waynexu1998
SL2 AF half-press blurs EVF
I have been noticing that Leica SL2 blurs the EVF when I half press the shutter. Is this happening with everyone and is there any news on if they will address this issue in the upcoming firmware update? Thanks a lot!
Share this post
I have not had no issues like that , half press actually lock in the focus and the evf is tack sharp
Share this post
Same thing happens with Q2... pretty sure it's normal for the SL2 (although not a good normal). Playback is CRYSTAL sharp. Is that what you are noticing??
Edited by Donzo98
Share this post
Yes indeed, there’s a noticeable blur the moment you press focus then the playback is tack sharp, I have seen people discuss this in the forum but could not locate it again.. so I decided to ask around
Share this post
What I noticed is a momentary blur during exposure not half press, I will check again in a moment
Share this post
Nope no blurring  at all with manual focus lenses , I will check with with autofocus lens
Edited by Artin
Share this post
Just now, Artin said:
Nope no blueing at all with manual focus lenses , I will check with with autofocus lens
Yeah it only happens with auto focus. It does not happen with M lenses
Share this post
Isn't it the AF system acquiring/correcting focus before locking?
Share this post
Yes and I just tested the af quickly goes back and forth and that is what you see , the camera actually engages focusing by quickly adjusting to make sure subject is still in focus
Share this post
Also I just noticed if you use the back focus half pressing the shutter does not engage anything, so it is basically the camera reassuring focus every time and at that second it is visible thru the the viewfinder.
Share this post
I don't see this in AFS mode. What I have noticed is that in AFC mode there's a slight blurriness as the focus constantly re-adjusts, which would be normal.
Are you seeing this in both AFS & AFC modes?
Share this post
I do see it in both afs. And afc.
Share this post
It should be less in AFs mode, as the AF will not be hunting all the time.
Share this post
Either way it’s quite normal and not distracting for me. I would not worry about it too much
Share this post
Mine does this. And as soon as I release the half press, the image in the finder is sharp. I have been trusting the green in focus indication and have had a pretty much 100% keeper rate. On a somewhat related note, I have left my pre-focus on up to now. I have always turned it off with my Sony cameras. With the SL2, I can hear the lens adjusting focus, but can’t see anything happening in the viewfinder. Even if I pan to a closer or farther away subject. With the Sony’s, I could always see the camera adjusting focus in the viewfinder, actually very annoying, so I shut it off. Also to save battery.
Share this post
Same with mine momentary blur annoying but I'm getting used to it  would prefer it didn't.
Share this post
I have the problem only in AF-C and far away objects I want to have in focus. It's just because of the hunting of the af system.
Share this post
In AFC you live with it. It’s the DFD system at work.
In AFS you can turn off pre-focus and not use 120FPS for the viewfinder. Both make the EVF *slightly* blurrier for me. You’ll also save some battery.
Gordon
Share this post
Well I am glad to read that I am not the only one experiencing this issue after asking on the SL2 Facebook group and getting nothing back. But I am not happy that there appears to be nothing to do to prevent it or fix it. I’m baffled by some people’s willingness to just accept it... from a $6000 state of the art camera? Loss of focus just as I am making final composition and timing decisions.  It’s infuriating me.
Share this post
So you would rather not have focus readjust the shot before you take it?
Share this post
Loading...
  • Similar Content
    • By Siran
      Would anyone be willing to share some tips on focussing manual glass on the SL2?
      What techniques do you use (Focus peaking, magification etc)? What is the most realiable and accurate for you?
      I use focus peaking and magnification, but feel this is a little slow (or I am  just slow and need practice! :-p)
    • By NRKstudio
      To the forum gurus:
      For my SL2, I am seeking a good on-camera flash with radio transmitter capability, plus a controller for it.
      I have the SF40, and it’s not making the cut really.  TTL is decent tho, but I just read “The Flash Book” by Scott Kelby and his system is all about setting the flash/camera (move the flash off camera if possible) to Manual mode (1/4 flash power, iso 100, 1/125 sec, f/5.6)and just adjusting the camera from there.
      So what have y’all been using for a good hot shoe flash and a radio controller??
      The SF58 and c1 remote are out of my budget unfortunately! I’m an amateur photographer who shoots just my toddler and wife, and some friends/family events.
      thanks in advance for the guidance!
    • By Siran
      I’ve just got my Leica SL2. Truly a beautiful camera!
