Good To Be Retired Posted May 14, 2020 Share #1 Posted May 14, 2020 Advertisement (gone after registration) Having determined that, for what I happen to like doing, an IR/UV Cut filter might be beneficial, I was wondering if I should create a new Lumariver custom profile for use with the IR/UV Cut filter attached. The appropriate approach would be to just make the profiles and see what happens, but the weather isn't currently cooperation and I'm working sort of on a thought experiment here until the sun peeks out. Any thoughts would be appreciated. Quote Link to post Share on other sites More sharing options...
Advertisement Posted May 14, 2020 Posted May 14, 2020 Hi Good To Be Retired, Take a look here M240, customers profiles, and IR/UV Cut filters. I'm sure you'll find what you were looking for!
jdlaing Posted May 14, 2020 Share #2 Posted May 14, 2020 Do it. Quote Link to post Share on other sites More sharing options...
jaapv Posted May 15, 2020 Share #3 Posted May 15, 2020 It is always a good idea to keep your profiles up to date but in this case the difference if any will be quite subtle. I assume that you colour manage your workflow completely, profiling one aspect is of limited use Quote Link to post Share on other sites More sharing options...
Good To Be Retired Posted May 15, 2020 Author Share #4 Posted May 15, 2020 5 hours ago, jaapv said: I assume that you colour manage your workflow completely You assume correctly. 1 Quote Link to post Share on other sites More sharing options...
