UHS-1 is the current cards that M's take and the new M-10 is no exception, but the current fast cards cards are UHS-II and the new standard is already out UHS-III. Why has Leica not upgraded? It is a disappointment considering the cost
I would imagine that Leica like other electronic manufacturures have a R&D department.. Once the design & other details have been agreed & Signed Off and manufacture begins, the designs cannot be retro engineered.. somewhere there is a UHS 1111   in the pipeline as is a  75mp Leica on someones design/engineering board.. Whatever electronics we buy today is already being superseded/engineered in a R&D department.. This goes for Cars, Cameras, TV's a million and one other things we use in life.. Take Heart   L
Edited by lykaman
Write speed is determined  by the processor. Leica M cameras are limited in that sense by heat management restrictions.mIn other words: the camera would not get any faster by using UHS-II or -III.
All M10 cameras can use UHS-II cards.
UHS-III cards were announced  a while ago, but never appeared on market.
I use UHS-II cards with my M10 cameras. Although there is no speed benefit with the camera, there is a speed benefit in uploading the images to my laptop with the proper card reader. When working on deadline every speed advantage helps.
4 hours ago, Fred C. Stadler said:
Sadly you are exactly correct, the card will work but not up to it's potential I suspect. I am using one in my M240 in fact. Just hoping for more when I update. Thanks to all for the help.
Why do you miss UHS II speeds on an M10? I never had to wait on SD card when using M10 cameras.
I believe UHS ii cards work in an M10 because they also work even if they are put into a UHS i socket, which is what the M10 has, and certainly all that the M240 can offer.  So in any of the present M cameras there will never be a speed advantage in writing to the SD chip.  The advantage is only in uploading to your computer over a wired interface, and that only would matter if you take 100s of shots per day (which I don't often do).