      FWIW my thoughts on the camera after a few hours use are:
      - The initial start up animation is very classy
      - Really simple menu system, which is very welcome after using the Sony A7R3
      - Coupled with 24-90 lens it was more heavy than I had imagined. Add an on camera flash and you get a really good arm workout
      - The grip is really good!
      - The top dial will take some getting used to, again because I’m coming from a Sony
      -  Top plate display is excellent quality with info clearly displayed, however I got most of my info from the back lcd so not sure how much I will use it
      - Shutter sound is lovely
      Things I noticed:
      -  When I zoom into an image to see if it was in focus (particularly when using m lenses), the initial magnification point is never on the spot that I focused on. Very frustrating!
      - IBIS does not work with non Leica m-mount glass
      Other stuff:
      - I decided to get some Godox flash system equipment to use with the camera. I was told from an existing user that this system in a canon fit works very well with the SL2. Has anyone else had any experience?
      I’m going to start using it tomorrow I hope  New year, new photography tool! 🙂
      Happy new year all!
    • By LUF Admin
      Text & Photos Thomas A. Berger | www.tab-fotografie.de
      Translation by Michael Evans | English version first published on Macfilos | German version available here
      The headline of my little review, in which I use Leica’s own wording to announce the new SL2, is the start of the enthusiasm that I feel for the youngest scion of the House of the Red Dot.
      But first, I ought to review of my entry into the world of the SL. Euphoria and immediate enthusiasm were not evident at the outset when I experienced the first SL. In fact, my approach was over a rather rocky path. Suffice it to say that I did not really care much about the camera at the time of its release in 2015. I must confess that I could not do much with this camera at first.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Compared with my beloved M-cameras, it was too big, too heavy and, in view of the already long-established mirrorless competition of Sony & Co, with their excellent cameras, rather superfluous. Even for Leica it was way too expensive. These were my first reactions back then. And so it was that at the time the SL was removed from my wish list.
      At that time, Leica still played the supporting role for street and travel photography with the M system. For the main work in my job as an advertising photographer within my agency, apart from the digital medium format in full format, DSLR Nikons were my weapons of choice.
      Turnaround
      Then came the turnaround: As a Hasselblad V photographer for many years, I was enthused by the Hasselblad X1D when it arrived. The realisation grew with working with this mirrorless medium-format camera that my ever-increasing problems of focusing with digital SLR cameras were suddenly blown away. No more problems with blurring during hectic appointments, because the sharpness just does not sit at the one the spot, requiring you to sweat blood and water to get the sharpness where you need it.
      That was the initial spark which caused me to take a second look at the Leica SL as a possible workhorse. Good that I did, because at the very first encounter I recognised immediately that this was a great camera. It represented Leica’s high quality standards in the field of mirrorless cameras. From the start I got along well with the SL in its guise as a workhorse. Since then, my association with Nikon DSLRs has ceased after over 30 years. With the SL and M, I am now completely happy and at peace with Leica.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> No choice
      A few months ago, I was asked by Leica Forum administrators, Andreas and Leon, if I would be interested in becoming a field tester for the software of the forthcoming SL2. What a question! Of course I would.
      I should say in advance that this review is written against the background of a purely practical user who uses his camera professionally and privately in his own personal way. I am not a professional tester who judges the camera by means of neutrally processed test photos on the test bench. And, although I will of course try to judge soberly and factually, my findings are always relatively subjective and very related to my personal way of working.
      They are not very technically based, the image results are developed by me from RAW with the Photoshop converter, basically in my style. I will not go into much detail in terms of features and technical capabilities of the new body. Furthermore, I am predominately a stills photographer and my review therefore refers exclusively to photography with the SL2. I make no statements about the camera’s video opportunities, although I acknowledge that Leica has gone big-time into video with this camera and it is likely that many videographers will be attracted to the SL2.
      Ergonomics, handling and operation
      The die-hard SL user, picking up the SL2 for the first time after unpacking, will be amazed. Despite the familiar appearance at first glance, the -2 feels extremely different. It becomes clear at once that the slightly different design elements and surfaces have led to a significantly changed grip. The SL2 is a perfect example of how just a few millimetres of change in the chassis pitches and shapes can make a big difference or improvement to the handling.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png">
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Andreas Kaufmann, in a popular video interview, said that a new SL would not be as brutal and would be more cuddly. He certainly expected a significant redesign and some may say that he would have expected even little more change in the SL2. The original SL design was controversial from the start.
