LUF Admin Posted September 22, 2021 Share #1 Posted September 22, 2021 Advertisement (gone after registration) Leica has introduced the new firmware V 3.0 for the Leica SL2. The improvements in detail: New Autofocus algorithm Improved eye/face/head/body recognition and focus tracking. HEVC video compression Internal 4K recording with 10 Bit at 60p/50p with h.265 codec. Long-GOP Recording for 10 Bit codecs with 150 – 200 MB/s means same Image Quality as All-Intra but less than half of data size. Segmented Video Videorecording will be split 1 minute segments to avoid data loss. Individual Viewing LUT Upload function for individual Look Up Tables. Enhanced Live View Better low light image composition control of the Live View image. Image Overlay Allows alignment of the camera position on basis of a previous taken image, that is displayed in a transparent mode in the EVF or on the LCD. Automatic Follow Focus Definition of three focus points for automatic focus shift during video recording. FN Buttons are now possible to use. Focus adjustment in video and live view additionally to predefined sequence. Wave form monitor Professional exposure valuation of the video signal. Color bar Reference for correct color grading and sound control in postproduction. Record indication Frame (Tally Mode) Camera shows red frame on LCD during video recording. Highlight weighted metering Metering method to save highlights instead of shadows. Dynamic-range control Increase brightness in shadows. Highlight-shadow control Precise contrast adjustment controls. » Download Leica SL2 Firmware 3.0 2 4 Quote Link to post Share on other sites More sharing options...
Advertisement Posted September 22, 2021 Posted September 22, 2021 Hi LUF Admin, Take a look here Leica SL2 Firmware 3.0 officially released. I'm sure you'll find what you were looking for!
Photoworks Posted September 22, 2021 Share #2 Posted September 22, 2021 The firmware update also includes updates for the Leica Vario-Elmarit–SL 24–90 mm f/2.8–4 ASPH. and the Leica APO-Vario-Elmarit-SL 90–280 mm f/2.8-4. lenses. Quote Link to post Share on other sites More sharing options...
Photoworks Posted September 22, 2021 Share #3 Posted September 22, 2021 FLASH! Working again in 3.0 Leica has updated the flash BUG on the SL2, it is frustrating that it took so long, now you can shoot with flash even if you have a bright window or sky behind the subject. Just mentioning it since it was not in Leica notes. 2 1 Quote Link to post Share on other sites More sharing options...
LBJ2 Posted September 22, 2021 Share #4 Posted September 22, 2021 32 minutes ago, Photoworks said: The firmware update also includes updates for the Leica Vario-Elmarit–SL 24–90 mm f/2.8–4 ASPH. and the Leica APO-Vario-Elmarit-SL 90–280 mm f/2.8-4. lenses. Same for the SL 50/2 to v 2.1 Checking my other primes now. * I mounted the lens to the updated SL2 v 3.0 and the lens firmware updated to v2.1 1 Quote Link to post Share on other sites More sharing options...
sillbeers15 Posted September 22, 2021 Share #5 Posted September 22, 2021 28 minutes ago, Photoworks said: FLASH! Working again in 3.0 Leica has updated the flash BUG on the SL2, it is frustrating that it took so long, now you can shoot with flash even if you have a bright window or sky behind the subject. Just mentioning it since it was not in Leica notes. Can the Manual Flash Mode work in HSS with SFC-1 to SF60s & MG10 now after the Firmware 3.0 installed? Quote Link to post Share on other sites More sharing options...
Photoworks Posted September 22, 2021 Share #6 Posted September 22, 2021 6 minutes ago, sillbeers15 said: Can the Manual Flash Mode work in HSS with SFC-1 to SF60s & MG10 now after the Firmware 3.0 installed? in TTL only, same as before. 1 Quote Link to post Share on other sites More sharing options...
Photoworks Posted September 22, 2021 Share #7 Posted September 22, 2021 Advertisement (gone after registration) FOTOS APP shooting mode is still SINGLE SHOT only in remote shooting. You can change it back to something else in camera after you connect. But don't Play a photo, It will reset to single shot.. 💩 Quote Link to post Share on other sites More sharing options...
JT07 Posted September 22, 2021 Share #8 Posted September 22, 2021 I may be missing something and hope its ok to ask here but i often struggle trying to keep the focus point dead center in the frame. I must be doing something wrong which makes it move and I’m missing shots. Is there a way to “lock it” dead center if desired? Thank you< JT 1 Quote Link to post Share on other sites More sharing options...
