Hello everyone!
I'm new to the leica film cameras but I came up a rather very nice iiif in great condition which comes with a summarit 50mm f1.5 going for about $550. This sounded like a pretty good deal to me, however, upon closer inspection the lens seemed to have a lot of haze (not sure about fungus) as when I performed the light test there were specks everywhere. It seemed to be internal and in the second glass?? Not sure how to fix it or if I even can, also the focus ring was pretty stiff (but that isn't a deal breaker or anything). Like I said, the body of the camera was in very good condition however the lens is my biggest concern. As most of you are owners/experts and such please help me out and let me know if this is a good deal or not.
Thanks, Ashley
Edited by ashley12234
Share this post
You'll have to decide yourself whether you consider this a good deal or not, but a body that "is in great condition" (to me it sounds like "looks nice but needs a CLA" (say, 350$)) and a lens the may be, or not be - but then it will need expert attention (say another few hundred $$) - a write-off, sounds like a gamble to me. There are plenty of good iiif cameras and Summarits out there from trusted sellers that are less problematic, even if they appear to be a bit more expensive up front.
Share this post
Optical cell is more or less fully closed, isolated from environmental influence with one exception and this is aperture. Aperture Ring is greased and especially grease used late fiftieth early sixties has a tendency to evaporate and to deposit on glass close to aperture blades. In case of Summarit it would be between 3rd and 4th element. Very often opening the lens allow to clean the fog completely, however sometimes the vapor destroyed the coating and the only one way to make the lens usable is to remove the coating.
the specs which you observe could be black paint used to paint the edges of the glass, it falls off sometimes. Or it could be as well air bubbles when glass for the lenses was melted. This is normal for lenses from older production and does not have effect on the quality. Small bubbles are seen as black, bigger as black ring transparent inside.
and stiff focusing ring is not a big problem, CLA.
Share this post
Of course, fully agree with Jerzy. On top of that, please have in mind that the good external condition means that probably the internals haven't suffered a lot, but usually also means little usage, so as mentioned by Jaapv it would probably need a CLA (specially for renewal of the greases and check/adjust speeds).
The good news are that once CLA'd you'll have camera for another 50-60 years :)
Best regards,
Augusto
Edited by tranquilo67
Share this post
Given that the lens is your major concern, I speak of it, as an owner of 2 Summarit 1,5 which are in rather different conditions
the "younger" - BM - is hazy - focus not smooth - and f/stop ring not so fine-clicking  (bought lot of years ago for few money)
the "older" - SM - is in a much better shape, glass clean, focus smooth, just a little misalignement of f stop ring, but with good clickings
And working with the second is a pleasure , while the first one... today is an honest paperweight : Summarit 1,5 is a someway critical lens to use (at 1,5 or 2) and  if you cannot focus comfortably that's annoying  (is not like working with an Elmar) ; I think that it can be restored, but that must be a very professional job, because is a complex / heavy / tight-tolerancing item :  in my opinion, in your mind you ought to think that the Summarit, can be accounted for a value in the range of 150$... and should you find a GOOD lab who can restore it for 300$ or so… it can be Worth.
Btw : Summarit is a lens for which a hood is a nice to have in several situations… and the hood isn't so easy to find… :huh:
Share this post
Loading...
    No registered users viewing this page.
  • Similar Content
    • By Rhys
      Hi folks. I'm looking at buying a iiif as my first Leica, but it doesn't matter how much I google I can't seam to see an indication on how big the eyepieces are and only one or two blurred pics looking through the rangefinder bit. I wear glasses sp don't know if anything really small would be any good, and I've never handled one, only an M years ago in the late 90's at a Focus show on Birmingham.
      I've also been looking at Canon IVsb's as well (with the option of using Leica LTM lenses) as they show 1.1 with built in magnification for other lenses. Even looked into Canon P for the bigger viewfinder and LTM mount, but they are mostly in Japan at a decent price. The thought of owning a Leica keeps bringing me back to the iiif though (iiig is too expensive for me at the min).
      I love the compact nature of my Fuji X-Pro2 but it isn't a proper rangefinder, and I've gone off my Nikon D3s as its too heavy to cart around so I'll probably end up selling it before the prices plummet any more (which will bring me into M territory).
      Can anyone take a few pics of a iiif viewfinder next to a penny or similar to give me an idea of size, and maybe a few pics from a camera phone showing the rangefinder split screen and viewfinder please.
    • By Julio Cardador
      Leica IIIF black dial 530271 1950/51 + Summitar 2/5cm Set CLA Foto Wiese Hamburg   Leica IIIf mit schwarzen Kontaktzahlen. Die Kamera wurde vor vier Jahren bei Foto Wiese in Hamburg überholt ( Quittungen und Zeitenmessprotokoll liegen bei, siehe Bilder ), sie hat dabei ein neues Verschlusstuch bekommen und wurde gereinigt. Sie ist m.M. in einem sehr guten gebrauchten Zustand und voll funktionsfähig.   Dazu gibt es das Summitar 2/50mm, die dazugehörige SOOPD Spring-Blende, einen Rot-Orange Filter und einen UV Filter für das Summitar ( letzterer leider mit kleinem Steinschlag ) sowie ein passendes Filter-Döschchen.
      Das Objektiv ist ebenfalls in einem sehr schönen Zustand, alles leicht und weich-gängig. Leichte Einschlüsse vorhanden. Normale Gebrauchsspuren, wurde immer mit einem Filter geschützt. Die Bereitschaftstasche ist auch in gutem Zustand und voll einsatzfähig.   Weitere Fotos gern per mail etc..   + kleiner Leica Pin fürs Revers 😉 + Original Karton
      Bei Fragen, VORHER fragen.
      Preis VB, bitte Angebote machen, ich beisse nicht 🙂
      Privater Verkauf, keine Garantie oder Rücknahme.
      Versand als DHL Paket, versichert + Tracking.
      Abholung und Test in 13055 Berlin möglich.
      Zahlung per PayPal und Überweisung oder Barzahlung bei Abholung.
      International Bidders: Please contact me BEFORE, to get an english description if needed + to check out/discuss shipping costs and conditions.
    • By lykaman
      Hi All, my CLA'd  111f's will be arriving shortly, I'm hoping to use one for B&W and the other for Color,, This is just going to be a fun exercise, which films would you suggest? (It must be 20years since I used my film cameras, R6.2 & M6) - L
    • By TheGodParticle/Hari
      Most of us seem to be photographers as well as collectors.
      Show me your favorite lenses, old and new alike.
      I like the Noctilux range for the extreme apertures, but I prefer the Summilux range for the best speed:size/weight ratio.
      Here’s a Summilux gathering of 21, 24, 28, 35, 50 and 75mm. All in black.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By frame-it
      i accidentally pressed the shutter [was cocked] of my iiif while removing it from  my coat pocket, the lens cap was on..am curious how many turns of the rewind knob would equal 1 frame ?