      But I am happy to say that the relatively minor changes in handling have wrought a significant improvement in the overall experience of owning this camera. The new “leather jacket”, the slightly rounded edges of the textured metalwork and, especially, the slight modification to the shape of the grip, with its inner recess, provides significantly more grip. The SL2 holds up well in my medium-sized male hands and is simply excellent to handle.
      The weight is practically the same — although you immediately think the camera is lighter because of the better handling. Although the new model is actually 80g heavier than that of the SL, I would have sworn the first time I picked up the -2 that it would be lighter.
      Here you can clearly see how the grip and feel can subconsciously create an impression of a camera. The dimensions of the camera have remained practically identical, the case has not increased in thickness. This is surprising because the SL2 now has IBIS with its moveable sensor. More on that later.
      What immediately catches the eye is the modified button design on the back of the camera. Here you have the three clearly-labelled pushbuttons as on the Leica M10 model, which I personally find great. (Also, incidentally, they are identical to those on the Q2 and CL).
      Those who work in parallel with the M10, such as me, find this departure from the unlabelled four-key concept of the SL a real relief. Although I got used to the SL over time, I always had my problems with the key assignment when things got hectic. The new concept suits me down to the ground. Joystick and adjustment wheels, on the other hand, have remained the same as on the SL.
      The new strap lugs, which are external and no longer recessed in the body, are a design cue I find a little less attractive. However, I do admit that it is now easier and quicker to attach and remove the strap as a result of the new design. It’s an improvement in practice, even though the sleek design has suffered as a result.
      When it comes to menu navigation, the SL2 is also quite similar to the M10 — but of course only in the areas that correspond to the M10. Added is a so-called quick menu in the main interface, which you can configure yourself. Here you can read the most important and most frequently used functions at a glance and operate them via touch interface without having to enter the list menu.
      One big change from the SL is the absence of a GPS. The SL2 has no antenna for locating and therefore no internal GPS. This is nicer for the design, because the ugly plastic hub on the left, under which the antenna was located, is now gone. GPS is now available only through the connection with the smartphone. Certainly some will regret that. Personally, it does not matter that much, as I’m not a copious user of tagged photos. Nevertheless, for some, this may be a downer.
      The Sensor
      The denser sensor is high on the list of reasons why Leica claims that the SL2 is a “milestone”. It is a completely new sensor with 47.3 effective-megapixel resolution. And is also equipped with IBIS. Above all, the so-called In Body Image Stabilisation — that is, the anti-shaking dachshund in the camera with the help of the movably mounted sensor — was a much-anticipated feature that has now become reality.
      For me personally, the addition of IBIS is at least as important as the doubling of the resolution, if not more so. The risk of blurred photos becomes greater as the sensor resolution increases. It is a great thing to be able to draw on it objectively and independently.
      It works too! As one who often attaches M-Lenses to his SL I think this is a really big step forward. With the many adapted manual lenses or also the new foreign lenses from the L-mount range of the partners without lens stabilisers (for instance, my new 45mm f/2.8 SIGMA with L-mount) having image stabilisation is a great asset. And, as already mentioned, Leica even managed to squeeze the IBIS sensor into an equally slim body. Perhaps that’s why they had to make the strap lugs external!
      I can only say good things about the image quality from the new sensor. Contrary to my fear that the higher resolution on the same sensor surface as the SL would lead to more noise in the higher ISO range, the SL2 has completely quelled those concerns.
      Even at ISO settings, the new sensor shows what it can do. The images are consistently not only finer, but also lower in noise than those from the camera’s predecessor. This is detectable at any ISO setting, but becomes visually more relevant once past ISO 400. This is really remarkable and refutes the commonly held opinion that a larger pixel density automatically leads to stronger noise.
      But I have confirmed one suspicion: The SL2 does not replace the digital medium format for me. However, it does come very close to the image quality of the larger sensors. Yet for those who need the last ounce of perfection in their photography, it is still not possible to better the larger-sized mirrorless cameras from Hasselblad or Fuji. That said, the distance between the new formats with the arrival of the SL2 has become significantly narrower. The SL2 achieves a level which will probably be sufficient in 90 percent of cases.