Photoworks Posted September 22, 2021 Share #9 Posted September 22, 2021 Just now, JT07 said: I may be missing something and hope its ok to ask here but i often struggle trying to keep the focus point dead center in the frame. I must be doing something wrong which makes it move and I’m missing shots. Is there a way to “lock it” dead center if desired? Thank you< JT SAME here. that is one option I like to see implemented in all leica cameras. Like you I use Spot or Field and the AF point moves to one corner.. Just give us a center lock Quote Link to post Share on other sites More sharing options...
Virob Posted September 22, 2021 Share #10 Posted September 22, 2021 Do you have touch autofocus on while having you eye at the viewfinder? If your nose touches the screen it will shift your autofocus point. 1 Quote Link to post Share on other sites More sharing options...
michali Posted September 22, 2021 Share #11 Posted September 22, 2021 27 minutes ago, JT07 said: I may be missing something and hope its ok to ask here but i often struggle trying to keep the focus point dead center in the frame. I must be doing something wrong which makes it move and I’m missing shots. Is there a way to “lock it” dead center if desired? Thank you< JT 23 minutes ago, Photoworks said: SAME here. that is one option I like to see implemented in all leica cameras. Like you I use Spot or Field and the AF point moves to one corner.. Just give us a center lock +1 it's extremely irritating. What Virob said, disable" touch autofocus" and then the focus point only moves with the joystick. There should however still be a shortcut to recentre the focus point e.g. by pressing the joystick. 1 1 Quote Link to post Share on other sites More sharing options...
chris_tribble Posted September 22, 2021 Share #12 Posted September 22, 2021 1 hour ago, LBJ2 said: Same for the SL 50/2 to v 2.1 Checking my other primes now. * I mounted the lens to the updated SL2 v 3.0 and the lens firmware updated to v2.1 This update was available earlier. Quote Link to post Share on other sites More sharing options...
chris_tribble Posted September 22, 2021 Share #13 Posted September 22, 2021 10 minutes ago, michali said: +1 it's extremely irritating. What Virob said, disable" touch autofocus" and then the focus point only moves with the joystick. There should however still be a shortcut to recentre the focus point e.g. by pressing the joystick. Agreed - I now have a profile that has the focus point locked as a default with a button programmed for lock on / off. Works fine for me after a bit of learning. 2 Quote Link to post Share on other sites More sharing options...
RBB Posted September 22, 2021 Share #14 Posted September 22, 2021 1 hour ago, LUF Admin said: Leica has introduced the new firmware V 3.0 for the Leica SL2. YES finally Quote Link to post Share on other sites More sharing options...
Ralf Posted September 22, 2021 Share #15 Posted September 22, 2021 I am very disappointed that the issue of battery performance has not been addressed, hard to understand! Quote Link to post Share on other sites More sharing options...
RBB Posted September 22, 2021 Share #16 Posted September 22, 2021 1 minute ago, Ralf said: I am very disappointed that the issue of battery performance has not been addressed, hard to understand! Did you already test with Panasonic and Sigma? Quote Link to post Share on other sites More sharing options...
Stuart Richardson Posted September 22, 2021 Share #17 Posted September 22, 2021 (edited) Any idea if it still has the warning that takes up the entire screen if you try to move the camera in multishot mode? Seemed like that annoyed a lot of people (myself included) and was mentioned on the requested features thread. It makes it very hard to compose without completely exiting multishot mode. Edited September 22, 2021 by Stuart Richardson 1 Quote Link to post Share on other sites More sharing options...
Ralf Posted September 22, 2021 Share #18 Posted September 22, 2021 vor 1 Minute schrieb RBB: Did you already test with Panasonic and Sigma? I looked at the above list of improvements, what exactly do you mean? Quote Link to post Share on other sites More sharing options...
SrMi Posted September 22, 2021 Share #19 Posted September 22, 2021 (edited) 2 hours ago, Ralf said: I looked at the above list of improvements, what exactly do you mean? <deleted> Edited September 22, 2021 by SrMi 1 Quote Link to post Share on other sites More sharing options...
Andrew Gough Posted September 22, 2021 Share #20 Posted September 22, 2021 20 minutes ago, michali said: +1 it's extremely irritating. What Virob said, disable" touch autofocus" and then the focus point only moves with the joystick. There should however still be a shortcut to recentre the focus point e.g. by pressing the joystick. I use single point tracking, and it does recenter. Might help. 1 Quote Link to post Share on other sites More sharing options...
