On 10/10/2022 at 9:23 AM, Huss said:
Owning both lenses, I would disagree.
"Outperform" is a vague term, but I also have both (well, all three) and I don't think either of the 35 Summarons outperform this lens in any technical sense. They're excellent lenses for 1960, especially the f/2.8, but this is a modern lens.
He could have said he prefers the Summarons, and nothing wrong with that.
A test picture with my screw 40mm on a Leica 111b. Copy of a darkroom print.
Lovely.  Longing for my own darkroom.
MP, CV 40 2.8, c200
Secured by pink flamingo
  • 5 weeks later...
Am 16.10.2022 um 12:15 schrieb Pyrogallol:
Did you try the lens with adapter for 35mm on an M? Do you need the typical adapter for 35mm with a recess to ensure that the focus-knob works? Or can you use adapters without recess?
I use mine on an M10-R and an MP with a Voigtlander 35/135 l-m adapter which has the recess, it works exactly the same as it does on my iiif.
I have not used it on an M adaptor but just tested it on one that doesnot have any cutouts and it Is ok, the infinity catch doesnot jam up.
  • 2 weeks later...
Now i can confirm that the 35mm Adapter without recess shown above does not cause problems for focussing the lens🙂.
Some quick first examples with a LTM-mount version of the Heliar with adapter on the M10:
In the review linked in #99 the 40mm Heliar was compared to the 35mm Summaron. I think the obvious comparison would be the 40mm C-Summicron. I had a try with both. Strong crops, focussing with liveview and focuspeaking on the display of the M10. Both f/2.8
First the center:
Heliar:
Summicron
Edited by UliWer
Now the object placed in the left corner:
Heliar
Summicron
