johnbuckley Posted December 3, 2020 Share #1 Posted December 3, 2020 Advertisement (gone after registration) When using the Monochrom-246, I found Auto ISO quite responsive. If I were to increase Exposure Compensation, the ISO would quickly adjust. However, with the M10 Monochrom, the adjustment seems to occur only with really pronounced changes in lighting. Typically, the ISO stays at 160 beyond when I would have expected it to go as high 640. I have used different Auto ISO settings, but settled on 1/focal length. Anybody else notice this? (I find it true on my M10R as well.) Any thoughts on what I should do? if you’re wondering why this matters, I often use Exposure Compensation with Aperture Priority to accentuate areas of comparative light and darkness, but don’t want to have too slow a shutter speed. Put differently, I’d prefer greater sensitivity in Auto ISO to preserve a higher shutter speed even when using Exposure Compensation. Thanks in advance for your thoughts and advice Link to post Share on other sites More sharing options...
Advertisement Posted December 3, 2020 Posted December 3, 2020 Hi johnbuckley, Take a look here Advice Needed on M10 Mono Auto ISO. I'm sure you'll find what you were looking for!
Keith (M) Posted December 3, 2020 Share #2 Posted December 3, 2020 With my M10M set to Auto-ISO and 1/f, I activated live-view, pointed the camera at my monitor then slowly swung it away - the ISO setting changed smoothly in stages from 160 to 640 as light levels changed. 1 Link to post Share on other sites More sharing options...
johnbuckley Posted December 3, 2020 Author Share #3 Posted December 3, 2020 Thanks, Keith. I’ll try that. Link to post Share on other sites More sharing options...
johnbuckley Posted December 3, 2020 Author Share #4 Posted December 3, 2020 Done like that, it absolutely works. I wonder why it’s hanging in real-world situations? Link to post Share on other sites More sharing options...
Jeff S Posted December 4, 2020 Share #5 Posted December 4, 2020 Is your metering pattern set the same in LV as without? Jeff Link to post Share on other sites More sharing options...
Anakronox Posted December 4, 2020 Share #6 Posted December 4, 2020 2 hours ago, Jeff S said: Is your metering pattern set the same in LV as without? Jeff That’s a great point. When using the rangefinder, all you have is center-weighted metering. In live view, I believe it defaults to multi-field (matrix). Link to post Share on other sites More sharing options...
