kengai
differences between Summicron 35 "king of bokeh" and Summicron ASPH
He’s a very reputable guy. He’s a coauthor of Cavina. In Italy, there are a few of very experts about Leica. Some of these say that numbers of Erwin Puts are not always correct.
In any case there’s no contradiction about this point.
Germany (new model ) : From 339xxxxx
Canada (new model) : From 341xxx
Just check your serial and nationality and you understand if a newer model or not.
For example I have a Canada 341185xx
in-fact it’s a model with frontal ring in metal.
Edited by Sergius
Share this post
Canada (new model) : From 341xxx  [...]
I sympathise with what you say Sergius but this would mean than more than the half of the total production would be a newer model since 1986 which i feel difficult to believe but i may be wrong :cool:
Share this post
I don't know lct.... I'don't know the volume of production. But in my experience I can say It's correct (if you want a "newer" model ) this classification. You can simply check the serial number and see the material of frontal ring.
An another trick is the weight of lens (only for the black one, of course) It's passed from 150 gr. to 200 gr.
Share this post
Problem is my German copy from 1991 (3553*** above) weighs 156g. Mystery thickens...
Share this post
Your scale is ok ? Did you weigh the old one Canada ?
Share this post
Don't worry Lct, your copy is not "plastic inside", if 156g is without cap or hood, that is the "good one" in my experiences.
In last decades, I had in my hand maybe dozen of Summicron 35mm IV, old aborted project to make kind of statistics of renderings.
Those were Wetzlar or Canada made , as I've found and the best ways to find out which " plastic" which "non plastic" :
- at front the ring is larger and colored in "brownish plastic" that one is "plastic inside",
Lct your copy is "solid" metallic front ring with serial number and E39 is one of the non-plastic unit
compare also the 2 slots for tools in this front ring
- second evidence weight : 130-135g = "plastic inside" and my non plastic units weight 150-155g
"Plastic-inside" looks like this one
No plastic inside, Germany (one that I sold some time ago)
Edited by a.noctilux
Share this post
The scale is OK but i have not my Canadian copy on hand so i cannot compare the color of what you call the front ring. Last time i checked it weighed about 150g if memory serves.
Share this post
I can't seem to view your pic Arnaud.
Don't worry Ict.... You 35xxxxx has the metal ring for sure.
Share this post
ID ring.
"plastic inside" is surrounded by "plastic gray/brown larger ring"
While
On the other type, the ID ring "non plastic one" has flatter slots surrounded by thinner ring.
Share this post
Got it thank you. I thought some inner plastic parts were visible through the glass.
Share this post
8 hours ago, lct said:
OK thanks but the plastic parts Marco Cavina refers to look different. In red in the graph below.
Interesting technical drawing, thanks lct.
We can see here clearly the plastic parts and relation of the front plastic part inside.
I'd like to see the non-plastic "same" technical drawing 😎
Share this post
Comes from my link to Marco Cavina's article here:
Share this post
On 11/18/2019 at 5:29 PM, adan said:
A different example of v.4 bokeh at f/2 (digital, M9). In this case I found it quite brilliant, interesting and effective.
I know most people don't but I actually love that bokeh, it's unlike that of other lenses I've used and that's why I love my copy of the v4.  I'd like to know whether other lenses have that same characteristic.
Share this post
Loading...
    No registered users viewing this page.
Important Information
