Recently Browsing 0 members
No registered users viewing this page.
Similar Content
By jivekp@gmail.comHi everyone, I'm a new Leica user and bought an M6 Classic with a Leitz Summicron 2.0. The first roll came back blurry and I thought it was my shooting..then the second and third and so on. I sent my lens in to Keh (where I had gotten it) to be serviced and it came back with the same results. The images are generally overexposed when in very sunny conditions and all of them are very softly focused. I shot most of a roll at f16 and not one thing was in focus. I don't think it could be the lens, as it just came back from being properly adjusted so I'm wondering if it could be the body? I'm not sure what to do as I've spent my budget on this setup. I was going to send it in to get the VF upgrade because I was experiencing some flaring but that is not what is happening here. Any tips very much appreciated.
By dsalinasHello,
I recently purchased a used 28mm Summicron from the Leica Store in Soho. My first Leica lens, so in my excitement I don't really notice a potential issue with the lens. The numbers on the aperture ring don't line up center with the white dot, they fall a little to the left. I don't think this is normal, but is it a problem? Photo attached
Also, there's al little more travel beyond f2 and f16. Not much at all, but it doesn't hard stop at f2 or f16. Is this normal?
Thanks for the help!
IMG_2657.heic
IMG_2657.heic -
By Hans ReklameHallo zusammen!
Ich habe mir das Summicron 35 Asph. Gekauft und besitze das 35 mm Voigtländer Nokton. In meiner Vorstellung benutze ich das Voigtländer weiter, wenn es bewusst um das unperfekte geht, die Sonne im Gegenlicht, nicht ganz scharf etc. .. hat jemand beide Objektive und kann mir sagen, ob eines von beiden eher ein Schubladendasein fristet?
Oder allgemein die Erfahrung über die Nutzung beider Objektive parallel.
liebe Grüße und danke! -
By IanoI have just purchased a pair of goggles for my Summicron 50mm DR. When mounted and the lens set to close focusing range there is significant vertical misalignment of the range finder patch.
Does anyone have any experience of such an issue? Is this something that can be repaired, or should I return the goggles to the seller while I still can?
Any guidance would be greatly appreciated!
By Holger1Verkaufe aus Sammlung ein neuwertiges APO-Summicron-M 2,0/90mm ASPH, E55 (11 884) ohne sichtbare Gebrauchsspuren.
Originalverpackung mit Front-u.Rückdeckel.
Dies ist ein Privatverkauf. I only send within EU
www.HolgerDaberkow.de
