50mm Summicron query
Punkrockemo
 Share
I have an older version of the 50mm (Version 4  I think-See picture) that i have had for a while. There a couple of things i am not sure about.
  1. When focusing I find that for subjects up to 2m it back focus's slightly unless I compensate for it. For subjects further away it focus just fine. Aperture does not seem to affect it.
  2. I seem to be able to unscrew the front section of lens (In front of focus lever/barrel)- is that normal?
I assume the lens may need servicing. I am not sure where to go to get that done. I live in the UK
6 minutes ago, Punkrockemo said:
Thank you both. I have found a couple of places I can contact in the collector-Historica forum as suggested.
Does anyone have opinion on if the issue I expereinced is common
Second issue is not common. In relation to back focus, is this your only lens that does this?  If so, lens needs adjustment, but if your sole lens may be camera rangefinder needs/also needs adjustment. FWIW
Loading...
 Share
