Arno Ryser Posted February 14, 2021 Share #1 Posted February 14, 2021 Advertisement (gone after registration) Picked up an M4-P recently, apparently CLA'd in 2020. A few frames from every roll so far have had the left 1/3 or so much darker than the rest of the frame to varying degrees (see examples). I have noticed that this happens only when I shoot in the sun at 1/1000s. I even tested it by shooting the same subject at 1/500s and 1/1000s. The 1/500s was fine while the 1/1000s had the issue. Is this a shutter problem, or am i just clumsy and blocking the lens with my fingers? (Don't mind the banding that was a development issue I have since fixed.) Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/318011-leica-m4-p-portion-of-frame-dark/?do=findComment&comment=4141047'>More sharing options...
Advertisement Posted February 14, 2021 Posted February 14, 2021 Hi Arno Ryser, Take a look here Leica M4-P Portion of Frame Dark. I'm sure you'll find what you were looking for!
wattsy Posted February 14, 2021 Share #2 Posted February 14, 2021 (edited) 2 hours ago, Arno Ryser said: Is this a shutter problem, or am i just clumsy and blocking the lens with my fingers? Shutter I'm afraid. The curtains look like they need some adjustment as the slit doesn't appear to be staying open across the frame. At 1/1000, the slit is quite narrow (something like 2mm I think) and therefore most sensitive to anything being slightly out of whack. It's something any competent Leica technician should be able to adjust. Edited February 14, 2021 by wattsy 1 Quote Link to post Share on other sites More sharing options...
mechs Posted February 15, 2021 Share #3 Posted February 15, 2021 Yep, had this happen on another camera I own. Nothing a service can't fix. If money is tight or you just don't have the time to send it in, simply avoid using 1/1000 for the time being. 1 Quote Link to post Share on other sites More sharing options...
giannis Posted February 15, 2021 Share #4 Posted February 15, 2021 On 2/14/2021 at 9:14 PM, Arno Ryser said: Is this a shutter problem Yup, it's called shutter capping. As @wattsy explained, usually happens at the top speeds. Yours looks like a textbook case. It's an easy fix for a repairman in 90% of cases. 1 Quote Link to post Share on other sites More sharing options...
Arno Ryser Posted February 15, 2021 Author Share #5 Posted February 15, 2021 Thanks for the help. I've heard elsewhere that this issue could be magnified by the cold weather causing the lubricants to thicken and shutter curtains to stiffen. I'll have it fixed soon. Quote Link to post Share on other sites More sharing options...
