Nachapon Dumrongthumavoot Posted June 8, 2021 Share #1 Posted June 8, 2021 Advertisement (gone after registration) Hello everyone, I have notice that my S3 give wrong battery percentage reading. On one battery it show 100% for all the time but when i took it out and put it on the charger, it says it has about 20%-40% left. On the other hand, the other battery accurately show it has 20% which is the same when i put it on the charger. Is anyone have encounter this problem and if so are there any solution for the problem? I read that sometime you need to empty the battery and fully charged it to recalibrate the reading and i will try doing that first. Quote Link to post Share on other sites More sharing options...
Advertisement Posted June 8, 2021 Posted June 8, 2021 Hi Nachapon Dumrongthumavoot, Take a look here S3 : wrong battery information. I'm sure you'll find what you were looking for!
otto.f Posted June 8, 2021 Share #2 Posted June 8, 2021 (edited) I don’t know anything about S camera’s. But what I see with my M9 and my Monochrome1 - of more than 10 years old - that if I do not use them for a few weeks and leave the batteries in the camera, I get misinformation about their remaining capacity. It says it’s full but it dies after three takes. This may have occurred when they were new too, I can’t check that because I used them much more at that time than now. Edited June 8, 2021 by otto.f 1 Quote Link to post Share on other sites More sharing options...
Nachapon Dumrongthumavoot Posted June 8, 2021 Author Share #3 Posted June 8, 2021 I see, my M9 also exhibit the same problem as well. I also left my S3 and battery inside for quite several weeks due to work as well. I guess that is also part of the problem. Thank you very much for your input. 1 Quote Link to post Share on other sites More sharing options...
sincurves Posted June 8, 2021 Share #4 Posted June 8, 2021 6 hours ago, Nachapon Dumrongthumavoot said: Hello everyone, I have notice that my S3 give wrong battery percentage reading. On one battery it show 100% for all the time but when i took it out and put it on the charger, it says it has about 20%-40% left. On the other hand, the other battery accurately show it has 20% which is the same when i put it on the charger. Is anyone have encounter this problem and if so are there any solution for the problem? I read that sometime you need to empty the battery and fully charged it to recalibrate the reading and i will try doing that first. Mine showed 50% in camera, but almost 0% in charger. Charger was correct. I have emailed Leica Customer Care weeks ago - no response. Quote Link to post Share on other sites More sharing options...
mgrayson3 Posted August 6, 2021 Share #5 Posted August 6, 2021 (edited) I have the same problem. Anyone find a fix or workaround? Removing and replacing the battery doesn't help. Edited August 6, 2021 by mgrayson3 Quote Link to post Share on other sites More sharing options...
sincurves Posted August 6, 2021 Share #6 Posted August 6, 2021 Leica thought it could be an issue with the battery and recommended a full discharge followed by a 100% charge to re-calibrate the capacity counter in the battery. I haven’t experienced any issues with my S3 since. 1 Quote Link to post Share on other sites More sharing options...
helged Posted August 6, 2021 Share #7 Posted August 6, 2021 Advertisement (gone after registration) 52 minutes ago, sincurves said: Leica thought it could be an issue with the battery and recommended a full discharge followed by a 100% charge to re-calibrate the capacity counter in the battery. I haven’t experienced any issues with my S3 since. No battery issues in my case (with S3), using 3 new and 2 older batteries. And yes, my batteries get fully discharged now and then, always followed by full (100%) charging. Quote Link to post Share on other sites More sharing options...
mgrayson3 Posted August 6, 2021 Share #8 Posted August 6, 2021 I was just told (Steve Hendrix at Capture Integration) that you can reset the battery (whatever that means) by plugging it into the quick charger first and then plugging the charger into the AC. I'm doing that with all of my batteries now. I'll let you know if that helps. 2 Quote Link to post Share on other sites More sharing options...
mgrayson3 Posted August 11, 2021 Share #9 Posted August 11, 2021 Update: Leica says it's a known issue to be fixed in a future firmware update. 2 Quote Link to post Share on other sites More sharing options...
