thetankengine Posted July 29, 2021 Share #1 Posted July 29, 2021 Advertisement (gone after registration) Seeing the Leica R-to-L is ridiculously expensive, I'm wondering if anyone has tried to use the R-to-M and M-to-L adapters together in order to mount a R lens on the SL/SL2? If you have tried it, could you please let me now if the R lens info will be recognised by the camera? I was thinking bout getting a Novolex one for R-to-L, but it doesn't pass any lens info to the camera body, so the inconvenience of the need to manually select the lens every time when taking my shots put me off. I've already got a M-to-L adapter, and seeing the R-to-M adapter is not overly expensive, I'm wondering if the combination of the two adapters would work? Quote Link to post Share on other sites More sharing options...
Advertisement Posted July 29, 2021 Posted July 29, 2021 Hi thetankengine, Take a look here R-to-M + M-to-L adapters for R lenses?. I'm sure you'll find what you were looking for!
Photoworks Posted July 29, 2021 Share #2 Posted July 29, 2021 it will not make a difference the M adapter does not have any electronic and will not transmit any information. Unless you have R lenses hit ROM there is no benefit in using the R-L leica adapter. unless you like how well it is built . Quote Link to post Share on other sites More sharing options...
lawman Posted July 30, 2021 Share #3 Posted July 30, 2021 My R lenses are not ROM so I use the Novoflex and it works very well. Quote Link to post Share on other sites More sharing options...
michali Posted July 30, 2021 Share #4 Posted July 30, 2021 As mentioned by Photoworks above, it won't make a difference. I use the following adapter Haoge Manual Lens Mount Adapter for Leica R Lens to Leica L Mount all of $30- it's well made & a good fit. 2 Quote Link to post Share on other sites More sharing options...
ardbeg Posted July 31, 2021 Share #5 Posted July 31, 2021 (edited) I regularly stack the two “dumb” Leica adapters. They work fine but as stated by others - no data passing. On very long R lenses (e.g. 400 and 560 Telyts), there can be some vignetting from the stack versus a single adapter likely due to narrowness of the M mount transition. Edited July 31, 2021 by ardbeg Quote Link to post Share on other sites More sharing options...
caissa Posted August 1, 2021 Share #6 Posted August 1, 2021 (edited) I use the stack since several years. No problems. I simply do not have the money to buy the single adapter. It works with the R 350. The 400 and 560 are not really good lenses anyway. Ok, but not more. Not necessary/worth to worry about them. I also have a cheap dumb L-R adapter, but I find the stack better. Edited August 1, 2021 by caissa Quote Link to post Share on other sites More sharing options...
Rodrigo castillo Posted August 1, 2021 Share #7 Posted August 1, 2021 Advertisement (gone after registration) I use the official M to L adapter that allow to pass information of coded M and allows magnification with the top dial, and a cheap R to M when I use R lenses in my CL, the only difference is the EXIF information, all the rest the same that with the M lenses. Quote Link to post Share on other sites More sharing options...