      Clarification
      I have made a small comparison to help clarify this proposition. Below a series of images, which I photographed with the Leica SL, the SL2 (each with the 24-90 Vario) and with the Hasselblad X1D and the 90s. I want to emphasise that my comparison is only about the noise behaviour and the dynamics, not about the resolution.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> The sharpening position is sometimes not exactly the same in the test shots, so my photos are not suitable for analysing the resolution but only for comparing the noise behaviour.
      For my assessment task I have also interpreted the results in the RAW processing and subsequent storage to the same level of resolution, so a total of about 50 megapixels, including the shots with the 24MP-SL.
      Thus, in my photographic reality, it is easier to compare what the sensors in the high-ISO range do when, as is common practice in the job, they are used for later for different media — for instance for large billboards or exhibition boards have to be “inflated” to the required resolution.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> My conclusions overall: Although the pixels of the SL are larger than those of the SL2 and thus would have to be brighter, the noise as the SL sensitivity increases is blatantly stronger. The quality gap between the two Leicas is definitely bigger than that between the SL2 and the Hasselblad. Of course, the SL2 and X1D have the same pixel resolution and so the fineness of the noise is initially the same, which is one explanation. Nevertheless, I find it amazing that the SL2, despite possessing only around 60% of the sensor surface of the X1D, keeps noise even at high ISOs so well under control. Leica has really done a good job and this includes pushing sensor technology into the high league..
      In practice
      To say it in one sentence: The SL2 is a lot of fun! When I got the camera I was again away on one of my small photo trips and, coincidentally has the task of photographing a wedding in Switzerland. As a result, my picture examples are not commercial in nature but include street scenes as well as scenes of the wedding.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> What impressed me most about the SL2 is the ease and speed with which you can take pictures. Compared with its predecessor, the new camera is not only easier to handle, more satisfying overall, but can also provide super-fast results. It is quiet, very agile and is therefore also ideal for street photography. It is quiet inconspicuous when used with correspondingly compact M lenses despite the SLR look. However, I should make one point here. The bright white Leica logo on the front of the viewfinder housing has even become a tad larger than it was on the SL and is just terrible. In a similar way, the red Leica dot is too close to the edge of the housing. As a trained graphic designer and typographer, I would have wished for more sensitivity here. But I digress.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> In this context, however, I should mention the outstanding viewfinder which, again, impresses mightily. I have the impression that it is not only of very high resolution but that it works without delay. It is a pleasure to achieve focus with the SL2 and I have to say that this is one of the best electronic viewfinders I have ever used.
      This is likely to be interesting for sports photographers in particular. I do some work in this area but I am by no means an expert. I use a lot of manual focus with the SL and the SL2, often with M lenses and also professionally in advertising shootings. Usually the autofocus for me does not need to be of high performance in the area of speed and follow-up.
      In this context, but to mention the very good viewfinder, which was also improved again. I had the impression that he is not only high-resolution but also works without delay. It is a pleasure to be in focus with him and he is still one of the best electronic viewfinder ever.
      Conclusion
      One thing is certain: I will definitely get the SL2, despite my continuing work with medium format. For me, the most important point is not necessarily the higher resolution. 47 megapixels in a Leica is basically great, but I still have my Hasselblad X1D. It will continue to be the first choice in the field of architecture and studio.
      What’s really intriguing to me about the SL2 is the ease and speed with which you can be on the road with these 47 megapixels. And that it also offers IBIS support. That simply is not on offer in a medium format camera. And with the comparative low price of just under €6,000, Leica has even admitted itself into a more “normal” price level. And that’s why my piggy bank has to cough up again. I just hope it’s getting fat enough.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Text & Photos Thomas A. Berger | www.tab-fotografie.de
    • By LUF Admin
      Testbericht von Thomas A. Berger | www.tab-fotografie.de
      Update 14. November 2019: English Version here
      Erste Erfahrungen mit einem neuen Meilenstein – Leica SL2
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! Zunächst ein Rückblick zu meinem Einstieg ins SL-Leben: Dass Euphorie und sofortige Begeisterung nicht von Anfang an für die SL standen, zeigt mein steiniger Weg zur ersten Leica SL. Von der Kamera war ich nämlich bei ihrem Erscheinen 2015 zunächst überhaupt nicht sonderlich angetan und ich muss gestehen, dass ich mit dieser Kamera zunächst nicht viel anfangen konnte. Verglichen mit meinen geliebten M-Kameras zu groß, zu schwer und angesichts der schon längst etablierten, spiegellosen Konkurrenz von Sony & Co. mit deren hervorragenden Kameras auch noch Leica-typisch viel zu teuer – das waren meine ersten Reaktionen damals und somit war die SL zunächst mal abgehakt.
