 DownloadImprovements New: Direct setting of ISO sensitivity via thumbwheel/front dial New: Configurable time before automatic WLAN shutdown ( Wi-Fi Sleep Mode ) New: Photo and video tagging via joystick Advanced: Additional function support for L-Mount-Alliance lenses Advanced: Additional functions for direct access via FN button Improved: AF metering method Person Detection allows the selection of the primarily focused eye Improved: ISO settings in finer increments (1⁄2EV or 1⁄3EV) Improved: Power saving mode can be completely deactivated (no AF system shutdown when recording via HDMI) Improved: Bugfixes in the firmware PHOTO New: Quick change of AF metering position between most recently used position and image center New: Exposure and depth of field preview Improved: Geotagging (via Leica FOTOS) VIDEO New: (SL2-S only) RAW format output via HDMI for external device recording Improved: Aperture setting in T-stops (1⁄2 and 1⁄3 increments) in Cine Mode Improved: HDMI output compatibility with Leica FOTOS Improved: HDMI output compatibility with USB connection 🥵 We have been complaining about the wandering focus point on the CL since the camera came out - now they fix it: On the SL2!! 😡🤬👺 Thank you very much Leica for not listening and abandoning your customers. 1 Quote Link to post Share on other sites More sharing options...
RBB Posted May 6, 2022 Share #68 Posted May 6, 2022 Updated the camera's, strange thing when I put the SL 50mm 1.4 lux on the SL2, some noise and the camera crashed, tried it again and the camera crashed again. Tried it on the Sl2s and update went fine and work on the SL2 after the lens update also. Don't understand why Leica didn't gave us the 1/3 of a iso stop on photo??? Quote Link to post Share on other sites More sharing options...
isleofgough Posted May 6, 2022 Share #69 Posted May 6, 2022 (edited) The update required factory reset a couple of times when I changed lenses (option for changing f-stop disappeared) but now everything is working. I can't tell from the pdf manual how to actually see depth of field preview. Is that a partial press on the shutter? Edited May 6, 2022 by isleofgough Quote Link to post Share on other sites More sharing options...
matted Posted May 6, 2022 Share #70 Posted May 6, 2022 11 minutes ago, isleofgough said: The update required factory reset a couple of times when I changed lenses (option for changing f-stop disappeared) but now everything is working. I can't tell from the pdf manual how to actually see depth of field preview. Is that a partial press on the shutter? You need to assign it to a function button and activate it that way. Quote Link to post Share on other sites More sharing options...
jrp Posted May 6, 2022 Share #71 Posted May 6, 2022 Does this firmware enable GPS via bluetooth without the need for WiFi?? Quote Link to post Share on other sites More sharing options...
caissa Posted May 6, 2022 Share #72 Posted May 6, 2022 (edited) 13 hours ago, Stephen white said: Can I simply upgrade to this firmware even if previous updates have not been installed ? Yes. And we have now eye AF and can even easily choose between eyes. Nice implementation. Edited May 6, 2022 by caissa Quote Link to post Share on other sites More sharing options...
jrp Posted May 6, 2022 Share #73 Posted May 6, 2022 Is the AF any better I any way? Or is it only that you have more control over which eye the camera picks to focus on? Quote Link to post Share on other sites More sharing options...
bab Posted May 6, 2022 Share #74 Posted May 6, 2022 (edited) 1 hour ago, jrp said: Is the AF any better I any way? Or is it only that you have more control over which eye the camera picks to focus on? Precisely the question my good man, Im sure not up to speed for sports or faster action but how close is it? Or a better way is it close to Canon's AF speed on a scale from 1-10 compared to other brands A1, Z9, R3 is the SL2 still in dead last place? What I shoot this file is without sharpening at all clarity set to -10 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited May 6, 2022 by bab new larger image Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/332162-big-firmware-update-for-leica-sl2-v40-and-sl2-s-v30/?do=findComment&comment=4430745'>More sharing options...
jrp Posted May 6, 2022 Share #75 Posted May 6, 2022 A great pic (although you could post process it to reduce the shiny skin, to make it a bit more flattering) but I assume that she is still and both of her eyes are within your depth of field, so I'm not sure what to conclude about the new firmware features. Quote Link to post Share on other sites More sharing options...
Paul2660 Posted May 7, 2022 Share #76 Posted May 7, 2022 For those who have updated, it’s been noted the 1/3 iso stop only applies to video. Do you get 1/2 stop increments for photo mode or is it still whole stops only. Thanks Paul Quote Link to post Share on other sites More sharing options...
beewee Posted May 7, 2022 Share #77 Posted May 7, 2022 (edited) 6 hours ago, jrp said: Does this firmware enable GPS via bluetooth without the need for WiFi?? This has been supported since the beginning. After you connect to the camera and it shows you the screen of photos on the camera, you can disconnect from the camera. This shuts down the WiFi connection keeps the bluetooth connection going and location updates is sent via bluetooth. Edited May 7, 2022 by beewee Quote Link to post Share on other sites More sharing options...
beewee Posted May 7, 2022 Share #78 Posted May 7, 2022 4 hours ago, bab said: Precisely the question my good man, Im sure not up to speed for sports or faster action but how close is it? Or a better way is it close to Canon's AF speed on a scale from 1-10 compared to other brands A1, Z9, R3 is the SL2 still in dead last place? What I shoot this file is without sharpening at all clarity set to -10 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It looks ever so slightly front focused. I’m guessing you focused on the right eye? It looks like it locked onto the reflection on the eye rather than the pupil/iris of the eye. Quote Link to post Share on other sites More sharing options...
bab Posted May 7, 2022 Share #79 Posted May 7, 2022 (edited) 4 hours ago, jrp said: A great pic (although you could post process it to reduce the shiny skin, to make it a bit more flattering) but I assume that she is still and both of her eyes are within your depth of field, so I'm not sure what to conclude about the new firmware features. Ya not pp so original raw not shinny the focus grabbed eyelashes I want to know how sticky is sl2 af for moving subjects? My image was shot in studio thanks Edited May 7, 2022 by bab Spelling Quote Link to post Share on other sites More sharing options...
SoarFM Posted May 7, 2022 Share #80 Posted May 7, 2022 21 hours ago, LocalHero1953 said: However, my SL2-S DID do its own factory reset sometime shortly after I had done the original body firmware update - I think it was just after the first lens update (24-90). It Hmm. Same thing happened on my SL2 after lens update on 24-90 Quote Link to post Share on other sites More sharing options...
