Happened to me with my SLX 35 ASPH. I tightened it back and it never happened again. As a consequence I unscrew filters only by grabbing the filter between two fingers at one point of its edge.
Edited by happymac
Yeah, I will approach the filter in the same way. I know sometimes with these wide angles, the elements are all 1 self contained unit and just unscrew from the focusing body... wasnt sure if Leica took the same approach and this was to be expected of the lens.
52 minutes ago, spacecad3t said:
I was recently gifted a late generation, E60 21mm/2.8 pre-ASPH.
While removing the lens filter, the entire lens group started to unscrew. Normal?
I gently tightened back and tested on my Sony, seems to work perfectly fine.
I would say, most unusual. But I guess you know little about its past life. If it works now, why worry. It was a gift and a very generous gift too.
That is the correct way to remove a filter! You can put a tiny dab of anti seize on the threads, but that can get messy if you're not careful.
Joel
Definitely an occasional "feature" of the whole set of M wide lenses brought out around 1980 by Leitz Canada, (and in some cases made later by Leica Solms) which includes the 21 pre-ASPH.
I have the same 21, and its sister 28 Elmarit v.3. 1980-83 Canadian manufacture. On both of those the aperture ring and index are slightly out of alignment with the focusing index-mark behind them.
The 28 will unscrew if I try really hard (I don't) - the 21's wide front ring seems to have countersunk set-screws at 120° around the outside, so it is misaligned, but can't be moved by finger-pressure alone.
The 35mm Summicron v.4 (at least, and in some sub-versions) is known to have a plastic locking ring inside, that can break and allow its front (half the barrel, all the glass and aperture mechanism) to screw out.
I don't use filters, so have no experience with trying to unscrew an overtightened filter. I do know to never to try and use a mounted lens hood as leverage to unmount the lens from the camera.
vor 4 Stunden schrieb adan:
that's what I did with a SLX 50 last version on a cold day--too lazy to take off the mittens. Off came the whole front element--which is only secured by one tiny screw.... Being in Lapland I secured the front element with sticky tape until I was back home and could send it to CS.
Another effective way to remove a stuck filter is to push it front-on against the rubber sole of a shoe and gently twist.  This imparts the torque evenly around the rim of the filter, which helps it to unscrew.
Pete.