      Zu dieser Zeit spielte Leica mit dem M-System bei mir immer noch die Nebenrolle für die Street- und Reisefotografie. Für die Hauptarbeit in meinem Job als Werbefotograf innerhalb meiner Agentur waren neben dem digitalen Mittelformat im Bereich Vollformat ausschließlich die DSLR-Nikons zuständig.
      Dann kam die Wende: mit Erscheinen der Hasselblad X1D, von der ich als jahrelanger Hasselblad-V-Fotograf gleich begeistert war, wuchs bei der Arbeit mit dieser spiegellosen Mittelformatkamera die Erkenntnis, dass meine immer größer werdenden Probleme der Scharfstellung mit digitalen Spiegelreflexkameras plötzlich wie weggeblasen waren. Keine Probleme mehr mit Unschärfe bei hektischen Terminen, weil die Schärfe einfach nicht auf dem Punkt sitzt und man Blut und Wasser schwitzt, um die Schärfe auch da hin zu bekommen, wo man sie braucht.
      Das war die Initialzündung für die Leica SL als mögliches Arbeitstier – und mit der ersten Live-Begegnung auch prompt die Erkenntnis: eine tolle Kamera, die den hohen Qualitätsanspruch von Leica im Bereich der spiegellosen Kameras sehr gut repräsentiert und mit der ich dann auch von Anfang an sehr gut zurecht kam. Seit diesem Zeitpunkt ist eine über 30 Jahre dauernde Arbeit mit Nikon passé und ich bin im Vollformat mit der SL und der M nun gänzlich bei Leica gelandet.
      Vor ein paar Monaten dann die Nachricht von unseren LUF-Admins Andreas und Leon, ob ich Interesse hätte, als Feld-Tester für die Software der kommenden SL2 tätig zu werden – was für eine Frage, die ich natürlich auch als rein rhetorisch gewertet habe! 😉
      Vorausschicken möchte ich, dass mein Review vor dem Hintergrund als reiner Praxisanwender geschrieben ist, der seine Kamera in seiner ganz persönlichen Art beruflich und privat einsetzt. Ich bin kein professioneller Tester, der die Kamera mittels neutral aufgearbeiteter Testfotos auf dem Prüfstand beurteilt. Und obwohl ich natürlich versuchen werde, nüchtern und sachlich zu urteilen, sind meine Erkenntnisse immer verhältnismäßig subjektiv und sehr auf meine persönliche Arbeitsweise bezogen. Sie sind nicht sehr techniklastik, die Bildergebnisse werden von mir in der RAW-Verarbeitung mit dem PS-Konverter grundsätzlich in meinem Stil entwickelt und ich werde auch nicht sehr ins Detail gehen, was die Funktionen und technischen Möglichkeiten des neuen Gehäuses anbelangen. Außerdem bin ich üblicherweise reiner Fotograf und mein Review bezieht sich deshalb auch ausschließlich auf die Fotografie mit der SL – Aussagen über die videotechnischen Möglichkeiten mache ich keine.
      Ergonomie, Handling und Bedienung
      Wenn man als eingefleischter SL-Anwender die SL2 nach dem Auspacken zum ersten Mal in die Hand nimmt, kommt sofort ein Staunen auf: Obwohl die Kamera auf den ersten Blick ihrer Vorgängerin zunächst sehr sehr ähnlich sieht, fühlt sie sich extrem anders an! Es wird sofort klar, dass die beim zweiten Hinsehen leicht veränderten Designelemente und Oberflächen zu einem deutlich veränderten Griffgefühl geführt haben. Die SL2 ist ein perfektes Beispiel dafür, wie nur wenige Millimeter Veränderung von Gehäuserundungen und Formen eine große Veränderung bzw. Verbesserung des Handlings bewirken können.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Es wurde nach der sinngemäßen Aussage von Andreas Kaufmann, einen neue SL würde nicht mehr so grob geschnitzt sein, sicherlich viel vom neuen Design erwartet und manch einer wird vielleicht sagen, dass er von der SL2 etwas mehr Veränderung erwartet hätte – zumal die SL ja bezüglich ihres Designs von Anfang an recht umstritten war. Ich kann aber berichten, dass die zunächst nur marginal wirkenden Veränderungen in der Handhabung eine deutliche Verbesserung gebracht haben. Der jetzt komplett umlaufende Kunststoffbezug, die leicht abgerundeten Kanten des mit Strukturlack versehenen Gehäuses und vor allem der in der Form leicht veränderte und mit einer Einbuchtung auf der Innenseite versehene Handgriff verhelfen der Kamera zu deutlich mehr Grip – die SL2 hält sich mit meinen etwa mittelgroßen Männerhänden einfach hervorragend!
