arshots Posted May 20, 2021 Share #1 Posted May 20, 2021 (edited) Advertisement (gone after registration) I just recently purchase the SL2-S with Sigma MC-21 mount converter and I noticed a few things that I wanted to put out just in case someone was attempting the same thing I am. I am a full Canon shooter and wanted to try the SL2-S at sports instead of just portraits so I purchased it. My DG Sigma Art Line 35mm works perfect with the SL2-S and the menu option of Image Stabilization is selectable. I can toggle it on and off with the Sigma lens, but when I attach my Canon 70-200 f2.8 III and also my Canon 400mm f2.8 III, that same menu selection is greyed out and NOT selectable. I also noticed that on the EF 400MM f2.8, it only goes down to f3.2 using the sigma adapter. BUT, when I attached the 70-200mm f2.8 , it stays at f2.8. So I don't know why it changes from the 200 to the 400. Going to test it today covering a two big baseball games to see how it operates. Edited May 20, 2021 by arshots Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 20, 2021 Posted May 20, 2021 Hi arshots, Take a look here SL2-S w/Sigma MC-21 mount using Canon EF lenses - *issues with image stabilization menu option*. I'm sure you'll find what you were looking for!
ocean2059 Posted May 20, 2021 Share #2 Posted May 20, 2021 6 minutes ago, arshots said: I just recently purchase the SL2-S with Sigma MC-21 mount converter and I noticed a few things that I wanted to put out just in case someone was attempting the same thing I am. I am a full Canon shooter and wanted to try the SL2-S at sports instead of just portraits so I purchased it. My DG Sigma Art Line 35mm works perfect with the SL2-S and the menu option of Image Stabilization is selectable. I can toggle it on and off with the Sigma lens, but when I attach my Canon 70-200 f2.8 III and also my Canon 400mm f2.8 III, that same menu selection is greyed out and NOT selectable. I also noticed that on the EF 400MM f2.8, it only goes down to f3.2 using the sigma adapter. BUT, when I attached the 70-200mm f2.8 , it stays at f2.8. So I don't know why it changes from the 200 to the 400. Going to test it today covering a two big baseball games to see how it operates. You may want to post this in the Leica L-Mount. Quote Link to post Share on other sites More sharing options...
BernardC Posted May 20, 2021 Share #3 Posted May 20, 2021 As Ocean2059 mentions, this is the S forum, you will want to post on the L-Mount forum. That being said, I think that stabilization is controlled by the button on the lens in this case, which is why the menu entry is greyed-out. Leica doesn't support dual-IS (in-lens and in-body) for adapted lenses, probably because they don't have any control over the lens settings. Quote Link to post Share on other sites More sharing options...
arshots Posted May 20, 2021 Author Share #4 Posted May 20, 2021 1 hour ago, ocean2059 said: You may want to post this in the Leica L-Mount. Crap, got excited when picking the thread category, my fault and thanks for pointing, moving this over, thanks again Quote Link to post Share on other sites More sharing options...
davidmknoble Posted July 16, 2021 Share #5 Posted July 16, 2021 @arshots, I would also look at the adapter for issues, it has to send information to the SL2-S and it may not be sending all the right information? If you can find another adapter brand / type, it might work differently? Quote Link to post Share on other sites More sharing options...
