Freezing and dark line on M10-P
Posted (edited)
Dear all,
I bought the "reporter edition" of M10-P about 5 months ago. And it constantly has freezing issue. For the past few weeks, it's just been way too often, like 1 out 2 days it would freeze. I always turn the EV on when I'm shooting, and before it's about to freeze, the EV looks like it's having dropped frames, pretty lagging and then it would freeze, so I have to take the battery out and restart the camera. And many times it just freezes after I turn the camera on, I don't even get to press the shutter.
Yesterday, I went out shooting and it froze again, but this time, after I restarted the camera like I always did, I found that the screen got a dark horizontal line on the very top of it (please view the photo I uploaded). I checked the photos, it's usually without the line on them, unless the ISO is 4000 or higher, then I got part of the line (or banding?) on the left side.
Is this normal? Should I send the camera in for a replacement of the CMOS or something?
Edited by clngood
9 hours ago, clngood said:
Dear all,
By "EV", I mean "LV", sorry about the confusion.
5 hours ago, frame-it said:
and what happens without the EVF?
I actually haven't done that, because it's faster to do quick shot on the street with EV, instead of OVF. Have you had the same freezing and line issues on your camera too?
Posted (edited)
Try with solely OVF.
Try with another -in the camera formatted- card.
Eliminate first all possible causes before sending it in.
Edited by Gobert
If the freezing doesn't occur with only OVF, does that mean the sensor is good or shoud I have it replaced?
51 minutes ago, Klassika said:
It looks like a sensor issue, but not for sure.  Try at first a totally different card from a different brand, sometimes this helps a lot. And try this with and whithout the EVF.
The freezing happened before with a different brand of SD card, but the line issue is new.
I’m just saying: eliminate possible causes before thinking about sensor.
My M10R  was sent back for exactly the same thing!  One fellow on the forum told me to download SDCard.org, format my card, return it to the camera, format in camera and shoot- that worked for the first 50 shots, then it shut down again- so I sent it to the great folks in New Jersey- I've sent cameras to  them in the past and have total confidence in them!!
Love the M10R and look for it to function as it should!
Loading...
    No registered users viewing this page.
  • Similar Content
    • By clngood
      Hi guys, so I had my "reporter edition" of M10-P sent in, which had freezing issue, and Leica replaced the old CMOS with a whole new one. So far, no freezing, however, I run into 2 new "issues" if they really are.
      1st one: Sometimes when I press the "Play" button to view the photos, a brief "loading" appears on the screen for like less than 1 second. I didn't do that right after pressing the shutter, even when I was in the menu screen, and that happened, but not very often.
      2nd one: Sometimes when I press buttons (like Play or Menu), and there is no response, so I had to press them again, and this is not very often either.
      I don't remember that I ever had those 2 issues before I sent my M10-P in. I wonder if it has something to do with the very low battery? Have you guys encountered same things on your M10 or M10-P? Are they really issues?
    • By Rick in CO
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By Antoinevdlb
      This loud noise appeared suddenly. I'm not sure if it has affected any other part of the camera, but I do feel like autofocus isn't working as well anymore...
      I've heard OIS can make sound it is normal, but this sound is NOT the same as the when i first camera. Originally it sounded crisp, now it was a gear grinding feel to it that seems.... Off...
      I've reseted the camera multiple times... Any insight on what to do?
      Camera is 2 week old.
      PXL_20211113_201644359.mp4
    • By Al Brown
      Do you use a half case? Show us the images of your beauties! What are in your opinion the benefits? What is the best half case out there? Curious and eager to see!
    • By Bornosor
      Hi
      i’ve just got my first digital Leica, an M10R.
      coming from a canon background im used to connecting my camera directly to my mac and having the eos utility automatically download and organize my photos into different folders sorted by date,
      Obviously thats not the case with the Leica and i have to connect the sd card to my mac in which all the photos are stores in one folder that i have to manually create date stamped folders for on my hard drive.
      is there any way (in camera or through an app) that i can do something similar to the canon eos utility with the leica sd card and automatically import all the photos on it into date stamped folders?
