Fontan Posted July 19, 2020 Share #1 Posted July 19, 2020 Advertisement (gone after registration) Hi guys Soooo, I got this very goofy problem with my M10. When I have my Pentax-l 43/1.9 special (M39 thread) via an adapter on my M10 every time I am in bright light surroundings, LV or EVF just switches off by itself. When indoor for example no such phenomena. It’s very annoying. Previously I had M240 and no such issues. Any thoughts? Could it be the adapter? Gracias in advance. 1 Link to post Share on other sites More sharing options...
Advertisement Posted July 19, 2020 Posted July 19, 2020 Hi Fontan, Take a look here EVF / LV shutting off in bright light. I'm sure you'll find what you were looking for!
m.birnbacher Posted July 19, 2020 Share #2 Posted July 19, 2020 when the bright light hit the lens ensor on the M10 body the EVF switches off. You schuld use a adapter that covers the sensor i used a peace of black paper - that helped:-) but I used it for just a few test shots greetings from Nuremberg Michell Link to post Share on other sites More sharing options...
Fontan Posted July 19, 2020 Author Share #3 Posted July 19, 2020 Thank you for the tip but hm . . . . I am not sure what you mean. Adapter that covers the sensor??? Link to post Share on other sites More sharing options...
brandnew2 Posted July 19, 2020 Share #4 Posted July 19, 2020 20 minutes ago, Fontan said: Thank you for the tip but hm . . . . I am not sure what you mean. Adapter that covers the sensor??? Hi, I have the same issue when I mount an MS Optics 24mm Aporia to my M10-p (it's a very small lens). The problem is that the lens does not fully cover the mount, so there is light that leaks in in the gap between the lens and the mount where the six-bit code reader is. If it detects light, it'll switch off live view because it assumes that that means no lens is installed on the camera. If I cover the gap fully with my finger, live view won't siwtch off in bright sunlight. 1 Link to post Share on other sites More sharing options...
Fontan Posted July 19, 2020 Author Share #5 Posted July 19, 2020 9 minutes ago, brandnew2 said: Hi, I have the same issue when I mount an MS Optics 24mm Aporia to my M10-p (it's a very small lens). The problem is that the lens does not fully cover the mount, so there is light that leaks in in the gap between the lens and the mount where the six-bit code reader is. If it detects light, it'll switch off live view because it assumes that that means no lens is installed on the camera. If I cover the gap fully with my finger, live view won't siwtch off in bright sunlight. Ahhhhh I see. A beautiful explanation! Thank you that! Lemme take a look here. Link to post Share on other sites More sharing options...
mujk Posted July 19, 2020 Share #6 Posted July 19, 2020 This happens when you use a 39toM adapter that has a cutout just where the lens code sensor elements are located in the mount, resulting in ambient lighting being able to reach these and causd this error. It's not really a light leak but a design feature of the adapter so that it doesn't obstruct the infinity lock of some older screw mount lenses. 2 Link to post Share on other sites More sharing options...
lucerne Posted July 19, 2020 Share #7 Posted July 19, 2020 (edited) Advertisement (gone after registration) For my M10 and 1951 Leitz 35 f:3.5 (LTM) I've just located a (rare) KIPON LTM to M adaptor (on Eb///) which has a shorter cutout and covers the lens code sensors at all times.. (it also has pits to allow permanent marking/coding of the LTM lens) . This method supports your EXIF record. Alternatively however, you can also stop the sensing by switching it off in the menu. You should buy the KIPON or similar which matches your lens focal lengths. Commonly 35-135. The Infinity Lock is still functional. Edited July 19, 2020 by lucerne Link to post Share on other sites More sharing options...
TomB_tx Posted July 19, 2020 Share #8 Posted July 19, 2020 Rayqual makes an adapter similar to the kipon, but I think higher quality. 1 Link to post Share on other sites More sharing options...
lucerne Posted July 19, 2020 Share #9 Posted July 19, 2020 (edited) Tom What evidence do you have for such a statement. have you handled both. What quality deficiencies did you observe. Dont be fooled. There may be some poorly made products but the kipon is fully profiled and well finished. Its not the cheapest and it does what its supposed to do. The Rayqual is very overpriced. What do get for the extra cost? Nothing! Its a single pressing. Once its fitted to the lens youll not need to touch it again. Edited July 19, 2020 by lucerne Link to post Share on other sites More sharing options...
Fontan Posted July 19, 2020 Author Share #10 Posted July 19, 2020 (edited) Well - I tried to cover it up and so on, but it is just hit and miss, so I ordered another one adapter from K&F. https://www.kentfaith.com/KF06.277_m39-50mm-75mm-lenses-to-leica-m-camera-mount-adapter?gclid=Cj0KCQjw3ZX4BRDmARIsAFYh7ZLpDjHdl6olZCvDc7GjbT-GpyX0arD2sP2xY9rwCVlZeJUcKVOsKWUaAu5HEALw_wcB Will see if this works better. If not, I can always send it back, I suppose. I am willing to go an extra mile because Pentax-l 43/1.9 special is, well, very special. I love the sharpness and the rendering. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited July 19, 2020 by Fontan 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/311471-evf-lv-shutting-off-in-bright-light/?do=findComment&comment=4011949'>More sharing options...
