I notice this on my photos with my M10 with different  objectives and different iso values but it is persist on same
a patch of different area can be seen on monitor adjusted to high illumunition
Edited by babaciciyo
mistake
A  screen for editing photographs is supposed to have a brightness of 120 lm. Cranking it up is not a good idea, it impacts the viewing negatively and will lead to uneven screen brightness and contrast. If you want to lighten your photograph, use the  sliders in your postprocessing software.
Ah-you mean the noise structure. Yes, that looks a bit washed out.  Is this from the corner of the frame? In that case I cannot tell whether it is normal or not. It may well  be that there is inevitable crosstalk between such small pixels on  high-resolution sensors at acute incidence angles. I suggest that you contact Leica with the images and ask for their comment.
