kingson138 Posted March 8, 2020 Share #1 Posted March 8, 2020 Advertisement (gone after registration) Hi, recently I had designed and built by 3D printing a longer Endcap for retractible lenses. Basically it has an internal depth of 23mm, which i think will fit most of the M mount retractible lenses. I designed this Endcap for my 50mm Elmar F2.8 lens. It is better to use a good 3D printer. I printed this Endcap using my Craftbot Plus printer at " 0.100mm " layer height, with 15% infill. I printed these Endcaps on Glass Bed with Dimafix 3D printer glue. The result is mirror smooth bottom. You can use PLA or PETG. This is a very clean design. There is no oozing to be cut except the last one when the nozzle started to go into Home position. You can use any colors you want. I did not take a picture of the Endcaps today but i will add that to the Dropbox download folder. In this folder you can find a stp file and a stl file suitable for 3D printing. You can revise the design by loading the stp file. A computer rendering is included. Tomorrow evening I will put actual pictures into this downloadable folder. This is the link: https://www.dropbox.com/sh/qsjcj2srlp3moea/AAD6QWKuZBCtYeihflJ3ZzIoa?dl=0 Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307236-endcaps-for-m-mount-retractable-lenses-by-3d-printing/?do=findComment&comment=3927320'>More sharing options...
Advertisement Posted March 8, 2020 Posted March 8, 2020 Hi kingson138, Take a look here Endcaps for M Mount Retractable Lenses by 3D printing. I'm sure you'll find what you were looking for!
kingson138 Posted March 9, 2020 Author Share #2 Posted March 9, 2020 This is a picture of the Black Endcap with the 50mm Elmar F2.8 lens. More pictures already in the download link : https://www.dropbox.com/sh/qsjcj2srlp3moea/AAD6QWKuZBCtYeihflJ3ZzIoa?dl=0 Regards, Kingson Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Quote Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/307236-endcaps-for-m-mount-retractable-lenses-by-3d-printing/?do=findComment&comment=3927781'>More sharing options...
TomB_tx Posted March 9, 2020 Share #3 Posted March 9, 2020 Nice idea! I had found an aftermarket deep aluminum cap for similar use, but 3D printing is ideal for such things. Quote Link to post Share on other sites More sharing options...
Good To Be Retired Posted March 9, 2020 Share #4 Posted March 9, 2020 (edited) A gentleman on this forum sent me samples of the rear caps he was printing two or three years ago, but was unable to identify a printing material that would allow sufficient flexibility for the intended use. The caps were brittle and small pieces would begin to wear off almost immediately. The bits coming off naturally would not be good inside lenses or cameras. What has been your experience in this regard? Also, had you considered printing a double ended version to facilitate lens changes? Edited March 9, 2020 by Good To Be Retired Quote Link to post Share on other sites More sharing options...
