Shooting in manual mode with a M10 capturing images as DNG.
MikeMyers
Adams in the Camera, the Print, and the Negative does a good job explaining what is going on with that white wall and the 18% grey card.  BUT, I don’t think that the zone system it is super important for day to day exposures in a digital world.  My personal style is to often have black black in photos (Zone 1 in  Adam’s world) no matter the subject.  I just like it that way.
To prepare an exposure in that way, I typically am shooting in manual mode because working with wide angle (21-28-35) I’ll catch too much of one thing or another with the meter and burn up the entire sky or black out the entire earth.  I also don’t like spending time messing around with Lr, PS, C1, or whatever, so I try to capture my intention in the camera.
For me that normally means on a sunny Mediterranean day, my version of the “sunny 16 rule” (iso200, 1/180, f/11) works fine.  You can see, I’m about +1 stop from the basic rule.  With that setting, I’ll get the brightest, brightest parts of sky, mostly near the sun burned (don’t care) and plenty of shadow details to play around with if I want.  This lets me frame and shoot, frame and shoot with out messing around with metering.  It also lets me run the same settings almost all day long.  If I step into a narrow dark gothic alleyway, I can bump the ISO a couple of stops to compensate.  If I walk inside a building, I’ll either meter quickly and compensate or flick over to A-A mode and let the camera do the work.
For me, my keepers are generally the B&W JPG from the camera, the DNGs are there but just for curiosities sake usually.  Which leads me to another tip: you might consider switching to monochrome mode even if you don’t want to shoot B&W.  The reason is that the LCD (EVF) will display in B&W.  This abstracts the scene a bit but also lets you view more in terms of tonality without the complexity of color if you choose to use the technology.
If you switch to a good manual setting you’ll probably be surprised at how well it will work for most of your day. You can use the rangefinder exclusively and concentrate more on your intention.  In A-A mode the camera is constantly adjusting (it’s job for sure) but once you overlay your personal style and expectation, the camera doesn’t seem quite so smart anymore. ;)
That's almost exactly how I do it too. I usually go 1 stop above the Sunny 16 rule. With M10, that's no problem.
If I were to photograph a white wall (or anything else), I just take a look at the sky to determine how much incident light there is, and set the exposure according to that. To me, that's both faster, easier and safer than fiddling with exposure compensation. And the results are more consistent.
6 hours ago, MikeMyers said:
First thing I think I understand about this video, is that if I take a photo of a pure white wall, I will end up with an image of an 18% gray, and that if I stand in front of a pure black wall, I will also end up with an image of 18% gray.  As the photographer, I need to understand that, and adjust my settings accordingly.  Bottom line, I "understand" this, but I'm not really sure how to apply it to real photographs I'm taking - beyond knowing that if the scene is overly bright or overly dark, I need to adjust the meter reading accordingly.  Nothing I have yet read suggests specifically how to do this.
You don't adjust the meter reading. You adjust exposure. By twiddling the shutter speed and aperture, or you use the EV compensation.
Second thing, is the despite Marcus telling us he is going to explain how the meter works, he leaves out a very important part.  If I'm right, the light hits the shutter curtain, with those gray areas marked on it, and the light is reflected back to sensors that must be somewhere in the camera - but I have no idea where they are.  How many sensors are picking up this reflected light from the back of the camera (the shutter curtain), and where are they?  Marcus never mentions them.  Maybe I am wrong about this?
On the bottom of the camera mouth.. One sensor.
I understand what the video is teaching us, about that one specific example scene.  When I aim my M10 somewhere (at random), and I get the exposure indicators, or better yet with the visoflex, I also get a histogram, how do I know whether to use the suggested readings, or adapt them based on how light or dark the middle part of my scene is?  I assume I just learn this by doing it, and eventually figure out what to do, and how.
https://digital-photography-school.com/how-to-read-and-use-histograms/
I think I'm going in the wrong direction, as nowadays I feel more comfortable with the M10 if I use the Visoflex.  It also gets me GPS information, which I prefer.  It's sad that the Visoflex uses up my battery so quickly, but it's beginning to feel like an essential accessory, which is also sort of effectively making my M10 into a "DSLR", or more so, a Mirrorless with all the tools that come with Mirrorless.  I prefer the simplicity of the basic camera, and would prefer to only use the Visoflex for complicated situations, not as my normal camera attachment.
I think, as I said,  that you are starting to overthink this. The M10 has plenty of dynamic range. There is no need to expose perfectly in 95% of situations, like there was for slide film. Your postprocessing program has an exposure slider.
Having said that, it is really not a matter of having the camera do the thinking for you. It gives you an indication to read the light on the scene and it is up to you to adjust the exposure settings to get the photographic results you are aiming for. If you are unsure, move the camera around and see how the metering changes on various parts. Pick the bit you want to be 18% grey, like a bit of grass, or a brick wall, or some skin, whatever you deem suitable and forget about the exposure. Remember: there is not one perfect exposure, it is a creative tool. What is right for one photograph (and photographer) is wrong for the next. Start visualizing the way you want the photograph that you are taking to look, and aim for that result.