      Das Gewicht ist praktisch gleich geblieben – obwohl man auf Grund des besseren Handlings sofort meint, die Kamera ist leichter! Auf meiner zugegeben ungenauen Haushaltswaage ist sogar eine im Vergleich zur SL ganz minimale Gewichtserhöhung zu verzeichnen (siehe Fotos), obwohl ich nach dem ersten Anfassen tatsächlich geschworen hätte, die SL2 ist leichter als die SL. Hier kann man deutlich sehen, was ein neues Griffgefühl bewirken kann. Die Maße der Kamera sind praktisch ebenfalls gleich geblieben, das Gehäuse hat auch in der Dicke nicht zugelegt. Das ist insofern erstaunlich, weil die SL2 jetzt mit ihrem beweglich gelagerten Sensor über IBIS verfügt – dazu später mehr.
      Was sofort ins Auge fällt, ist das veränderte Tastendesign auf der Kamerarückseite. Hier stand mit ihren drei wieder beschrifteten Drucktasten eindeutig die Leica M10 Modell, was ich persönlich super finde. Wer wie ich parallel mit der M10 arbeitet, empfindet diese Abkehr von dem unbeschrifteten 4-Tasten-Konzept der SL als echte Erleichterung. Ich habe mich im Laufe der Zeit bei der SL zwar dran gewöhnt, hatte aber immer wieder mal meine Schwierigkeiten mit der Tastenbelegung, wenn es hektisch wurde. Das neue Konzept kommt mir sehr entgegen. Joystick und Bedienräder sind hingegen in Bezug auf die SL gleich geblieben.
      Die jetzt nach außen abgesetzten und nicht mehr in den Gehäusebereich versenkten Chrom-Bügel für den Tragegurt empfinde ich zwar designmäßig als etwas weniger gelungen, aber dafür lässt sich nun ganz eindeutig der Tragegurt viel schneller und einfacher befestigen und wieder abnehmen. In der Praxis eine Verbesserung, auch wenn das glatte Design dadurch etwas gelitten hat.
      Bei der Menüführung ist die SL2 der M10 ebenfalls recht ähnlich – natürlich nur in den Bereichen, die mit der M10 auch korrespondieren. Hinzugekommen ist ein sogenanntes Schnellmenü in der Hauptoberfläche, das man selbst konfigurieren kann. Hier lassen sich auf einen Blick die wichtigsten und am häufigsten gebrauchten Funktionen ablesen und per Touchoberfäche sofort bedienen, ohne ins Listenmenü zu müssen.
      Eine große Veränderung gegenüber der SL betrifft das GPS. Die SL2 hat keine Antenne mehr für die Ortung und demzufolge auch kein internes GPS. Das ist zwar schöner fürs Design, weil nämlich der hässliche Plastik-Hubbel links, unter dem sich die Antenne befunden hatte, jetzt weg ist. Dafür gibt es GPS jetzt nur noch über die Verbindung mit dem Smartphone. Das werden sicherlich einige bedauern. Mir persönlich macht es nicht so viel aus, da ich auch hier kein ausgiebiger Anwender von getaggten Fotos bin. Trotzdem wird dies für so manchen vielleicht ein Wermutstropfen sein.
