gwater Posted October 3, 2020 Share #1 Posted October 3, 2020 (edited) Advertisement (gone after registration) I read that the SL2 outputs HDMI, but only 4K DCI is listed for external recording. Am I missing something, or is the SL2 unable to output any other resolution than 4096 x 2160 via HDMI? I would like to stream in Full HD using an encoder such as the LiveU Solo. Would that be possible? SL2 specs I read online: Recording Modes MOV/H.264 10-Bit 5K (4992 x 3744) at 23.976p/25p/29.97p DCI 4K (4096 x 2160) at 24.00p/25p/29.97p/50p/59.94p UHD 4K (3840 x 2160) at 23.976p/25p/29.97p/50p/59.94p Full HD (1920 x 1080) at 23.976p/25p/29.97p/50p/59.94p/100p/119.88p/180pMP4/H.264 10-Bit UHD 4K (3840 x 2160)23.976p/25p/29.97p/50p/59.94p Full HD (1920 x 1080)23.976p/25p/29.97p/50p/59.94p/100p/119.88p/180p External Recording Modes 10-Bit DCI 4K (4096 x 2160) up to 59.94p Edited October 3, 2020 by gwater Quote Link to post Share on other sites More sharing options...
Advertisement Posted October 3, 2020 Posted October 3, 2020 Hi gwater, Take a look here SL2 HDMI Output to Stream in Full HD. I'm sure you'll find what you were looking for!
LocalHero1953 Posted October 3, 2020 Share #2 Posted October 3, 2020 I'm pretty certain it does output FHD to HDMI; I have tried the HDMI-out, and I don't use UHD, just FHD - but I can't absolutely confirm I didn't have a higher res set. Quote Link to post Share on other sites More sharing options...
gwater Posted October 4, 2020 Author Share #3 Posted October 4, 2020 Thanks, I hope somebody can confirm if it outputs FHD to HDMI Quote Link to post Share on other sites More sharing options...
Melampus Posted October 4, 2020 Share #4 Posted October 4, 2020 Yes - you can stream FHD (1920x1080) from the SL2. I've used this $20 HDMI-USB converter (link below), works like a charm providing FHD@30fps, even though it's only USB 2.0. It converts the UHD HDMI signal from the SL2 and you can use it to stream from your Mac (or PC I'm sure - not tested). Here Cheers, -Peter 1 Quote Link to post Share on other sites More sharing options...
Sébastien NUNES Posted January 17, 2021 Share #5 Posted January 17, 2021 Hi @Melampus The link is broken, could you please tel us know which one you're using? Anybody tried the Cam link? Thanks! Quote Link to post Share on other sites More sharing options...
Melampus Posted January 18, 2021 Share #6 Posted January 18, 2021 That particular vendor appears to no longer be on Amazon. Here is another which looks identical to the one I bought. Hope this helps: Here Cheers, -Peter Quote Link to post Share on other sites More sharing options...
Photoworks Posted January 19, 2021 Share #7 Posted January 19, 2021 Advertisement (gone after registration) Yep there are so many of them. I am using them as Webcam in zoom in 1080p Quote Link to post Share on other sites More sharing options...
matted Posted December 17, 2022 Share #8 Posted December 17, 2022 I’m having trouble getting anything other than 1080 FHD out of my SL2-s, despite recording C4K internally. This is using my Odyssey 7Q+ recorder. Are there any settings in the SL2s that would dictate the HDMI output format? All I can find is the control to output RAW. Any help would be appreciated. Thanks! Quote Link to post Share on other sites More sharing options...
matted Posted December 19, 2022 Share #9 Posted December 19, 2022 On 12/17/2022 at 1:09 PM, matted said: I’m having trouble getting anything other than 1080 FHD out of my SL2-s, despite recording C4K internally. This is using my Odyssey 7Q+ recorder. Are there any settings in the SL2s that would dictate the HDMI output format? All I can find is the control to output RAW. Any help would be appreciated. Thanks! Never mind… I tried a different display device and am getting C4K output over HDMI. Must be either the cable or the Odyssey itself not allowing or not configured for 4K properly. Will see if I can dig up another cable (silly mini HDMI port on the Odyssey!) and tinker with the settings. Quote Link to post Share on other sites More sharing options...