Forget about ETTR, with the noise performance of present-day cameras, the concept is obsolete. Remove that EVF and put it in your camera bag, only use it when you really need it (and for fixing exposure you can just as well use the LCD).
You have the camera that gets the most out of the way between you and the subject of all, giving you the most direct photographic experience possible. You are creating a technological  barrier between yourself and and your subject.
10 hours ago, MikeMyers said:
Mostly because of what you wrote, when I really care about exposure, I am shooting in (M)anual mode.  Based on what the meter reads, I may or may not adjust the exposure - if I'm standing on a freshly paved asphalt parking lot, or on a sandy white beach, with identical lighting, it's very likely that the proper exposure will not change, but the meter readings will.  .....and even though the camera is in (M)anual mode, the red arrows and the circle guide me somewhat.  With the Visoflex I enjoy using the histogram.  I found your drawing very useful, but I'm also looking for small bright lights that I've read will confuse things.
I'm sure you're right, I am, but before I simplify things in my mind, I think I need to understand all these things.  Eventually, metering will get simpler - I hope!
That's what I'm trying to learn to do now.  First step was to lock the camera into (M)anual mode, and use the indicators and/or the histogram as a guide.
Well, not for me.  I capture all my images as DNG, and process in DxO PhotoLab4.  I post images continually in the PhotoLab4 forum, and get feedback and corrections from others in the forum.  They are extremely picky about this, and they expect me to be as careful as they are.  Until I learned to use the Leica meter properly, with the Visoflex as a guide, they were constantly telling me that I got the exposure "wrong".  Only when I started to use the Visoflex, and pay attention to clipped areas in my image, and the histogram, did they finally tell me I was getting the exposures right.  ...which is why for "landscape" photos, my Visoflex is a standard part of how I use my M10.  I'm sure others here will disagree, that I might as well be using a DSLR, and in fact, everyone in this forum thinks I'm doing myself a dis-service by using the Leica which lacks that fine control.  As for me, I've enjoyed shooting with a Leica since I was a kid, and it fits me like a glove, and while I have lots of Nikon gear, it doesn't get used so much anymore.  Now there's the new mirrorless Z9 coming out, but I'm far more interested in the Leica M11.
Doing that now, while realizing how much I can adjust in post processing with PL4 when/if needed.
I dunno - I'm getting spoiled by the GPS, and the more precise focusing, and in daylight the LCD isn't very useful for me and my vision.  I prefer looking "into" something, and there are lots of times where I don't worry about this if I'm trying to be precise, the Visoflex is quite handy.  I never used to carry it with me, and when I get home, I'll probably put it away, but I can't deny that I feel it is quite helpful for me, both for focus, and exposure, and most certainly with my 135mm f/4 Tele-Elmar, where it nails the focus more easily than I can do with the rangefinder....
12 hours ago, Michael Geschlecht said:
Metering is not that hard to do. Which model of Nikon did you use & what type of metering did it have?
Started with Nikon SP, along with S3, then the F, F2, F2 photomic, D2h, D2x, D3, and D750 which is now my "main" DSLR, except I enjoy my new Df more.  My newer Nikons have spot or center weighted metering, or "averaging" for the full image.  Pick one of the three.  I used to use averaging the most, but then started using center weighted.
As to metering, if I don't do it perfectly, the people in the DxO PhotoLab forum complain.  I feel the newer DSLR cameras do it better, with more choices, than my M10, but with care, I think I can now use the M10 (with Visoflex) just as well.  The benefits, charm, simplicity, and "feel" of a Leica, combined with smaller and lighter, continue to keep the Leica as my number one choice.
(I think the new Nikon Z9 will outperform all the above, but with a huge increase in size, weight, cost, and value.  By comparison, the Leica cameras are the least expensive of the lot - my M10 is now on sale, used, at B&H for only a few hundred $$ less than I paid for mine.  By contrast, my big Nikon cameras cost me $4k to $5k, and are essentially worthless now....)
Edited by MikeMyers
In my hypothetical situation, the sky would be identical.  For the Leica, I suspect the change in metering would be huge, because of the brightness of the asphalt vs white sand.  Spot metering would be preferable, but without the Visoflex, the M10 only does "center weighted".
I think you misunderstood (I probably didn't explain clearly enough). I don't meter anything. I use the Sunny 16 rule. I take a look at the sky, and then set everything manually, without taking into account the camera's metering.
So what would you spot meter in that situation to get a correct exposure?  That is the underlying question.  You could meter the white wall then the asphalt and average the readings… Or you can meter the wall and open 4 stops to get it to white (back to the zone system) in the exposure.
Or much more simple and works anyplace on a sunny day on earth: sunny 16 rule.  f/16, shutter speed is 1/film ISO.  So ISO 200, f/16, 1/200.  From this you can dial +/- EVs to get DOF control or motion control as needed.
Just go shoot sunny 16, or some other manual setting method.  You’ll be surprised at how well it works. :)
Edited by KFo
So, with that huge area of "black" or "white" at the bottom, you would use the same exposure for both images, under those conditions?
