Radost Posted December 25, 2020 Share #641 Posted December 25, 2020 Advertisement (gone after registration) 2 minutes ago, Steven said: The footage from the sl2s at 400mbps has been editing flawlessly on my Mac. Unlike the 260mbps footage from the a7siii, which was better than the R5. Can you use this : MediaInfo (mediaarea.net) ? Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 25, 2020 Posted December 25, 2020 Hi Radost, Take a look here SL2-S. I'm sure you'll find what you were looking for!
LocalHero1953 Posted December 25, 2020 Share #642 Posted December 25, 2020 23 minutes ago, Radost said: Leica SL2-S announced, Leica’s 24-megapixel, 4K/60p answer to popular full-frame hybrid cameras (imaging-resource.com) That must be an error - it doesn't match the options in the camera nor in the manual Quote Link to post Share on other sites More sharing options...
Steven Posted December 25, 2020 Share #643 Posted December 25, 2020 9 minutes ago, Radost said: Can you use this : MediaInfo (mediaarea.net) ? Here. You owe me 99 cents 😂 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/314370-sl2-s/?do=findComment&comment=4105700'>More sharing options...
BernardC Posted December 25, 2020 Share #644 Posted December 25, 2020 That's H.264 in a Quicktime wrapper, not ProRes. Both are Apple formats, so that's probably why the article confused them. Leica uses very little compression in their MOV H.264, so that's probably why they are easy to edit. Their MP4 files (which are also H.264) use much higher compression. MOV and MP4 are both data wrappers, so there's no inherent reason why one would be more compressed than the other. I guess Leica thought it would make more sense to save the highly-compressed files in MP4 (which can be played directly on most TVs and devices), and the low-compression files in MOV (which most NLEs will understand). 1 1 Quote Link to post Share on other sites More sharing options...
Radost Posted December 25, 2020 Share #645 Posted December 25, 2020 13 minutes ago, Steven said: Here. You owe me 99 cents 😂 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Can you shoot a short clip and share it? Quote Link to post Share on other sites More sharing options...
Radost Posted December 25, 2020 Share #646 Posted December 25, 2020 2 minutes ago, BernardC said: That's H.264 in a Quicktime wrapper, not ProRes. Both are Apple formats, so that's probably why the article confused them. Leica uses very little compression in their MOV H.264, so that's probably why they are easy to edit. Their MP4 files (which are also H.264) use much higher compression. MOV and MP4 are both data wrappers, so there's no inherent reason why one would be more compressed than the other. I guess Leica thought it would make more sense to save the highly-compressed files in MP4 (which can be played directly on most TVs and devices), and the low-compression files in MOV (which most NLEs will understand). Is the leica using the panasonic AVC intra codec that compresses each frame? Quote Link to post Share on other sites More sharing options...
Radost Posted December 25, 2020 Share #647 Posted December 25, 2020 Advertisement (gone after registration) 20 minutes ago, Steven said: Here. You owe me 99 cents 😂 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! It should be L5.2 Quote Link to post Share on other sites More sharing options...
Slender Posted December 25, 2020 Share #648 Posted December 25, 2020 (edited) 4 hours ago, Steven said: Are there any added tools that let you nail focus faster, or you just mean the bigger and brighter screen ? The focus peaking is a bit easier to see during takes/movement. Dont get me wrong it works fine in the wonderful EVF, too. Hover, just like grain, it does diminish when you hit record, on SL2 at least. I had a blast maual focussing for video since the Linear update on my 24-90... reminds me on my days with the Leica R7 and R8. Except its easier Crazy to think I learned with slide film iso50 or 400 and now I feel "bad" because my 47mp camera doesnt perform as good as the 24mp one at 6400iso 🤪 Edited December 25, 2020 by Slender 1 Quote Link to post Share on other sites More sharing options...
BernardC Posted December 25, 2020 Share #649 Posted December 25, 2020 2 hours ago, Radost said: Is the leica using the panasonic AVC intra codec that compresses each frame? You get quite a choice. The specifications mention ALL-I (intra-frame) for 400 Mbps, and Long GOP (inter-frame) for 150 Mbps and lower. Those specs are a nightmare to read. Here is what I can make out of them: In MOV (Quicktime), 10-Bit, 4:2:2, you can record "C4K" (4096x2160, a.k.a. DCI 4K) at 24, 25, or 29.97 fps. Or you can record "4K" (3840x2160, a.k.a. UHD) at 23.98, 25 and 29.97 fps. 59.94 fps internal is always 8-Bit 4:2:0 Long-GOP. Notice that C4K records at 24 fps, whereas 4K UHD records at 23.98 (which is the North American colour television frame rate). You may run into issues if you use both in the same project, although editing software is better than it used to be at fixing that. MP4 is always Long-GOP and 4:2:0 8-Bit. External recorders can record ALL-I 4:2:2 10-Bit (in ProRes or DNxHR), so that's your option if you want to shoot 59.94 fps in 10-Bit HDR. 2 Quote Link to post Share on other sites More sharing options...
Steven Posted December 25, 2020 Share #650 Posted December 25, 2020 3 hours ago, Radost said: Can you shoot a short clip and share it? Sure. Any preference on what I shoot ? Quote Link to post Share on other sites More sharing options...
