tedd Posted February 25, 2020 Share #1 Â Posted February 25, 2020 Advertisement (gone after registration) So I'm yet to pick up my first digital Leica, but I am thinking about it a LOT and curious how Lightroom works with the 6-bit code system. If you only shoot RAW (which I do), does Lightroom pick up the lens info and automatically apply the correction? Or does the camera apply the correction before writing the RAW file? If none of your lenses are coded, can you simply tell the camera nothing and then select the correct lens in Lightroom and have it fix anything that needs fixing there? Newbie questions I know, but I like to have things well and truly figured out before I jump in completely! Thanks!! Link to post Share on other sites More sharing options...
Advertisement Posted February 25, 2020 Posted February 25, 2020 Hi tedd, Take a look here Does Lightroom pick up 6-bit code information from RAW file?. I'm sure you'll find what you were looking for!
jaapv Posted February 25, 2020 Share #2  Posted February 25, 2020 Lightroom does nothing with the six-bit code except read camera-produced EXIF and sidecar files to recognize the lens. The camera picks up the 6-bit code and uses it to apply in-camera corrections. It writes the lens data into the file and EXIF for post-processing programs to use. You can also select the lens type in the camera menu with uncoded lenses. You cannot make all corrections on the camera output of a non-selected lens - you will be missing out on the basic in-camera corrections. Lightroom lens corrections of M lenses are either minimal (distortion) or non-existent. 1 2 Link to post Share on other sites More sharing options...
M11 for me Posted February 25, 2020 Share #3  Posted February 25, 2020 (edited) Definitely Lightroom recognises your lens. I shoot only DNG and it behaves as with Canon: When ticking the field fir profile correction the image is immediately adapted And it goes even further: When you crop your images in LR then the adapted angle of view is recognized as well and rendered in the exported pictures. I am always amazed when I view my images in Smugmug that it shows the "new" focal lengh in the Exifs. Great. And indeed the image was slightly croped as shown correctly. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited February 25, 2020 by M10 for me Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/306808-does-lightroom-pick-up-6-bit-code-information-from-raw-file/?do=findComment&comment=3919442'>More sharing options...
pedaes Posted February 25, 2020 Share #4 Â Posted February 25, 2020 (edited) 4 minutes ago, M10 for me said: Definitely Lightroom recognises your lens. I shoot only DNG and it behaves as with Canon: When ticking the field fir profile correction the image is immediately adapted Agree the first sentence if you add 'and shows the information of lens model in EXIF data'. I do not agree anything else happens that is lens, not camera, specific . The camera profiles work with any lens, coded or not. Edited February 25, 2020 by pedaes Link to post Share on other sites More sharing options...
jaapv Posted February 25, 2020 Share #5  Posted February 25, 2020 Cyan vignetting, for instance, is corrected in-camera before the raw file is written. Distortion correction is mostly done in Lightroom in a lens profile. Lens (and sensor) corrections is something completely different from a camera profile in Lightroom. The last is applied during raw conversion in the post-processing program and is lens-independent. 1 Link to post Share on other sites More sharing options...
M11 for me Posted February 25, 2020 Share #6  Posted February 25, 2020 vor 14 Minuten schrieb pedaes: Agree the first sentence if you add 'and shows the information of lens model in EXIF data'. I do not agree anything else happens that is lens, not camera, specific . The camera profiles work with any lens, coded or not. Thx pedaes. But I wonder if we talk of the same thing. Look at my sceen-shot (only part of screen actually) of the settings in Lightroom: How would LR recognise that information without the Code?  Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/306808-does-lightroom-pick-up-6-bit-code-information-from-raw-file/?do=findComment&comment=3919450'>More sharing options...
pedaes Posted February 25, 2020 Share #7 Â Posted February 25, 2020 Advertisement (gone after registration) 3 hours ago, M10 for me said: information without the Code? Ok yes. Code to Exif, EXIF to LR I guess. If you manually select a lens in camera menu it shows in the LR lens profile as well.I have just checked a 50mm Zeiss Planar entered as a Summicron and it shows the selected Summicron in the lens profile. 1 Link to post Share on other sites More sharing options...
antonio-p Posted May 28, 2024 Share #8  Posted May 28, 2024 On 2/25/2020 at 11:52 AM, jaapv said: Cyan vignetting, for instance, is corrected in-camera before the raw file is written. Distortion correction is mostly done in Lightroom in a lens profile. Lens (and sensor) corrections is something completely different from a camera profile in Lightroom. The last is applied during raw conversion in the post-processing program and is lens-independent. Are you really sure that with the 6 bit code the vignetting correction is also applied to the DNG as well as to the on camera JPG? I can't find any clarification on this topic written directly by Leica Link to post Share on other sites More sharing options...
jaapv Posted May 28, 2024 Share #9 Â Posted May 28, 2024 The instructions for the raw converter are written to the .XMP file. If you want a good explanation of DNG refer to Jeff Schewe: The Digital Negative. An older work, but still essential reading for any photographer who wants to understand the basics of digital photography. 1 Link to post Share on other sites More sharing options...
