TangoCharlie27 Posted December 14, 2019 Share #1 Posted December 14, 2019 (edited) Advertisement (gone after registration) The dial on the back had always been firm which is fine. But lately it has been very hard to shift around and sometimes appearing to almost jam. Is there a quick fix...how can I remove the dial and take a look or has the camera got to travel back to Germany? Edited December 14, 2019 by TangoCharlie27 Quote Link to post Share on other sites More sharing options...
Advertisement Posted December 14, 2019 Posted December 14, 2019 Hi TangoCharlie27, Take a look here M10-D On/Off/Wi-Fi Dial tough to move. I'm sure you'll find what you were looking for!
Guest Posted December 14, 2019 Share #2 Posted December 14, 2019 (edited) 1 hour ago, TangoCharlie27 said: The dial on the back had always been firm which is fine. But lately it has been very hard to shift around and sometimes appearing to almost jam. Is there a quick fix...how can I remove the dial and take a look or has the camera got to travel back to Germany? I wouldn't mess with it..........So yes sadly it's probably a trip back to Wetzlar to fix it. While you're at it, ( if you agree of course ), please let Leica know that the rear dial is a poorly executed piece of design. For instance I feel that it should have been metal like the previous MD's rear dial and that there should have been a safety catch to prevent one accidentally turning too far to the WiFi position when switching the camera on. Meantime, if you can turn it on, leave it on. Mine is set to 2 minutes "sleep" time, the on/off dial is camera taped so it can't be moved and I find that the battery drain when the camera isn't used even for a few days or more is minimal. My MD is "On" pretty much all the time. Edited December 14, 2019 by petermullett Quote Link to post Share on other sites More sharing options...
TangoCharlie27 Posted December 14, 2019 Author Share #3 Posted December 14, 2019 (edited) 42 minutes ago, petermullett said: I wouldn't mess with it..........So yes sadly it's probably a trip back to Wetzlar to fix it. While you're at it, ( if you agree of course ), please let Leica know that the rear dial is a poorly executed piece of design. For instance I feel that it should have been metal like the previous MD's rear dial and that there should have been a safety catch to prevent one accidentally turning too far to the WiFi position when switching the camera on. Meantime, if you can turn it on, leave it on. Mine is set to 2 minutes "sleep" time, the on/off dial is camera taped so it can't be moved and I find that the battery drain when the camera isn't used even for a few days or more is minimal. My MD is "On" pretty much all the time. Thanks. that's exactly what I've been doing regarding the leaving on sleep. I have found that if I dial it to the off position, it can be very hard to move it at all. It almost looks like the plastic dial is warped. What can cause it to cease up? Switches or the dial? Dust under the dial? Edited December 14, 2019 by TangoCharlie27 Quote Link to post Share on other sites More sharing options...
AndreasG Posted December 14, 2019 Share #4 Posted December 14, 2019 vor 30 Minuten schrieb TangoCharlie27: It almost looks like the plastic dial is warped. Could this happen if too much axial pressure is applied onto the switch while turning? Quote Link to post Share on other sites More sharing options...
Guest Posted December 14, 2019 Share #5 Posted December 14, 2019 39 minutes ago, TangoCharlie27 said: Thanks. that's exactly what I've been doing regarding the leaving on sleep. I have found that if I dial it to the off position, it can be very hard to move it at all. It almost looks like the plastic dial is warped. What can cause it to cease up? Switches or the dial? Dust under the dial? 8 minutes ago, AndreasG said: Could this happen if too much axial pressure is applied onto the switch while turning? Well I think my answer to both of your questions here is again that I think that the rear dial switch on the M10-D is poorly conceived and poorly made....It should have been of metal construction like the previous MD, definitely not made of plastic which isn't a good choice for a camera of this cost and quality and also I think that the dial itself wasn't thought out well. I know Leica must have testers for their new designs but I wonder how rigorous the testing is and whether or not the testers themselves do actually influence Leica's design decisions. I know that if I had been one of them for the M10-D I'd have presented Leica with a list of corrections and questions "why"..............BUT having said that, with all the frustrations I do have with the camera this is for me the best digital M that I've yet owned. Quote Link to post Share on other sites More sharing options...
jakontil Posted December 14, 2019 Share #6 Posted December 14, 2019 Im surprised and never realized it was made of plastic instead of metal construction dang..! Quote Link to post Share on other sites More sharing options...
inglis Posted December 15, 2019 Share #7 Posted December 15, 2019 Advertisement (gone after registration) If you leave it on all the time and it times out, do you use the shutter to reactivate the camera? Quote Link to post Share on other sites More sharing options...
Guest Posted December 15, 2019 Share #8 Posted December 15, 2019 2 hours ago, inglis said: If you leave it on all the time and it times out, do you use the shutter to reactivate the camera? Yes.... Quote Link to post Share on other sites More sharing options...
TangoCharlie27 Posted December 15, 2019 Author Share #9 Posted December 15, 2019 (edited) I'm sending it back right now. Switching back to my M9 until I see it again. You can see my issue here... Edited December 15, 2019 by TangoCharlie27 1 Quote Link to post Share on other sites More sharing options...
jakontil Posted December 15, 2019 Share #10 Posted December 15, 2019 6 hours ago, TangoCharlie27 said: I'm sending it back right now. Switching back to my M9 until I see it again. You can see my issue here... That’s pretty bad mate, i wish u have a quick solution and get it back working wonderfully agan 1 Quote Link to post Share on other sites More sharing options...
ChillnScott Posted June 10, 2020 Share #11 Posted June 10, 2020 How did your repairs end up? My M10-D has started doing the exact same thing. It was fine 2 days ago, yesterday it was really difficult to move and today it's completely frozen. Fortunately, I read your post and left it at the on position. I'm just curious if they explained why it occurred and what to do if it occurs again. Quote Link to post Share on other sites More sharing options...
Guest Posted June 10, 2020 Share #12 Posted June 10, 2020 Mine's at Wetzlar now, for a mother-board/internal battery problem, but I also asked them to look at the rear OFF/ON/WIFI switch too because I always secure mine at the ON position with a piece of black paper camera tape, ( I keep the camera "ON" with sleep set to 2 minutes, and that works for me ), because it too easily goes to the WIFI position and that drains the battery very quickly. I have always felt that this switch was poorly conceived, at least for me anyway, and I'd much rather have had the ON/Off at the normal M position, under the shutter release with WIFI activated in another, safer, way and exposure compensation dealt with by the thumb wheel. I've yet to hear back from them regarding the switch. Quote Link to post Share on other sites More sharing options...
fredbonhomme Posted August 19, 2020 Share #13 Posted August 19, 2020 Any news from your cameras ? Did Leica found a correct solution ? Thanks. Quote Link to post Share on other sites More sharing options...
Guest Posted August 19, 2020 Share #14 Posted August 19, 2020 On 12/14/2019 at 11:24 AM, petermullett said: For instance I feel that it should have been metal like the previous MD's rear dial... It seems to me it is metal, except the centre cap part. Quote Link to post Share on other sites More sharing options...
fenykepesz Posted August 20, 2020 Share #15 Posted August 20, 2020 it's actually metal, likely brass : look here - i was so crazy to drill some holes, or dents i should say, so fed up i was with that loose dial. look also here and here. ultimately it's now black textile tape that covers most of the dial which explains why the colored holes at the dial's side were needed... Quote Link to post Share on other sites More sharing options...