      Der Sensor
      Hier steckt sicherlich der Hauptfaktor der von Leica proklamierten SL2 als „Meilenstein“: ein völlig neuer Sensor mit 47 Megapixeln Auflösung – und der ist auch noch mit IBIS versehen! Vor allem die sogenannte InBodyImageStabilization, also der Anti-Wackeldackel in der Kamera mit Hilfe des beweglich gelagerten Sensors war ein sehnlichst erwartetes Feature, das Leica jetzt wahr gemacht hat. Für mich persönlich ist der IBIS mindestens genauso wichtig wie die Verdoppelung der Auflösung, wenn nicht sogar wichtiger. Denn die Gefahr unscharfer Fotos durch minimale Verwackelung steigt potentiell mit der Steigerung der Sensorauflösung. Völlig objektivunabhängig drauf zurückgreifen zu können ist eine tolle Sache. Und: es funktioniert auch! Ich bin einer, der sehr häufig M-Objektive an seine SL adaptiert und finde das einen wirklich großen Fortschritt, jetzt auch mit den vielen adaptierten manuellen Objektiven oder auch den neuen Fremdobjektiven aus dem L-Mount-Angebot der Partner ohne Objektiv-Stabi (wie z.B. mein neues 45er Sigma mit L-Mount) eine Bildstabilisierung zu haben – klasse! Und wie schon erwähnt hat es Leica sogar geschafft, den IBIS-Sensor in ein gleich schlankes Gehäuse zu stecken.
      Zur Bildqualität des neuen Sensors kann ich nur Gutes berichten. Entgegen meiner Befürchtung, die höhere Auflösung auf der gleichen Sensorfläche wie bei der SL führe zu einem stärkeren Rauschen im hohen ISO-Bereich, wird mit der SL2 widerlegt. Auch in den hohen ISO-Einstellungen zeigt der neue Sensor, was er kann: die Aufnahmen sind durchgehend nicht nur feiner, sondern auch rauschärmer als bei der Vorgängerin! Im Grunde ist das praktisch in jeder ISO-Einstellung zu sehen, optisch wirklich stärker relevant wird es ab ISO 400. Das ist wirklich bemerkenswert und widerlegt die häufige Meinung, eine größere Pixeldichte führe automatisch zu stärkerem Rauschen.
      Was sich aber auch bestätigt hat: die SL2 ersetzt für mich nicht das digitale Mittelformat. Sie kommt zwar sehr nahe an die Bildqualität der größeren Sensoren heran, aber wer das letzte Quäntchen Perfektion auch für die Kunden braucht, kommt trotzdem nicht an den größerformatigen spiegellosen von Hasselblad oder Fuji vorbei. Allerdings ist der Abstand mit der SL2 deutlich geringer geworden und ihr Niveau wird wohl in 90 Prozent der Fälle ausreichen.
      Ich habe zur Verdeutlichung einen kleinen Vergleich gemacht: nachfolgend eine Motivserie, die ich mit der Leica SL, der SL2 (jeweils mit dem 24-90er Vario) sowie mit der Hasselblad X1D und dem 90er fotografiert habe. Ich möchte betonen, dass es bei meinem Vergleich nur um das Rauschverhalten und die Dynamik geht, nicht um die Auflösung. Die Schärfelage ist teilweise in den Testshots nicht ganz exakt gleich, deshalb taugen meine Fotos nicht zur Analyse des Auflösungsvermögens sondern nur zum Vergleich des Rauschverhaltens. Ich habe außerdem für meine persönliche Einschätzung in der Praxis alle Aufnahmen bei der RAW-Verarbeitung und anschließenden Speicherung auf das gleiche Auflösungsniveau interpoliert, also insgesamt auf etwa 50 Megapixel, auch die Aufnahmen mit der 24MP-SL. So lässt sich in meiner fotografischen Realität besser vergleichen, was die Sensoren im High-ISO-Bereich leisten, wenn sie, wie es im Job häufige Praxis ist, für später benötigte Medien wie z.B. Großplakate oder Messetafeln auf die dafür benötigte Auflösung „aufgeblasen“ werden müssen.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Insgesamt zeigt sich dabei folgendes Bild: Obwohl die Pixel der SL größer sind als die der SL2 und damit lichtstärker sein müssten, ist das Rauschen mit höher werdenden Empfindlichkeitseinstellungen bei der SL doch eklatant stärker. Der Qualitäts-Abstand zwischen den beiden Leicas ist dabei definitiv größer als der zwischen der SL2 und der Hasselblad. Natürlich haben die SL2 und X1D die gleiche Pixelauflösung und damit ist die Feinheit des Rauschens zunächst einmal die gleiche, was eine Erklärung ist. Trotzdem finde ich es erstaunlich, dass die SL2 trotz nur etwa 60% der Sensorfläche der X1D ihr Rauschen auch bei hohen ISOs so gut im Griff hat. Da hat Leica wirklich einen guten Job gemacht und schließt damit sensortechnologisch in die ganz hohe Liga auf.