jdlaing Posted July 19, 2020 Share #11 Posted July 19, 2020 3 minutes ago, Fontan said: Well - I tried to cover it up and so on, but it is just hit and miss, so I ordered another one adapter from K&F. https://www.kentfaith.com/KF06.277_m39-50mm-75mm-lenses-to-leica-m-camera-mount-adapter?gclid=Cj0KCQjw3ZX4BRDmARIsAFYh7ZLpDjHdl6olZCvDc7GjbT-GpyX0arD2sP2xY9rwCVlZeJUcKVOsKWUaAu5HEALw_wcB Will see if this works better. If not, I can always send it back, I suppose. I am willing to go an extra mile because Pentax-l 43/1.9 special is, well, very special. I love the sharpness and the rendering. It still has the cutout. You need adapters like this: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/311471-evf-lv-shutting-off-in-bright-light/?do=findComment&comment=4011951'>More sharing options...
Fontan Posted July 19, 2020 Author Share #12 Posted July 19, 2020 4 minutes ago, jdlaing said: It still has the cutout. You need adapters like this: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Where can I get it!!? Link to post Share on other sites More sharing options...
jdlaing Posted July 19, 2020 Share #13 Posted July 19, 2020 Just now, Fontan said: Where can I get it!!? Cameraquest Link to post Share on other sites More sharing options...
Fontan Posted July 19, 2020 Author Share #14 Posted July 19, 2020 1 minute ago, jdlaing said: Cameraquest Thank you for the info! Link to post Share on other sites More sharing options...
jdlaing Posted July 19, 2020 Share #15 Posted July 19, 2020 4 minutes ago, Fontan said: Thank you for the info! You’re welcome. There are other adapters available without the cutout if you dig around. I have a couple old Voigtlander adapters without the cutout. They are no longer made and Rayqual is the new choice that the Voigtlander rep, Cameraquest, sells. Send an email to Steve Gandy, the owner.. 1 Link to post Share on other sites More sharing options...
TomB_tx Posted July 20, 2020 Share #16 Posted July 20, 2020 2 hours ago, lucerne said: Tom What evidence do you have for such a statement. have you handled both. What quality deficiencies did you observe. Dont be fooled. There may be some poorly made products but the kipon is fully profiled and well finished. Its not the cheapest and it does what its supposed to do. The Rayqual is very overpriced. What do get for the extra cost? Nothing! Its a single pressing. Once its fitted to the lens youll not need to touch it again. Good point - KIPON is a reputable manufacturer, and the products are generally good quality. The KIPON ltm/M adapter I have does have an appropriate cutout to work with most lenses, and covers the 6-bit sensor with an area with machined pits for encoding. The adapter is satin-chrome plated without grinding off the plating on the rear seating surface as was done on the original Leitz adapters (to assure plating thickness did not affect the registration distance). The satin-chrome has a definite texture, and I notice it has scuff marks on the back after some use of mounting-removing. Leitz used bright chrome with a smooth finish. The genuine Leitz adapters I have all measure flange thickness of 0.98 to 0.99 mm measure at points all around the circumference. The only KIPON I have measures from 1.02 to 1.07 mm measured around the circumference - so about 0.05 mm variation on the same part. I suspect that may be variation in plating thickness causing it. The Rayqual adapters I have also have a similar partial cutout to work with most lenses, and cover the 6-bit sensor with a machined channel (instead of individual pits) in area needed for coding with paint. These also have a satin chrome finish (black on these), but seem to have less texture than the KIPON, and also do not grind it off on the back side of the flange. The two Rayqual adapters I have measure flange thickness of 0.97 to 0.98 mm all around the circumference, so consistency is on the same order as the Leitz adapters. Voigtlander were the most like Leitz that I have seen. I would count both KIPON and Rayqual as good choices compared to other brands of Chinese adapters that I have tried - some don't even have the 3 small cutouts to remove the flange if it gets stuck in the camera body. But as I suggested, I think Rayqual has a slight edge - based on the few samples I have. 1 Link to post Share on other sites More sharing options...
Fontan Posted July 20, 2020 Author Share #17 Posted July 20, 2020 23 hours ago, jdlaing said: You’re welcome. There are other adapters available without the cutout if you dig around. I have a couple old Voigtlander adapters without the cutout. They are no longer made and Rayqual is the new choice that the Voigtlander rep, Cameraquest, sells. Send an email to Steve Gandy, the owner.. Ordered it yesterday! 1 Link to post Share on other sites More sharing options...
Fontan Posted July 23, 2020 Author Share #18 Posted July 23, 2020 An update! Got the Rayqual filter in the mail today, and glad to report that the problem is solved! Thank you guys! 2 Link to post Share on other sites More sharing options...
mmx_2 Posted July 24, 2020 Share #19 Posted July 24, 2020 On 7/23/2020 at 5:29 AM, Fontan said: An update! Got the Rayqual filter in the mail today, and glad to report that the problem is solved! Thank you guys! Is the adapter coded or do you need to write the codes yourself? Link to post Share on other sites More sharing options...
Fontan Posted July 25, 2020 Author Share #20 Posted July 25, 2020 On 7/24/2020 at 4:16 AM, mmx_2 said: Is the adapter coded or do you need to write the codes yourself? It’s not coded. But it can be coded is my understanding. The lens I’m slapping on is Pentax-l 43/1.9 m39 screw mount so coding doesn’t matter . . . . 1 Link to post Share on other sites More sharing options...