Radost Posted December 25, 2020 Share #651 Posted December 25, 2020 1 hour ago, BernardC said: You get quite a choice. The specifications mention ALL-I (intra-frame) for 400 Mbps, and Long GOP (inter-frame) for 150 Mbps and lower. Those specs are a nightmare to read. Here is what I can make out of them: In MOV (Quicktime), 10-Bit, 4:2:2, you can record "C4K" (4096x2160, a.k.a. DCI 4K) at 24, 25, or 29.97 fps. Or you can record "4K" (3840x2160, a.k.a. UHD) at 23.98, 25 and 29.97 fps. 59.94 fps internal is always 8-Bit 4:2:0 Long-GOP. Notice that C4K records at 24 fps, whereas 4K UHD records at 23.98 (which is the North American colour television frame rate). You may run into issues if you use both in the same project, although editing software is better than it used to be at fixing that. MP4 is always Long-GOP and 4:2:0 8-Bit. External recorders can record ALL-I 4:2:2 10-Bit (in ProRes or DNxHR), so that's your option if you want to shoot 59.94 fps in 10-Bit HDR. I was hoping for internal prores. Quote Link to post Share on other sites More sharing options...
Radost Posted December 25, 2020 Share #652 Posted December 25, 2020 (edited) 39 minutes ago, Steven said: Sure. Any preference on what I shoot ? shoot dci or 4k 23.976 something with detail and differences in light. Also 1080p 180 frames Edited December 25, 2020 by Radost Quote Link to post Share on other sites More sharing options...
Svetozar Posted December 26, 2020 Share #653 Posted December 26, 2020 (edited) 2 hours ago, BernardC said: 59.94 fps internal is always 8-Bit 4:2:0 Long-GOP. @BernardC This what are you saying is true for now. But when they release the firmware update it will be a different story, 4K 10Bit 60p/50p with internal recording will be included. New Autofocus algorithm Improved eye/face/head/body recognition and focus tracking. HEVC video compression Internal 4K recording with 10 Bit at 60p/50p with h.265 codec. Long-GOP Recording for 10 Bit codecs with 150 – 200 MB/s means same Image Quality as All-Intra but less than half of data size. Segmented Video Videorecording will be split 1 minute segments to avoid data loss. Individual Viewing LUT Upload function for individual Look Up Tables. Enhanced Live View Better low light image composition control of the Live View image. Image Overlay Allows alignment of the camera position on basis of a previous taken image, that is displayed in a transparent mode in the EVF or on the LCD. Automatic Follow Focus Definition of three focus points for automatic focus shift during video recording. Wave form monitor Professional exposure valuation of the video signal. Color bar Reference for correct color grading and sound control in postproduction. Tally Mode Camera shows red frame on LCD during video recording. All those things looks like a pretty significant update to me. You can check link here: https://en.leica-camera.com/Photography/Leica-SL/Leica-SL2-S/Firmware Edited December 26, 2020 by Svetozar Quote Link to post Share on other sites More sharing options...
Radost Posted December 26, 2020 Share #654 Posted December 26, 2020 Does video mode correct distortion for Lmount alliance lenses? Quote Link to post Share on other sites More sharing options...
farnz Posted December 27, 2020 Share #655 Posted December 27, 2020 On 12/25/2020 at 10:22 PM, Steven said: Sure. Any preference on what I shoot ? Yes - can you shoot the deputy? (I shot the sheriff.) Pete. 4 Quote Link to post Share on other sites More sharing options...
bilbrown Posted December 27, 2020 Share #656 Posted December 27, 2020 On 12/24/2020 at 7:15 PM, Radost said: 5K mov? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Am I missing something... where is the 5K function on the SL2-S? Quote Link to post Share on other sites More sharing options...
Radost Posted December 27, 2020 Share #657 Posted December 27, 2020 (edited) 14 minutes ago, bilbrown said: Am I missing something... where is the 5K function on the SL2-S? Its in the manual. Maybe will introduced later with h265? Edited December 27, 2020 by Radost Quote Link to post Share on other sites More sharing options...
Slender Posted December 27, 2020 Share #658 Posted December 27, 2020 For I have recently read both camera manuals side by side = pretty sure this 5k one is SL2, not SL2s. 🤠 Quote Link to post Share on other sites More sharing options...
Radost Posted December 27, 2020 Share #659 Posted December 27, 2020 49 minutes ago, Slender said: For I have recently read both camera manuals side by side = pretty sure this 5k one is SL2, not SL2s. 🤠 Just saw that. I did read the wrong manual. I am wondering why they decided to skip 6k. Quote Link to post Share on other sites More sharing options...
Slender Posted December 28, 2020 Share #660 Posted December 28, 2020 4K is hard enough on most machine without a prores workflow... and who can really enjoy 6K content anyway? Perhaps they keep this as a suprise hattrick for later with raw output... or for a more expensive SL2 SP (or C ine) version 😜 This would get rid of all thing allialing and moire, by the way. I really would like to see some footage of fine detailed object shot in FF vs APS-s (pixel mix vs full pixel readout0 on this camera Quote Link to post Share on other sites More sharing options...
