tedwill Posted April 10, 2022 Share #1 Posted April 10, 2022 Advertisement (gone after registration) I have a Leica M11. I bought two batteries with it. One battery will not charge past 75%. I tried it with the USB connected to the camera and to the charger. It stops charging (the lights flash on the charger at 75%). Anyone else experience this? Is there a fix, or should I replace the battery? Thanks! -Ted Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 10, 2022 Posted April 10, 2022 Hi tedwill, Take a look here Battery Issue. I'm sure you'll find what you were looking for!
idusidusi Posted April 11, 2022 Share #2 Posted April 11, 2022 8 hours ago, tedwill said: I have a Leica M11. I bought two batteries with it. One battery will not charge past 75%. I tried it with the USB connected to the camera and to the charger. It stops charging (the lights flash on the charger at 75%). Anyone else experience this? Is there a fix, or should I replace the battery? Thanks! -Ted I presume you take the battery out and the camera says 75%. Have you tried leaving this battery in the charger for a longer period than normally needed? If the other battery charges to 100% I would return the other battery if it does not charge past 75%. Not related but a warning to everyone. Once when I put the battery in the charger I was not concentrating and firstly put it down into the charger the wrong way, I cannot remember if I put it in normally or pressed too much..... result one of the 4 pins of the charger was a little out of position! I have since carefully pushed it back into position and the charger is working fine. It is a shame that there is no marker like a red dot on battery and charger to indicate correct insertion position. 1 Quote Link to post Share on other sites More sharing options...
tedwill Posted April 11, 2022 Author Share #3 Posted April 11, 2022 It's been very inconsistent. I have used the original cable from Leica with the charger and it just flashes green and orange as soon as I put the battery in. The other battery, which didn't have this problem, had the same problem with the charger. I used a brand new USB 3 power rated cable and plugged it into the camera and left it in all night. The first battery did charge to 100%. The second battery, which discharged down to 15%, I left in the charger all night. The charger stopped flashing after a few minutes. When I got up, the battery was still at 15%. I put that same battery into the camera and used the same cable that charged the first battery. So far, that seems to be working. It's at 80% after an hour. It could be that my charger is bad. Quote Link to post Share on other sites More sharing options...
idusidusi Posted April 11, 2022 Share #4 Posted April 11, 2022 6 minutes ago, tedwill said: It's been very inconsistent. I have used the original cable from Leica with the charger and it just flashes green and orange as soon as I put the battery in. The other battery, which didn't have this problem, had the same problem with the charger. I used a brand new USB 3 power rated cable and plugged it into the camera and left it in all night. The first battery did charge to 100%. The second battery, which discharged down to 15%, I left in the charger all night. The charger stopped flashing after a few minutes. When I got up, the battery was still at 15%. I put that same battery into the camera and used the same cable that charged the first battery. So far, that seems to be working. It's at 80% after an hour. It could be that my charger is bad. It does sound like the charger. I have two hopefully both don't go bad at the same time. Quote Link to post Share on other sites More sharing options...
Photoworks Posted April 11, 2022 Share #5 Posted April 11, 2022 one of my two batteries start blinking both light when it is done on the charger.. works fine but strange Quote Link to post Share on other sites More sharing options...
mjlamott Posted April 28, 2022 Share #6 Posted April 28, 2022 I just unboxed a new M11 and it seems that the battery is faulty. I was able to start it up, but as I began to set it up I noticed that the battery rapidly dropped from 15 to 10 percent. After that, I removed the battery and put it into the supplied charger. The charging light turned green for a few seconds, and then both lights flashed rapidly. I removed the battery and tried charging it in the camera with a USB-C cable, but the camera will not turn on anymore. I also tried a different wall charger and cable that I connected to the charging base, but that also seemed to not do anything. 1 Quote Link to post Share on other sites More sharing options...
Photoworks Posted April 28, 2022 Share #7 Posted April 28, 2022 Advertisement (gone after registration) 12 minutes ago, mjlamott said: I just unboxed a new M11 and it seems that the battery is faulty. I was able to start it up, but as I began to set it up I noticed that the battery rapidly dropped from 15 to 10 percent. After that, I removed the battery and put it into the supplied charger. The charging light turned green for a few seconds, and then both lights flashed rapidly. I removed the battery and tried charging it in the camera with a USB-C cable, but the camera will not turn on anymore. I also tried a different wall charger and cable that I connected to the charging base, but that also seemed to not do anything. one of my battery flashes, still works fine.. but I would get it replaced if it the only one you have Quote Link to post Share on other sites More sharing options...
hdmesa Posted April 29, 2022 Share #8 Posted April 29, 2022 (edited) 5 hours ago, mjlamott said: I just unboxed a new M11 and it seems that the battery is faulty. I was able to start it up, but as I began to set it up I noticed that the battery rapidly dropped from 15 to 10 percent. After that, I removed the battery and put it into the supplied charger. The charging light turned green for a few seconds, and then both lights flashed rapidly. I removed the battery and tried charging it in the camera with a USB-C cable, but the camera will not turn on anymore. I also tried a different wall charger and cable that I connected to the charging base, but that also seemed to not do anything. Try leaving the battery in the charger. I couldn't charge mine in-camera until I charged it up past a certain minimum point when new. Edited April 29, 2022 by hdmesa Quote Link to post Share on other sites More sharing options...
mjlamott Posted April 29, 2022 Share #9 Posted April 29, 2022 13 hours ago, hdmesa said: Try leaving the battery in the charger. I couldn't charge mine in-camera until I charged it up past a certain minimum point when new. I was hopeful and left it on overnight, but it's dead. Waiting for a new one from B&H and enjoying my brass paperweight in the meantime! Quote Link to post Share on other sites More sharing options...
hdmesa Posted April 29, 2022 Share #10 Posted April 29, 2022 5 hours ago, mjlamott said: I was hopeful and left it on overnight, but it's dead. Waiting for a new one from B&H and enjoying my brass paperweight in the meantime! That's dreadful to have to wait! Ugh. Throw that new one in the charger first this time! Quote Link to post Share on other sites More sharing options...
DenverSteve Posted November 22, 2022 Share #11 Posted November 22, 2022 On 4/11/2022 at 5:54 AM, idusidusi said: It does sound like the charger. I have two hopefully both don't go bad at the same time. Even if they did, charging in the body works perfectly, as I'm sure you know. Quote Link to post Share on other sites More sharing options...