      Die Praxis
      Um es mit einem Satz zu sagen: Die SL2 macht sehr viel Spaß! Ich war in der Zeit, als ich die Kamera bekommen hatte, mal wieder auf einer meiner kleinen Fotoreisen und hatte außerdem zufällig in diesem Zeitraum eine Hochzeit in der Schweiz zu fotografieren. Demzufolge sind meine Bildbeispiele auch nicht kommerzieller Natur sondern beinhalten Street-Motive sowie Szenen des Paar-Shootings meiner Hochzeiter.
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Am meisten begeistert hat mich bei der SL2 die Leichtigkeit und Schnelligkeit, mit der man fotografieren kann. Die Kamera ist aus meiner Sicht im Vergleich zur Vorgängerin nicht nur deutlich besser zu halten – wie oben beim Thema Ergonomie ja schon angesprochen – sondern lässt sich einfach insgesamt super schnell bedienen. Die Kamera ist leise, sehr agil und eignet sich deshalb auch hervorragend für die Streetfotografie, da sie mit entsprechend kompakten M-Objektiven trotz Spiegelreflex-Look recht unauffällig ist. Nur ein Punkt arbeitet hier entgegen und dieses Manko liegt im Design: der strahlend weiße Leica-Schriftzug auf der Vorderseite der Sucherkappe ist sogar noch einen Tick größer geworden als bei der SL und fällt einfach fürchterlich auf. Wie übrigens auch der viel zu große rote Leica-Punkt auf der Vorderseite, der auch noch zu nahe an der Gehäusekante sitzt. Als ursprünglich ausgebildeter Grafikdesigner und Typograf hätte ich mir hier mehr Feingefühl gewünscht, aber ich schweife ab 😉 ...
      Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Hello guest! Please register or sign in to view the hidden content. Hallo Gast! Du willst die Bilder sehen? Einfach registrieren oder anmelden! /applications/core/interface/js/spacer.png"> Der Autofokus ist nochmals verbessert worden und bietet jetzt weitere Funktionen und Automatisierungen, auf die ich persönlich hier aber nicht sehr tief eingehen möchte. Nur so viel: es gibt sogar vorprogrammierte und selbst veränderbare Autofokus-Profile für verschiedene Bewegungsabläufe. Dies dürfte für Anwender wie z.B. Sportfotografen interessant sein. Ich bin in diesem Bereich aber nicht der ganz große Experte, da ich mit der SL und auch der SL2 sehr viel manuell scharf stelle, wie schon erwähnt häufig mit M-Objektiven arbeite und auch beruflich bei Werbe-Shootings in der Regel der Autofokus nur zur Scharfstellsicherheit dient und nicht sehr viel Leistung im Bereich Schnelligkeit und Nachverfolgung haben muss. In diesem Zusammenhang ist aber der sehr gute Sucher zu erwähnen, der ebenfalls nochmals verbessert wurde. Ich hatte den Eindruck, dass er nicht nur hochauflösender ist sondern auch verzögerungsfreier arbeitet. Es ist ein Genuss, mit ihm scharf zu stellen und er ist nach wie vor einer der besten elektronischen Sucher überhaupt.
      Fazit
      Eins ist sicher: Ich werde mir die SL2 zulegen. Trotz vorhandenem Mittelformat. Für mich der wichtigste Punkt ist dabei eben gar nicht unbedingt die höhere Auflösung. 47 Megapixel in einer Leica sind zwar grundsätzlich toll, aber ich habe ja noch meine Hasselblad X1D. Die wird auch weiterhin in den Bereichen Architektur und Studio erste Wahl sein. Was für mich persönlich an der SL2 wirklich faszinierend ist, ist die Leichtigkeit und Schnelligkeit, mit der man mit diesen 47 Megapixeln auf der Straße unterwegs sein kann. Und das auch noch mit IBIS-Unterstützung. Das bietet einfach keine Mittelformatkamera. Und mit einem für Leica-Verhältnisse vergleichsweise günstigen Preis von unter 6.000,- Euro hat sich Leica sogar auf ein einigermaßen „normales“ Preisniveau eingelassen. Und deshalb muss halt wieder mal mein Sparschwein dran glauben. Ich hoffe nur, dass es schon fett genug geworden ist ...
      Text und Fotos: Thomas A. Berger | www.tab-fotografie.de
    No registered users viewing this page.
Important Information
