jdlaing Posted April 28, 2020 Share #21 Posted April 28, 2020 Advertisement (gone after registration) 1 hour ago, ianman said: I had always thought the M-E was exactly the same as the M9. Evidently it is. Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 28, 2020 Posted April 28, 2020 Hi jdlaing, Take a look here A 21mm for M9/M-E. I'm sure you'll find what you were looking for!
Ko.Fe. Posted April 28, 2020 Share #22 Posted April 28, 2020 2 minutes ago, BarberShop said: I have also been considering a 21mm but am worried about framing since it requires an attachment on top of the camera, which would introduce even more parallax than the usual rangefinder. Can anyone put my mind at ease? You would have to deal mostly only with vertical one, horizontal is going to be less since it is above the lens axix. It is not as critical as with 50mm lens, it seems. I don't own 21mm Leica made or Viogtlander, Zeiss modern ones. They might have correction sub frame for closer distances. My Russar's VF has distance adjustment to correct vertical parallax. Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted April 28, 2020 Share #23 Posted April 28, 2020 2 minutes ago, jdlaing said: Evidently it is. Here is no ISO 6400 in M9 and M-E 220 which is M9 sub-model. Clear? Quote Link to post Share on other sites More sharing options...
jdlaing Posted April 28, 2020 Share #24 Posted April 28, 2020 Just now, Ko.Fe. said: Here is no ISO 6400 in M9 and M-E 220 which is M9 sub-model. Clear? Yes. Clear. But you have a snotty attitude and give new meaning to English as a second language. You should work on that. Quote Link to post Share on other sites More sharing options...
Ko.Fe. Posted April 28, 2020 Share #25 Posted April 28, 2020 1 minute ago, jdlaing said: Yes. Clear. But you have a snotty attitude and give new meaning to English as a second language. You should work on that. Your own attitude ain't the bed of roses as well. So, you are getting just adequate response. Sorry, it isn't as English as you prefer to be treated. But look at the mirror first. Quote Link to post Share on other sites More sharing options...
a.noctilux Posted April 28, 2020 Share #26 Posted April 28, 2020 (edited) Nightstreet, which Yashica 3.5/21mm lens ? ML like here ? 😉 ... Barbershop, with Leica M10 you can use LV or Visoflex 020 to frame 21mm lens. Edited April 28, 2020 by a.noctilux Quote Link to post Share on other sites More sharing options...
nightstreet Posted April 28, 2020 Author Share #27 Posted April 28, 2020 Advertisement (gone after registration) Yes, Yashica ML 21mm f/3.5, C/Y Mount [Contax/Yashica]. There are adapters for both m-mount and z-mount, and I suspect others too. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/308951-a-21mm-for-m9m-e/?do=findComment&comment=3962756'>More sharing options...
Topsy Posted April 28, 2020 Share #28 Posted April 28, 2020 FYI the 16-55 f2.8 isn't the kit lens for the Fuji that would be the 18-55 not weather sealed and f2.8-f4. Good lens none the less but I wanted the bad weather setup. Quote Link to post Share on other sites More sharing options...
BarberShop Posted April 29, 2020 Share #29 Posted April 29, 2020 14 hours ago, a.noctilux said: ... Barbershop, with Leica M10 you can use LV or Visoflex 020 to frame 21mm lens. Thanks but I only have an M9 at the moment Might upgrade eventually but tbh I am still mulling whether or not rangefinders are for me. Quote Link to post Share on other sites More sharing options...
a.noctilux Posted April 29, 2020 Share #30 Posted April 29, 2020 27 minutes ago, BarberShop said: Thanks but I only have an M9 at the moment Might upgrade eventually but tbh I am still mulling whether or not rangefinders are for me. Leica M can be used without rangefinder, (of course also M9 ) mainly with wide angle lenses. I happily used for decades the "film Leica" without viewfinder/rangefinder like MDa, here with Super-Angulon 4/21mm and add-on 21mm finder 😉 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! very compact, pleasing and light combo kind of P&S Leica with of course a bit of practice to make the best out of the combo 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! very compact, pleasing and light combo kind of P&S Leica with of course a bit of practice to make the best out of the combo ' data-webShareUrl='https://www.l-camera-forum.com/topic/308951-a-21mm-for-m9m-e/?do=findComment&comment=3963106'>More sharing options...
