dickgillberg Posted November 14, 2019 Share #1 Posted November 14, 2019 Advertisement (gone after registration) The light on the frame lines in my M10P is usually pretty dim when I use it in darker environments. It's slow changing when the light are different if not at all. Why can't we decide the strength of the illumination in the menu? Or do I miss something? And I noticed my camera have more illumination of the frame lines on the right side. Quote Link to post Share on other sites More sharing options...
Advertisement Posted November 14, 2019 Posted November 14, 2019 Hi dickgillberg, Take a look here frame lines on M10P?. I'm sure you'll find what you were looking for!
Jeff S Posted November 14, 2019 Share #2 Posted November 14, 2019 (edited) First, be sure that your fingers aren’t covering the front window, and that the glass is wiped clean. And be sure your eye is centered (more importantly for best focusing). DAG apparently has an accessory for the issue, but I have no experience with it (nor any need)... https://gmpphoto.blogspot.com/2018/08/leica-m-viewfinder-frame-illuminator.html?m=1 Jeff Edited November 14, 2019 by Jeff S Quote Link to post Share on other sites More sharing options...
jaapv Posted November 14, 2019 Share #3 Posted November 14, 2019 AFAIK, the M10(P) has LED-illuminated frame lines, thus no frameline window. 2 1 Quote Link to post Share on other sites More sharing options...
jdlaing Posted November 14, 2019 Share #4 Posted November 14, 2019 6 hours ago, dickgillberg said: The light on the frame lines in my M10P is usually pretty dim when I use it in darker environments. It's slow changing when the light are different if not at all. Why can't we decide the strength of the illumination in the menu? Or do I miss something? And I noticed my camera have more illumination of the frame lines on the right side. Is the rangefinder patch illuminated the same brightness as the framelines? Quote Link to post Share on other sites More sharing options...
adan Posted November 14, 2019 Share #5 Posted November 14, 2019 Nope - in M240/M10, framelines are electrically lit, the RF patch is simply the natural brightness of the scene (times two, from two windows overlapped, minus any glass/coating transmission losses). The frameline LED illumination is auto-controlled by either the "blue dot" sensor on the top front, or the internal "classic" light meter - to adjust with subject brightness (probably the first, to avoid lens aperture biasing the frameline brightness.) And to the OP's question, no, there is no user adjustment for framelines, just the available light detected. The LCD on the back can be adjusted by the user menus for Auto, or to a fixed dim > bright amount. 2 Quote Link to post Share on other sites More sharing options...
Jeff S Posted November 14, 2019 Share #6 Posted November 14, 2019 (edited) 2 hours ago, jaapv said: AFAIK, the M10(P) has LED-illuminated frame lines, thus no frameline window. I should have said brightness sensor on front, not window. Jeff Edited November 14, 2019 by Jeff S Quote Link to post Share on other sites More sharing options...
mujk Posted November 14, 2019 Share #7 Posted November 14, 2019 Advertisement (gone after registration) This is one of the quite few really annoying "features" of the M10. It is particularly noticeable when the middle of the scene is much darker then the rest. This is probably because the brightness sensor seems to be center-weighed, like the built in exposure meter (which makes sense for the primary use of the sensor, i.e. guesstimating the aperture setting based on the difference in meter reading). I don't know why Leica hasn't made the framelight brightness setting configurable, assuming it is controllable by software. If that is not the case, it would be quite an odd design decision... Quote Link to post Share on other sites More sharing options...
jaapv Posted November 14, 2019 Share #8 Posted November 14, 2019 3 hours ago, Jeff S said: I should have said brightness sensor on front, not window. Jeff OK, but that gizmo won't work Quote Link to post Share on other sites More sharing options...
Jeff S Posted November 14, 2019 Share #9 Posted November 14, 2019 3 minutes ago, jaapv said: OK, but that gizmo won't work Don’t understand... my point was to keep the sensor unobstructed, and clean, for optimal performance. Jeff Quote Link to post Share on other sites More sharing options...
jaapv Posted November 14, 2019 Share #10 Posted November 14, 2019 https://gmpphoto.blogspot.com/2018/08/leica-m-viewfinder-frame-illuminator.html?m=1 Quote Link to post Share on other sites More sharing options...
Jeff S Posted November 14, 2019 Share #11 Posted November 14, 2019 Correct...only on models prior to M240... my mistake. Jeff 1 Quote Link to post Share on other sites More sharing options...
Peter Kilmister Posted November 14, 2019 Share #12 Posted November 14, 2019 The only problem I had with viewfinder framelines was when my M10-P was new and I hadn't fully clicked the lens into place. Mea culpa! Since then no problem and it highlights well in poor light. Quote Link to post Share on other sites More sharing options...
dickgillberg Posted November 15, 2019 Author Share #13 Posted November 15, 2019 Well, let's hope we can get a menu option to change the illumination of the framelines from auto to mid and high. I think the auto, on my camera anyway, works to slow when I go from low light to high light in a room. That's on my wish list, otherwise the M10P are almost perfect. Quote Link to post Share on other sites More sharing options...
mujk Posted November 15, 2019 Share #14 Posted November 15, 2019 16 hours ago, jaapv said: https://gmpphoto.blogspot.com/2018/08/leica-m-viewfinder-frame-illuminator.html?m=1 I guess you could build something similar to trick the light sensor on the M10 to believe it is really in very bright conditions. Tried it with a small flashlight. Seems to work. Would of course give crazy aperture values in the EXIF. Actually, I sometimes have an even bigger problem than the dim framelines, because also the led display in the OVF goes very dim under certain conditions (controlled by the same sensor). Manual setting would fix this too. Quote Link to post Share on other sites More sharing options...
