LUF Admin
Leica SL Firmware Update 3.7
Leica Camera has released a new firmware update for the Leica SL (Type 601):
Compatibility with existing and upcoming lenses from L-Mount Alliance partners
  • Improvement on compatibility with lenses that are equipped with a focus limiter switch.
  • Improvement on compatibility with lenses that are equipped with an O.I.S. mode switch.
  • Improvement on compatibility with lenses that are equipped with an aperture ring.
  • Improvement on shutter lag in bright situations.
  • Adapters firmware version is now shown in camera menu.
  • Further improvement on compatibility with existing and upcoming lenses from L-Mount Alliance partners.
Video performance
  • Improved L-Log, which contains the latest developments on video post-production. Thus, SL and SL2 can be used with the same L-Log.
» Leica SL Firmware 3.7 Download Page
Share this post
Thanks. Did somebody checked if the SL is again compatible with the Sigma MC-21?
Share this post
I've done the update, and so far MC-21 is still not compatible on the SL601.
Share this post
Bah humbug...
Share this post
Thanks Mike for the check.
I don't understand Leica strategy on this topic. It works with SL2, initially worked with SL and doesn't work on SL since one of the last firmware update....Strange.
Share this post
Yes, it is an odd one.  You would think that somehow the 'alliance' would be able to work things out.
Share this post
Updated my SL from 3.6 to 3.7 and Sigma 45mm  Auto focus DG DN ( L Mount )  1.0  to 1.1 with no problem.
Hope that helps.
Share this post
Loading...
  • Similar Content
    • By pehle
      Hallo zusammen,
      ich hoffe ihr könnt mir bei folgendem Problem weiterhelfen:
      Ich habe eine Leica SL und habe mir nun das Voigtländer 35mm 1.4 gekauft inklusive dem Leica M-Adapter L.
      Leider wird an meiner Kamera angezeigt, es sein ein "Kommunikationsfehler Objektiv" vorliegend. Die SL hat das neustes Betriebssystem installiert, ich habe die Profile durchprobiert und in den Einstellungen verschiedenste Punkte probiert. Als ein kleiner Hinweis, die SL, der Adapter und das Objektiv sind alles Originalwaren. Gibt es jemanden unter euch, der ein ähnliches Problem hatte und kann mir dabei helfen?
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden!
    • By Frank_W
      Verkaufe aus gesundheitlichen Gründen eine Leica SL, wenig benutzt und daher nahezu neuwertig und ohne Gebrauchsspuren. Gekauft im Juli 2017 hat die Kamera weniger als 10.000 Auslösungen. Die Kamera wird verkauft im Originalkarton und allem darin befindlichen Zubehör.
      Gerne weitere Auskünfte per PN oder Email.
      Verkauf an Selbstabholer oder Versand (dann bitte Vorkasse oder Paypal).
      Privatverkauf, keine Garantie, keine Rückgabe.
    • By LUF Admin
      Leica Camera hat eine neue Firmware für die Leica SL (Type 601) vorgestellt:
      Kompatibilität mit existierenden und zukünftigen Objektiven von L-Mount Allianz Partnern
      Verbesserung der Kompatibilität mit Objektiven, die einen Schalter zur Fokusbegrenzung haben. Verbesserung der Kompatibilität mit Objektiven, die einen Schalter zur Auswahl der optischen Bildstabilisierung haben. Verbesserung der Kompatibilität mit Objektiven, die einen Blendenring haben. Verbesserung der Auslöseverzögerung in Gegenlichtsituationen. Die Firmware-Version von Leica L-Adaptern wird im Kamera Menü angezeigt. Verbesserung der Kompatibilität mit aktuellen und zukünftigen L-Mount Objektiven von Leica sowie mit Objektiven unserer L-Mount Allianz-Partner. Video Performance
      Verbesserter L-Log, der die aktuellsten Entwicklungen im Bereich Video-Nachbearbeitung enthält. Dadurch sind SL und SL2 mit dem gleichen L-Log verwendbar. » Leica SL Firmware 3.7 Download Seite
    • By KenBennett
      Just installed the new Q2 firmware. Writing to the SD card is significantly improved. The buffer hasn't improved, of course, so I still get only 9 fast DNG+JPEG photos before the camera stops shooting, but instead of ~20 sec to finish writing, now it's <10 seconds. The card is a Sandisk Extreme Pro 300 mb/sec 64 GB.
      I had never saved my settings as a User Profile, so I lost them. (Hint, when the camera asks if you would like to save your user settings before doing the firmware upgrade, it's NOT going to tell you that you don't have any.  ) Now I get to spend the next 30 minutes trying to recreate my settings. Sigh.
    No registered users viewing this page.
Important Information
