tappan Posted January 19, 2020 Share #1 Posted January 19, 2020 (edited) Advertisement (gone after registration) My exact actions, etc, leading up to a freeze of the camera while "SD" blinks in viewfinder. I have an M9P. I understand and actually appreciate the limitations of Leica digital M's. I use Canon EOS 1DX Mark 11's for my job as a news photographer. If I needed a huge burst rate I would have just stayed with what I have instead of buying/loving Leica. I just purchased a demo M10P. I used it today for the first time. I used a SanDisk 64GB Extreme Pro, Class 10 (170MB/S). I formatted in camera. My drive was at "continuous High." I was shooting at DNG+JPG. 800 asa. Monochrome on. I used the camera off and on for about 1 hour. I did NOT "lean" on the shutter release. At one point, i simply pressed the shutter release for a very quick burst of 4 photos to see how fast the camera was FPS... I continued to shoot every once in a while for a few minutes. I then turned the camera's drive to "single" and turned off jpg and monochrome and was then only shooting raw DNG"s. Then, the camera froze. MENu would not come on and "SD" flickered of and on inside my camera's viewfinder/eyefinder. The battery area got a bit warmer than I think it should have been. Almost hot. The camera stayed jammed for several minutes. I repeatedly took the battery out and then the SD CArd over and over again. Finally it came back on. First thing that I did was change the settings back to DNG & JPG , and turned back on Monochrome. Oh well. Camera is working well now, but....I just spent a bunch of money on this and.......! Edited January 19, 2020 by tappan typos and misspellings Quote Link to post Share on other sites More sharing options...
Advertisement Posted January 19, 2020 Posted January 19, 2020 Hi tappan, Take a look here M10-P Freeze with "SD" Blink warning. I'm sure you'll find what you were looking for!
jaapv Posted January 19, 2020 Share #2 Posted January 19, 2020 Try another SD card. The camera is telling you that there is something wrong with this one. Quote Link to post Share on other sites More sharing options...
tappan Posted January 19, 2020 Author Share #3 Posted January 19, 2020 7 hours ago, jaapv said: Try another SD card. The camera is telling you that there is something wrong with this one. Hello Jaap. I should have mentioned that it was a new card (first time out of the box), and then I switched to a San Disk 32GB class 10 Exxtreme Pro 95mb/s, and it still would not unfreeze. Mark Quote Link to post Share on other sites More sharing options...
pedaes Posted January 19, 2020 Share #4 Posted January 19, 2020 (edited) 15 minutes ago, tappan said: Hello Jaap. I should have mentioned that it was a new card (first time out of the box), and then I switched to a San Disk 32GB class 10 Exxtreme Pro 95mb/s, and it still would not unfreeze. Mark Formated? Edited January 19, 2020 by pedaes Quote Link to post Share on other sites More sharing options...
jaapv Posted January 19, 2020 Share #5 Posted January 19, 2020 In that case put a wipe of contact spray fluid on an old card and insert a few times, if that doesn't help and it repeats the problem, you will have to contact Leica, I fear. 1 Quote Link to post Share on other sites More sharing options...
tappan Posted January 19, 2020 Author Share #6 Posted January 19, 2020 5 minutes ago, pedaes said: Formated? Yes, in camera. MARK 1 Quote Link to post Share on other sites More sharing options...
tappan Posted January 20, 2020 Author Share #7 Posted January 20, 2020 Advertisement (gone after registration) UPDATE>Since I switched to the San Disk 32GB class 10 Extreme Pro 95mb/s, I have had no problems. I shot with the camera all day today. All good. Mark Quote Link to post Share on other sites More sharing options...
