richfx Posted June 11, 2020 Share #1 Posted June 11, 2020 Advertisement (gone after registration) The auto lens sensor hasn’t worked on my M10 since I bought it. I’ve read that this is a fairly common occurrence. Short of sending it in to Leica, has anyone figured out a fix? Link to post Share on other sites More sharing options...
Advertisement Posted June 11, 2020 Posted June 11, 2020 Hi richfx, Take a look here Auto Lens Sensor Not Working. I'm sure you'll find what you were looking for!
250swb Posted June 11, 2020 Share #2 Posted June 11, 2020 You mean the code sensor isn't working when you mount a coded lens? Link to post Share on other sites More sharing options...
chris_tribble Posted June 11, 2020 Share #3 Posted June 11, 2020 What lenses are you using? The sensor will only work with 6-bit coded lenses. Link to post Share on other sites More sharing options...
mujk Posted June 13, 2020 Share #4 Posted June 13, 2020 Do you get an error message indicating that lens detection doesn't work? Does the camera show the wrong lens type? Have you checked that Lens detection is set to Auto in the menu? Have you mounted the lens properly, i.e. exactly to the position where it locks, not short of this or past it? Link to post Share on other sites More sharing options...
