In addition:
  • The possibility to set up a custom list of uncoded lenses and a rapid way to choose between these.
  • The possibility to force selection of an uncoded lens even if the camera thinks there is no lens mounted, e.g. when using an LTM lens with an adapter that has a cutout for the infinity lock
And these also for the M10, please.
2 hours ago, mujk said:
+1
In addition:
I think you can do your first item already by having custom profiles setup with the lens of choice selected.  It’s probably not as direct as you are envisioning but it can be done now.
Yes, that's what I currently do, but it's not particularly fast to change. E.g. being able to change the lens from the info screen (centre button) would be great. Also, if you want to change any other settings, you need to update them separately for every custom profile.
I would love to see the option, so go down to ISO 100 in auto ISO mode, if the shutter speed is maxed out at 1/4000th s. This would be very helpful when shooting wide open.
And a faster wake-up time would be great.
Edited by PatrickN
