17 minutes ago, oka said:
If you have a single body which is slightly front focusing, lens which is slightly back focusing and second lens which has perfect calibration - you might easily end up sending the perfect lens for the service... tripod and live view is not always bulletproof check.
Never said it was bulletproof.  The most important point concerned your point about user error; hence tripod, target and RF comparison vs LV, which is exactly what the sensor sees.  In 35 years of M use, I’ve had a calibration issue 3 times. But better to send everything in than to do sloppy testing. Many people can’t discern simple focus shift, which is common and easily accommodated.
Jeff
