Using colored filter with color sensor is not good idea at all.
I had "done" this by surprise, when I use same lens ( Summilux 50, color red filter on it ) with film M, then forgot to remove when used on my M9 (by then),
the file was "something special" not less.
When viewed later, I had hard time to work with those reddish files 😪
the red filter saturated the red channel and let the other G,B not usable.
Monochrom sensor is not colored sensor !
Edited by a.noctilux
14 minutes ago, wolan said:
Hi,
can you recommend me a brand of high-quality color filters to use for BW photography with a M10?
Thank you.
No, a bad idea, make a colour photograph and use Silver Efex to add the effect of a colour filter (and also do all your other B&W post processing at the same time).
One thing against using postprocessed filters is that there is a risk of amplifying one colour channel to show too much noise. You must do your noise reduction per colour channel.
Maybe it would have helped to focus! :lol: Yes, using only one channel will reduce resolution to 50% (G)  or 25%. (R,B)
