Ginko66 Posted November 28, 2021 Share #1 Posted November 28, 2021 Advertisement (gone after registration) Hello, I took this photo against the light with the monochrome ccd and the summilux 35 Fle lens. I wonder if this glow is normal, or is there some problem with the floating lnte, thanks to whoever helps me to solve Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/327001-summilux-35-asph-fle-problem-flare/?do=findComment&comment=4321667'>More sharing options...
Advertisement Posted November 28, 2021 Posted November 28, 2021 Hi Ginko66, Take a look here Summilux 35 asph FLE problem flare. I'm sure you'll find what you were looking for!
jaapv Posted November 28, 2021 Share #2 Posted November 28, 2021 It looks like the sun reflected on a window opposite the camera and the rings are probably a reflection off the edge of a filter ring. Do you use silver-coloured filters? They tend to do so. Quote Link to post Share on other sites More sharing options...
SiggiGun Posted November 28, 2021 Share #3 Posted November 28, 2021 vor 1 Minute schrieb jaapv: It looks like the sun reflected on a window opposite the camera and the rings are probably a reflection off the edge of a filter ring. Do you use silver-coloured filters? They tend to do so. I agree, this looks like a filter issue. 35mm lux is in general well controlled Quote Link to post Share on other sites More sharing options...
Ginko66 Posted November 28, 2021 Author Share #4 Posted November 28, 2021 (edited) hello, a black Leica-branded protective filter is mounted on the lens. the lenses are perfect, there are no streaks or dirt inside. I doubt that the problem is with the floating lens. Edited November 28, 2021 by Ginko66 Quote Link to post Share on other sites More sharing options...
Ginko66 Posted November 28, 2021 Author Share #5 Posted November 28, 2021 57 minutes ago, SiggiGun said: Sono d'accordo, sembra un problema di filtro. Il lux di 35 mm è in generale ben controllato hello, a black Leica-branded protective filter is mounted on the lens. the lenses are perfect, there are no streaks or dirt inside. I doubt that the problem is with the floating lens. Quote Link to post Share on other sites More sharing options...
a.noctilux Posted November 28, 2021 Share #6 Posted November 28, 2021 (edited) Next time, @Ginko66 take the pic without filter, you would see by yourself that filter + contre-jour = uncontrolled reflections. Experiment with the MC / HMC from many brands ... filters gave me this 'troubles'. Since that day of UV/IR Leica filter, I use less and less protective / UV/IR filters (only colored filters ) Edited November 28, 2021 by a.noctilux Quote Link to post Share on other sites More sharing options...
jaapv Posted November 28, 2021 Share #7 Posted November 28, 2021 Advertisement (gone after registration) 1 hour ago, Ginko66 said: hello, a black Leica-branded protective filter is mounted on the lens. the lenses are perfect, there are no streaks or dirt inside. I doubt that the problem is with the floating lens. Well, there you have the cause. Leica filters are decent, but certainly not the best - and any filter will flare and reflect in these circumstances. Never use them contrejour. Quote Link to post Share on other sites More sharing options...
Ginko66 Posted November 28, 2021 Author Share #8 Posted November 28, 2021 6 hours ago, jaapv said: Well, there you have the cause. Leica filters are decent, but certainly not the best - and any filter will flare and reflect in these circumstances. Never use them contrejour. Thanks for the answers, now I'll do some tests without using the filter, then I'll let you know, see you soon Quote Link to post Share on other sites More sharing options...
