Images from Panasonic L-Mount cameras
On 1/9/2020 at 12:55 PM, dritz said:
Why would the S lenses require manual focus?  I use the S lenses on the SL with the Leica adapter, and autofocus works fine. Perhaps you are saying that perfect focus requires manual focus and 100% zoom.... and to that I would agree.
Dean,
Unfortunately the S-L adapter does not AF on the Panasonic.  Just manual focus.
 Rob
  • jaapv changed the title to Images from Panasonic cameras
  • jaapv pinned this topic
S1r with Leica 24-90-L lens
Pana S1R + 24-105mm
Same again
  • Thanks 2
S1r + 24-105mm
Same Combo
Messing around with some film looks, what do you guys think of these?
Pana S1R + 70-200mm F4
Rosenmontag mit S1R und Sigma 24-70
Edited by Günter1966
On 3/18/2019 at 6:51 PM, thighslapper said:
I suspect this is the issue ...... but it does raise the question of how the SL manages to produce a perfect screen image and meter correctly with a 10 stop ND at ISO 50 in normal lighting and continues to function accurately in even lower light conditions.
The S1R in the same light levels at ISO 100 shows a dimmed screen even with a 6 stop ND and underexposes by 2.5 stops. I'm not that fussed about the display but the inaccuracy of exposure metering ..... in conditions where I would expect things to work fine.
I fear that my expectations after extensive use of the SL with long exposures, low light and high value ND's are not going to be matched by Panasonics offering. The only question is whether all the other advantages outweigh the 5% of occasions where it will irritate me because it can't do what the SL does .....
I managed to get my SL to show the same behavior. A 10 ND plus a 0,9 Grad did the trick; Just not enough light to trigger the mter, was the verdict. Picture attached after choosing a much lighter ND.
Edited by vanhulsenbeek
S1R + late 1960's adapted 7.5mm fisheye @ 5.6
S1 + Elmarit-M 24mm + Torch (light on the hotel) + patience to wait for cars.
Edited by tom.w.bn
  • Like 17
  • jaapv changed the title to Images from Panasonic L-Mount cameras