17 hours ago, blackpaint-R said:
Boy. And I came to Leica to get away from the EVF…
I understand - do you have or use a Tele-Elmar f/4 135mm lens?
I tried using the rangefinder, shooting some animals where I wanted to focus on their eyes.  I got much better results with the Visoflex.  Now I'm spoiled - maybe the M11 will have a built-in GPS, something else I've gotten to like.  I also like the "focus assist" tools on my M10, but using "live view" when it's bright and sunny outside is difficult for me.  There are some things better done on a non-rangefinder camera, and the Visoflex fixes that.
Yes.  I do it all the time.  Bright sunny day, at the same time deep shadows, equivalent to the asphalt - white wall scenario.
Here’s the deal: we are talking about incident light, light that is shinning on an object, rather than the light reflected by an object when we use the sunny 16 rule.  Remember, we aren’t “metering” anything when applying sunny 16.
Thats why the sunny 16 works, it is based on incident light from the sun which is consistent.  Give it a try. :)
Edited by KFo
I used to use it all the time, until I got exposure meters.  I suspect that the M10 with meter will give me results matching Sunny 16.  It just feels "silly" for me to use Sunny-16 when I have that meter built-in, and I should add that between the exposure indicators on the M10, and the histogram on the Visoflex, I have been very pleased with my results.  (I still need to read the article on histograms that was posted up above.)
Sunny-16 is better than nothing, but I think the brightness of the scene is going to be important for selecting my exposure, and the meter in the Leica should take that into account......
I know!
If you’re satisfied then don’t change a thing.  For me, I came back around to a manual setup because I didn’t care for the results from the meter anymore; it required a lot of intervention to get what I want.  I also zone focus a lot as well.  You could say that I treat my Leica/lens combo like a $10,000 point and shot much of the time.  But it gets the results I want!
Well, for me, I got tired of too many different suggestions, and I saw where @jaapvuses (M)anual mode, and that was mostly the end of my internal debates.  Set ISO to something I feel is appropriate, set a shutter speed that I feel is appropriate, and vary the lens opening unless I have a good reason to want more or less depth of field.  I'm getting spoiled with the Visoflex though.
Plan B, when things are changing too quickly for me to keep up, is to set the ISO, set one of the automated modes, and pay attention to the green arrows and the green dot.
I read that long story about how to use a histogram, and found it very useful.
I'm not sure how to respond to this the M10 may have a rather crude system to set the exposure, but it does usually seem reliable, if I interpret the information correctly.  I must be doing something right though, as my images usually come out pretty well, even images that seem impossible to measure...
You don’t need the Visoflex to view a histogram; that can be done after the shot using the rear screen. That way you can stick to the RF experience, practice your metering/exposure and, if needed, check your results.  Over time you should no longer need to inspect under most lighting conditions.  That’s the learning benefit of immediate digital playback… don’t need to wait for film processing/printing.
Jeff
Most of the time I would agree with you, but that rear screen isn't all that handy when I'm in bright sunlight, not to mention I focus my 135 f/4 Tele Elmar much more accurately with the Visoflex.  That kind of photography probably isn't really part of the "rangefinder experience".
I'm the kind of person who wants to see if it's possible to do everything with an M10.  Last night I was photographing the trail left behind by a rocket launch in Florida, and before going back inside I wanted to shoot the Milky Way.  I haven't edited the images yet, but I'm very pleased with my camera.  For the past ten days, I've been doing everything with the M10, 35, 50, and 135, using the rangefinder or the Visoflex depending on what I was shooting.  Camera was set to Manual following @jaapvand his suggestions, and the exposure was usually selected by adjusting the aperture, and if needed, the shutter speed, and again if needed, the ISO.
Anyway, once I set the camera to Manual mode a week ago, it has stayed there.  By following all the suggestions, I've found exposures that more technical people later told me were "spot on", thanks a LOT to the image @jaapvposted of the meter coverage.  And to simplify things, I set the metering to "center weighted" and left it there.
One last thing - I don't like the idea of setting the exposure after reviewing the shot on the rear screen.  I want to get it as close as possible before I take my one shot (maybe a second for insurance, just in case).
I strongly believe that for my needs, the Leica is the best camera there is most of the time.  Definitely not always.  My fall-back cameras are my two Nikons, D750 and Df, but I didn't bring any Nikon gear with me on the trip I just returned from today.  I figured I'd either learn the Leica inside out, or come home hating it.  (....and it was huge help to read responses here, regardless of whether or not I agreed with them for my own photography.)
22 hours ago, jaapv said:
Nothing wrong there. In general, with sunsets, measure the sky next to the sun.
While I did follow all the advice, both here and in the DxO Forums, I don't know if I was "good" or if I was "lucky".  Had I tried to follow your advice of measuring the sky next to the sun, how would I be able to do that with the M10?  I guess with the Visoflex, I could select spot meter function, which I mostly stopped using because of your earlier comments.  How do you do it?
Jeff
Quite right. It is indeed a learning curve and experience will make exposing a second nature.
