lykaman Posted April 5, 2020 Share #1 Posted April 5, 2020 Advertisement (gone after registration) Hi All, something that is niggling at me, If I use B&W on my Leica digital will the difference between just changing a Color image to B&W be noticeable? L Quote Link to post Share on other sites More sharing options...
Advertisement Posted April 5, 2020 Posted April 5, 2020 Hi lykaman, Take a look here Looking For Info. I'm sure you'll find what you were looking for!
Exodies Posted April 6, 2020 Share #2 Posted April 6, 2020 The B&W option on Leica’s non-monochrome cameras is just changing a colour image (the raw file) to black and white (the jpeg file). There are as many ways of doing this conversion as there are permutations of three eight bit numbers. Quote Link to post Share on other sites More sharing options...
Luke_Miller Posted April 6, 2020 Share #3 Posted April 6, 2020 (edited) Probably not a lot of difference between a B&W jpeg straight from the camera and a B&W image from a raw file processed using default settings. But with many raw processors one can create B&W images by manipulating the color information in the raw file. This changes the luminosity of different colored elements in the image, much the same as using a color filter on the lens. So, for example, a landscape shot could have the green foliage lightened or darkened to taste without affecting other (different colored) elements in the resulting B&W mage. Edited April 6, 2020 by Luke_Miller 1 Quote Link to post Share on other sites More sharing options...
lykaman Posted April 6, 2020 Author Share #4 Posted April 6, 2020 (edited) 2 hours ago, Luke_Miller said: Probably not a lot of difference between a B&W jpeg straight from the camera and a B&W image from a raw file processed using default settings. But with many raw processors one can create B&W images by manipulating the color information in the raw file. This changes the luminosity of different colored elements in the image, much the same as using a color filter on the lens. So, for example, a landscape shot could have the green foliage lightened or darkened to taste without affecting other (different colored) elements in the resulting B&W mage. On this Forum, I don't really think it matters, for printing and other reasons RAW B&W and then PP is always the best.. L Edited April 6, 2020 by lykaman Quote Link to post Share on other sites More sharing options...
zeitz Posted April 6, 2020 Share #5 Posted April 6, 2020 A raw file is a table of numbers read from the sensor's pixels; a raw file is not an image. You can open a raw file in a text editor and see the contents. Color digital cameras, such as the OP's color digital Leica, make each pixel red, blue or green by means of a filter array such as a Bayer filter. So when a color digital camera displays a color image or a B&W image, some post-processing software is converting the table of numbers, de-mosaicing it into the image. It is displayed on the camera's monitor as a jpeg image. In-camera B&W for a color digital camera uses in-camera post-processing software. Whether or not an in-camera B&W image matches a post-processing B&W image done on a computer depends solely on how you do the conversion on a computer. The only raw B&W is on a Leica Monochrome camera. Quote Link to post Share on other sites More sharing options...
Jeff S Posted April 6, 2020 Share #6 Posted April 6, 2020 31 minutes ago, zeitz said: The only raw B&W is on a Leica Monochrome camera. Or other company’s monochrome camera or back, e.g., Phase. Jeff Quote Link to post Share on other sites More sharing options...
Jossie Posted April 7, 2020 Share #7 Posted April 7, 2020 (edited) Advertisement (gone after registration) The conversion of a digital colour image into a greyscale image is standardized by various definitions. In general, the linear greyscale value Y is calculated from the (linear, i.e.not gamma-corrected) RGB-values according to Y = wR * R + wG * G + wB * B, with the weights wR, wG and wG. (see Burger & Burge 2016, Springer for details). The two most common definitions of the weights are the TV-standard: wR = 0.299, wG = 0.587 and wB = 0.114, and ITU-BT.709: wR = 0.2125, wG = 0.7154, wB = 0.072. Since the human eye is most sensitive in G, this channel is weighted highest. I would assume that any in-camera conversion is using one of these. Also the conversion functions in any software will most likely use one of them. The documentation should tell you, which is actually used, if it cannot be selected by the user. Some software does allow the user to specify arbitrary weighting factors, e.g. SilverFast. Here is a comparison between the two standards (original left, TV standard middle, ITU-BT.709 right): Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Hermann-Josef Edited April 7, 2020 by Jossie 1 Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! Hermann-Josef ' data-webShareUrl='https://www.l-camera-forum.com/topic/308238-looking-for-info/?do=findComment&comment=3948663'>More sharing options...
