Sign in to follow this
Artin
SL2 grip , what do you guys think
this is what I am getting with may grip tightened as much as I can , you tell me if this is good enough
Share this post
My old SL1 grip was a tight seamless fit with no wobble.
Presumably you have removed any extraneous rubber/bits/plugs etc. so either means the tripod hole screw is bottoming out before the grip is tight on the body .... or the connector plug is sitting too high ..... or any locating pegs are too long.
If it's the screw, 5 minutes with a file should fix it, but then you void the warranty. I suspect it has to be, otherwise there would be no wobble.
Stabl produced and sold a whole batch of L plates for the S1R when they clearly had not tried the finished production model on the camera. They didn't fit and you couldn't get the battery door open. I suspect this is a similar problem.
Share this post
This is my take on this .. the rubber under the camera.. which is not removable is sitting on to the grip which gives you that gap that we see, the thumb wheel to thirteen the grip is small so not enough leverage to pull it tight. The way it should have been designed and manufactured is wrong. That grip and the camera should have made metal contact , RE the perimeter of the grip should have a raised lip to seat directly on the perimeter of the Body away from the rubber.
I want to know if anyone that has a grip on their camera can stick a Nickel in the gap
Share this post
29 minutes ago, snooper said:
Greetings,
The rubber is not supposed to go out of the way ?
no the rubber under the camera is glued on
Share this post
Sorry I thought you were writing about the rubber piece over the contacts... I have no other rubber under my SL2 ??!!??
Edited by snooper
Share this post
Either there is something in between that does not belong there (e.g. that little rubber piece that protects the cameras contacts or the other one that protects the grip contacts) or you may wanna exchange it. My SL2 grip sits snug tight perfect, while the SL 601 was a little bit shaky. Don‘t worry, if something is wrong, Leica is for sure taking care of. Btw I like the grip a lot!
Edited by frogfisher
Share this post
vor 58 Minuten schrieb Artin:
No it’s not. It’s just pretty tight
Share this post
The large rubber pads under the camera are not meant to be removed l am not going to try and damage the camera.
Share this post
If you look close you will see large rubber pads on the bottom plate of the SL2
Share this post
Just now, frogfisher said:
that should help demonstrate
I know the small cover comes off , now do you see that large pad all around? That is what I am talking about. Put your grip on and see if it has a give or is it solid with no movement
Share this post
I see, I meant the little rubber piece. It sits very tight, but you need to remove it before you screw on the grip. As said, my grip sits perfectly, no wobble at all even if I try hard
Share this post
Is the larger surrounding pad on you body inset , or is it proud of the base plate ?
Share this post
and of course i did not mean to manipulate that „large rubber pad“, sorry if I was misunderstanding. Have you removed the two little  protective rubber/plastic pieces? One on the camera, the other one on the grip, both to protect the contacts.. Leica has designated a particular space on top of the grip to store both pieces, while the grip is attached
Share this post
Froggy, this is not my first Rodeo . Yes I have removed the protective covers and placed them in their designated spots. I have checked this thing 9 ways to heaven either my camera body is defective...  ie.... the base plate rubber was not seated in deep enough. Or the bloody design is just plain old bullshit. Simple as that.
it is what it is hopefully they will correct it on the next generation.
Edited by Artin
Share this post
vor 53 Minuten schrieb Artin:
😅 got it. I was just trying to help, nevermind
Share this post
Loading...
    No registered users viewing this page.
Important Information
